i presume that the bios is in english?
Phil
Phil
final settings.
how much better or what is better from f3 to f4j bios?
and the same question phill asked if its in english
Damn if I could only get Easytune working on Vista64
Figured it was about time i did one of these fancy pics...
This was a quick OC tonight, no tuning done on voltages to find out what i actually need, memory timings not touched, etc, far from final!
http://img.photobucket.com/albums/v4...estar/bnch.jpg
It wouldn't work with a nasty old GeForce 6200 and no graphics drivers at all.
EasyTune works for me on Vista 64bit w/ 2x 4870x2 in CFX using Catalyst 8.12.
I spent most of last night reading all 30+ pages of this thread because I have the Extreme board and cannot resume from S3 sleep. At least one or two others in this thread have had the same problem - has anyone figured out what the cause is and how to fix it?
I had my first board replaced b/c two of the SATA ports went bad . . . but on BOTH boards, I could not get S3 sleep to work properly. Any ideas?
I'm using ex58-ud5, i7 920, and F4R BIOS, with 180*20, cpu 1.28v, qpi 1.28v, cpu/pll 1.84v, vdimm 1.58v,turbo on, ht on. all else default....
it runs well, prim95 also fine. memtest wen 2000% ok. but one small problem occurs when I was watching movies with this PC. After watching about one hour or so, the sound would suddenly went very small, and then came back normal. It last a few seconds. And this occured several times during the movie show. and then, it's fine again.
so should I increase some other voltages, say ioh, or some others?
BTW, should I test if the integreated sound card is stable or not, is there any specific test that I should run?
easy tune 6 doesnt work here either, thats with a 4870 1gb 32 bit vista, i tried to get it going last night again,
ive noticed there is a big difference in voltages needed between 1 hour prime , 5 hours prime 10 hours prime even 20 hours prime, and then even after 20 hours or more of prime , it still isnt stable enough to run 2 smp clients folding and ive tried small ftt and blend tests, thats with HT on and turbo on
Hey Freshy ..
I think you were onto something with these settings ..
http://www.xtremesystems.org/forums/...&postcount=657
I used exactly these settings & been priming for 90mins + now which is farthest I've ever got at at 4Ghz CPU clock .. lowest temps too ..
But I'm confused about your Vcore .. your later posts here are saying you had to up the Vcore to ~1.39V after BIOS updates ..
But then the link in your sig to 4Ghz settings show Vcore of only 1.328V (CPU-Z) .. back on 12-10-2008 ..
http://www.xtremesystems.org/forums/...&postcount=761
So what were you using for that test ? QPI/Vtt volts etc ?
Same here never got easytune or des working and tested every version possible, SP1 /SP2 but never got problems with S3 :D
