Good job, guys! :up:
@ owikh84: you have a higher frequency run with the same chip already, so I have not replaced it. I can if you want, though.
i7 920 D0 HT on, Stepping 3938Bxx (cant remember)
214.5 x 21=4504mhz 1.432v
Asus Rampage Gene II
Adata DDR2000x
Water - H50 pump/block-> Stock 120 Rad.->MCR220w/Res. with 1/4 ID tubing, 6 Rosewell 120mm 2000rpm fans push/pull 78f ambient 87c peak
All memory used, 21 run successful
Made it :D
http://i27.tinypic.com/2vubjno.jpg
i for the life of me can't seem to get LinX to ever continue past the first run without errors... yet every other program *prime95, memtest, super pi and RealTemp GT* all go through with flying colors every time... i don't get it >.<
at the moment i'm running 4.5ghz cpu and 1900mhz mem w/ 12gb and it's been running solid all day with several different games...
GA-H55M-S2HP mobo
http://img830.imageshack.us/img830/7016/dgzs.jpg
I know the LinX time ...
Onboard graphics...
Good afternoon everyone, today is a warm end-of-July day in Virginia.
A challenging day for oc for sure, especially with a Cascade for a space warmer! :rolleyes:
Even so, the IHS was staying in the -40s. :)
So Mr Zalbard, please update my 980x entry yet again.
I think to go much higher I will need much cooler weather.
I would love to get 5.3 but probably not likely till later in the year.
So anyway - drum roll please :D:D - 980x at 5.2 linx stable -
http://img823.imageshack.us/img823/267/5200h.png
Nice run, but whats with the low gflops dude? With HT off at that speed you should be over 100 surely?
Yep, I saw that too, gflops seem to be all over the place with 32nm
I have had this same 980 at over 100 - :shrug:
I want to Join.
Core i7 930 [4C 4T] @ 4620.3MHz pass linx 62 loops run on water.
Core i7 930 / Gigabyte X58A UD7 bios F6 / micron ddr3 1333 d9jnm 1GBx3 / Water Cooling
http://img831.imageshack.us/img831/1856/19878586.th.png
http://img409.imageshack.us/img409/9162/68782514.th.png
http://img695.imageshack.us/img695/7166/22088330.th.png
http://img39.imageshack.us/img39/4948/34739471.th.png
http://img695.imageshack.us/img695/7166/22088330.png
hi! Mr. zalbard please check, two post was same link. ~thx u
# mwlhr | Core i7 920 [4C 8T] @ 4503.6MHz | 1.470 | EVGA Classified E760 | Water | 3925A260
http://www.xtremesystems.org/forums/...&postcount=455
# kup | Core i7 920 [4C 8T] @ 4501.7MHz | 1.360 | ASUS P6X58D | Water | 3912B185
UPDATE!
i'm proud to anounce i ACTUALLY got successful passes in LinX! though i do not have a screenshot to post just yet, i just didn't have the time to get all 20 passes, but it's done 7 passes so far and i will post a screenshot when i can get 20 passes through, but here's the settings. i DO need to reseat my water block though, i have 2 cores that are getting MUCH hotter than the rest by around 10*c so i think my thermal paste is off a bit or i have too much preasure on one side of the block. i found that LinX wasn't passing because my QPI was too high and was causing errors.
4.54ghz / 1866mhz mem / 1.39v QPI / 1.48v CPU / 1.66v DRAM / (34x133 ratio)
980x cpu / ASUS R3E mobo / Corsair 12gb DDR3 1866 CL9
HTT Enabled
Gflops Score: average 81-82!!!
Thats current feedback throttling dude - happens by default when the cpu draws over 100 amps. There shoul dbe an option in bios to disable that. On my Bloodrage its called "Enable Current Feedback Over-ride", have a poke round in bios and see what you can find. Asus have been plagued by these multi throttling issues since the first P6 board came out. Took them ages to fix the P6T-Deluxe throttling issues.
Has anyone on the R3E thread mentioned or noticed the same thing?
SteveRo - Still blown away by that 5.2ghz run after a nights sleep. Just mental dude :eek2:
Thanks Mr Pilsy - I think I could do 5.3 if I could get my ambient temps down - might not happen until next Fall.
:up: Nice one Steve.
Must admit, i can't understand those Gflops either.
Sometimes one really has to question just how good or bad Linx really is as stability prog, because it is so inconsistant.
I was having a similar problem with my Q9650 the other day I was getting like 37 gflops and my temps were much lower. I have a feeling a thread crapped out w/o being detected by linx/IBT because it finished both tests (20 passes) but failed prime blend instantly:shrug:
Jesus SteveRo, awesome run with that 980X :up: You're thrashing it hard :D
phase cooling really helps with the high cpuv. :yepp:
cascade cooling has also allowed me to improve my PC Mark Vantage World Record to - 38684 - :D
see -
http://www.xtremesystems.org/forums/...&postcount=172
@ kit - yes but now I am able to speak from personal experience :)
@ Mr Zalbard - yep - see new WR score - http://www.xtremesystems.org/forums/...&postcount=172
@ Mr Kit - yes a little concerned but all is well so far.
ThanksQuote:
I fixed this. Thanks for mentioning it! :up:
Adding yours in a bit, too. :yepp:
