What country are you in?
@Deluded, PM sent.
performance-pcs.com is having a big sale of some heatsinks, from 75% to 82% off. A bunch of coolers for $9.99 each.
Might be interesting for us http://www.performance-pcs.com/catal...x&cPath=46_821
man those are some really great deals, good find werd.
stay patient on the boards guys, they WILL get to you. i'm still trying to deal with the seller on the bad boards and i guess he doesn't email over the weekends or something.
Any ideas which of those will fit on the two sockets that are right next to each other? Need to jump on that.
EDIT:The Vapochills don't require a top retention bracket which is nice. If they fit next to each other at that funky angle I think I'll buy some.
EDIT: Someone bought all the K8 Extreme and High End Vapochills. Jerks!! (Please ignore the appearance of these in any photos of my setup.)
Idk. But I can tell you the coolers I got (http://www.newegg.com/Product/Produc...82E16835103064) fit with zero room to spare. Orientated with fan -> heatsink -> (touching) fan -> heatsink. I hope that makes sense. Anyway you can compare with those dimensions
Ok I need to find appropriate boxes to send these out. Anyone got any bright ideas?
What are the board dimensions?
These came yesterday.. :D
http://i58.photobucket.com/albums/g2...0704001452.jpg
16x13. So now you got cpus, what else do you need?
Well that won't fit in a USPS box... hm.
I need the board, RAM (getting from work) and power cable adapters. And a box to mount it in :P
Board is coming soonish. Cable adapters can be found compusa if you have one of those. Make sure your psu is single rail
Hmm it isn't, it is an Antec Truepower New 750W. Single rail a requirement? Sigh, must have missed that. I didn't think I had to buy a power supply.
single rail is HIGHLY reccomended for quad quads, either that or a very strong 12V rail, although, you MIGHT be able to get the power you need off multiple rails, depending on the layout
The power supply is an Antec Truepower New 750W. Each rail is rated at 25A, there are 4 of them, and the max total wattage combined is 744W, only 6W shy of the total output lol. I would think it would have enough 12V guts, the issue I suppose is possibly connecting rails together when hooking it all up.
I guess you'll just have to try it. It'll either work or not I suppose. You could sell it for the price of a new 500w psu,maybe more
75 amps in the 12 v (combined) in a non single rail psu for 2 boards, would that cut it?
thanks
these might be worth looking at for you guys looking for coolers. these are the ones i'm using.
http://cmstore.coolermaster-usa.com/...roducts_id=520
thanks. i decided to get two of those. i'm only getting two cpus for now, i don't have enough $$$ to get all four right away.
so an update for me:
memory is in hand!
cpus are in the mail from Deluded!
just ordered the two coolers from Coolermaster!
already have 2 psus, each one is overqualified :p:
need to order or purchase adapter cables.
need the motherboard.
:up:
Hmm more decisions!
1.8GHz 79W TDP for $24.88 (http://www.cpu-world.com/CPUs/K10/AM...46PAL4BGC.html)
OR
1.9GHz 115W TDP for $27 (http://www.cpu-world.com/CPUs/K10/AM...47WAL4BGC.html)
1.8 79w for sure. i wish i had those! the PPD/watt will be much much better
update on the boards: the seller got back to me and offered to replace or refund the bad boards. the problem is who is going to pay for the shipping? i'm hopefully getting some boxes tomorrow from my wife's work. finding the appropriate sized boxes is hard
or any restaurant...
