Originally Posted by
Sam_oslo
Yes I'm having some fun and good results with these sticks :).
VVT-volt seams to be very CPU-pendent. So far, my w3520 hasn't care much about VVT, and I can't see it having any effect on stability, yet. So far (up to 216x19) it is running stable with anything from 1.21v to 1.28v VVT. But it doesn't like high VVT-volts at all, and it can't even get into windows with VVT>1.32v :rolleyes:.
On the other hand, my i7 920 C0 wouldn't run stable at it's highest 24/7 OC, @4GHZ(211x19) 1.34v with anything else than VVT=1.34v. But it didn't care much about VVT at lower speeds and would run stable with almost anything at < @3.8GHZ.
I have to test more to make sure, but so far, the new RAM haven't had any affect on VVT, either.
I belive VVT is very CPU-batch dependent and seams to get important when you get closer to your max-stable 24/7 OC, but not before that.
Anyways, does this mean that you haven't changed subtimings or other RAM/IMC settings
