My Temps are topping around 46/48. The voltages were gotten from a sample online. Yes, I have had only the CPU-VDD, CPU NB VDD, Dram and NB Voltage as set with the remainder on "Auto" from another example I saw. I have them at current setting and they work, but if you can give me lowers numbers to use, that's why I worte. I would like not to use more than needed if I am too high.
I guess I need to play with less voltage and see results? Have not tried.... but your getting me in the directions I am looking for. Do you think SpredsSpectrum stopped my unlocking CPU's 4th core? I thought SpreadSprectrum was for RFI interfearance and leave on if stable? Or are you saying too get a higher "Stable" result? My goal is not how high, but where is best for overall, as in tuned.
Thanks.... throw chnages to try at me. I didn't mention that I have ACC off also. 29/32deg at Idle. If I take HT Voltage to 1.4 I get 35/38deg Idle- high 40's load. I have used the HT voltage adjustment to get a more stable NB increase to 2436. Have not found setting for 2600ish that OCCT likes. I am not totaly clear on NB and HT settings for best performance. Yet current works great....
