ive noticed that sometimes if you run memtest and get say 75 errors, then run it again it will give you a different number the second time....kinda makes it hard to tell if more or less voltage is helping...unless the error difference is significant
Yep. Best is: errors equal 0 :DQuote:
Originally Posted by stealth17
But if errors during longer memtest sessions occur, there may be a heat problem... cooling the ram better is a good idea ;)
ive always thought that and some frown on the idea for some reason :confused:Quote:
Originally Posted by SAE
get my NF4 tommarrow!!!! :D :slobber: :p:
Good luck pal, and don't fry it on first day :lol:
Mine comes with the FX-55, and that's gonna last... :( (already payed, but still not available)
I just ordered my NF4, maybe in two weeks?
i got some issue overclocking my DFI LPB with 2-2-2-11-9-12-1T timing even at 200MHz
Proc : AMD Aplebred 1600 (tbred A)
Mem : TwinMOS SP 2 x 256mb Vdimm @ 3.3V in bios
vdd = 1.7 v
v agp = 1.5v
The board run fine if i use it. But if i leave it for awhile(20-30 minutes) with heavy load. It just freeze .... :(
@ tictac - my board never ran 200mhz 3.3v stable, i always though it was the ram... but maybe SP has the same problem...try 3.2v maybe?
or maybe try 2-2-2-11-13-15-1t?
i let it prime and go to sleep... when i wake up... system is freezing... prime show it is stable for 3 hours ... :-/
ok i will try loosen the timing
got my DFI NF4 and 3200 winnie yesterday...VERY nice mobo! got a bad cpu stepping but ill see what i can do with it. Running good temps. 21c full load but thats at stock so...
yeah, try 2-2-2-11-13-15.. some have mentioned ch-5 having issues at 9-12.
ive always used 13-15 anyways, seems more stable when i get up top in FSB.
BTW my NF2 i think is dead, hasnt posted in a day or two...
seems normal for those crappy nf2...go nf4 man! LOVE mine!Quote:
Originally Posted by Revv23
Hey... i just did the Vcore mod on my DFI LPB... with just a pencil trick...OMG... it works :hehe:
tictac Pencil Vcore Mod
1) you only need to pencil down this resistor i mark with yellow color...
2) The resistor value is about 100 ohm
3) pensil it down to reduce the resistance.and you will get higher Vcore voltage
4) i pencil it down to 90-95ohm
5) now when i set 1.55v Vcore in bios i get 1.6V (0.05V overvolt) :D
Tested by me... on my DFI Lan Party B
Happy Tweaking... ;)
ignore that 2 red & black wire :slap:
http://www.tictac.katrourke.com/pic/...Pencil-mod.JPG
Tictac, do ya notice stability problems now? Or is it as stable as before using the 2V setting? :)
oh great.. now I want another infinity lol.
i cant play with 2.0V vcore with stock cooling & tbred A... its too hot to get it stable :bsod:Quote:
anyway i have been priming for 5hours... and it is stable so far... still running & kicking ass :lol:
Cool, mate :thumbsup:
BTW, what fsb your running those Twinmos at? :)
@ tictacQuote:
Originally Posted by tictac
What do you mean with "pencil down"? How does this work? :rolleyes:
decrease resistance of the resistor because the graphite the pencil lays down re-routes some of the electricity.
Ahhh ... and where do i have to draw with the pencil? The whole resistor?
just from one side of the resistor to another, start small and then check and see how much voltage your getting, then put more lead on it until your where you want it...
thats awesome btw tictac...very nice work sir...
im rebuilding my whole rig right now in a an effort to get it going, things arent looking good though.
Along its side. :) (one side, it's equal which you chose)Quote:
Originally Posted by Esox
Fine :) Thx!
Hello guys, i have annoying problem with my infinity.
I can do till 285 3D stable but is only single channel.
First i had 2x256 hynix d-43 and max 250 3-4-4-x.
All above that = errors in memtest + 3D crashing to desktop.
Now i have 2x256 adata tccd and it is worse...... max 245 3-3-3-x and higher is the same - memtest errors + 3D crash after 5s.
I have tested VDD 1.6 - 2.3V = nothing (5 mhz in single),
alpha all combinations ( more or less errors) slew rate = nothing, Vmem 2.6-3.3 = nothing.
Now i'm waiting for BH6 (256 2-2-2 3.3V tested) but i'am afraid history will reply..
Have someone simillar problem to me ? Is board crappy or fussy or maybe memory bad chosen. I have no idea :confused:
(my english is bad, i now, sorry)
IMO hynix and tccd are da cr@p :D No, honestly, on NF2 boards they do suck! :(
BH-6 should serve ya well though, mate, I hold thumbs :up: for ya.
