argh Rollback :D
argh Rollback :D
Intel Core 2 Quad Q9400
DFi LP DK P45-T2RS PLUS
Crucial Technology 2048 MB DDR2 Dual Channel
EVGA9600GTSC
High Power 1000W
Cooling: Dice
http://valid.canardpc.com/cache/banner/553497.png
CPU-Z: 4410 MHz
http://img27.imageshack.us/img27/237/valide.jpg
Pifast: 23.33
http://img27.imageshack.us/img27/9687/pifast2333.jpg
SPi1M: 11.69
http://img27.imageshack.us/img27/2196/spi1m11687.jpg
SPi32M: 11.46.50
http://img27.imageshack.us/img27/1876/spi32m1146047.jpg
On the P45-T2RS (none Plus) is the 1.18 vNB normal? I can't really test this out because it's my uncle's board and he lives 3000 miles away. My uncle never got pass installation after he reset the BIOS. This would BSOD during XP or crash on Vista/7.
Hi all,
I'm blocked at 585x6 Pi32M stable, i can't get it at 600x6 with my e8400 :mad:
made with TeamGroup9600
http://images0.hiboox.com/vignettes/...fc9d73e9c6.bmp
i find that my board is hard to play with, strap 400 doesn't want to work and more voltage does'nt help me
edit: Finally, i got it @600x6 after a couple of hours playing with GTL's and Vnb :)
http://images2.hiboox.com/vignettes/...f576b768a0.bmp
So the strap 400 is working well with Rcomp 3/3/1 ;)
Thanks all
Hi
Can Any1 Give Me GTL Setting For Quad Too Got Over 500 MHZ FSB
I Can Try But Dont Be Stable Over 500Mhz.... Just For Few Second And Then Crash Win
Seems This Tread Get In The Hell:D
Not Any1 For Helpppppp Guyssssssss
They are different for each separate board even with the same CPU on it, so start trying it :)
First post here btw, hi guys!
Few weeks ago i bought a E8600 Q822A435 and DFI lanparty DK P45 T2RS+ to see what its all capable off doing,
The DFI was a motherboard i needed to play with for a while to find all the sweet spots, and im sure i didnt discover half of all the settings yet.
Literally scared the :banana::banana::banana::banana: out of me when i found out of that Memory settings tab that was hidden, my god!
Anyhow, Receiving a set of D9's next week, so hoping to do some proper FSB testing then, in preparation of starting with Dry ice :) !
Also, think it has more potential, but need to lap my Ultra Extreme 120, temps are getting to high im affraid. ;)
http://www.thijskramer.nl/tweakersdo...cpuz-thumb.jpg
Max Mhz with 1,45 IDLE Vcore. booted @ 4600mhz, and setfsb right up to 500fsb!
http://www.thijskramer.nl/tweakersdo...0x10-Cpu-Z.jpg
Max superpi, havent done any tweaking at all, mainly due to the fact im not really in to SuperPi just yet, need to read up on some proper tweaking :) :
http://www.thijskramer.nl/tweakersdo...18-4950mhz.jpg
Cant wait to push it further!
thijs Wellcome And Great Resualt Man
Are U Stable In 500FSB?? What Use Cooler For CPU?
i forgot to mention it here :D
Biostar Killer :rofl:
http://valid.canardpc.com/cache/screenshot/567201.png
Validation
Hi ViViD, 10x500 was fairly stable indeed. rebooted it after 5minutes or so, to try a bit higher Vcore for SuperPi 5Ghz. but couldnt really get it to work somehow, ill invest some more time in it shortly.
Cooler was a Thermalright Ultra Extreme 120, with a Push&Pull Ultra Kaze 3000RPM, and a outtake Ultra kaze 3000RPM right behind it.
Going to lap it soon, the base is filled with groves and such, my guess is that there is poor contact between the ihs & cooler base.
Had 5100Mhz on 1,45Vcore but bsod'd right before i wanted to take a screenshot, needs a bit more voltage i guess ;)
//edit
fiddled around some more tonight, and with a tip of someone els i just threw the vcore on 1,35 / 1,36 in bios, same as cpu-z actually.
and got away with 4900Mhz SuperPi stable, very satisfied with it. Cant wait to try it with dryice or LN2!
Great FSB angoholic
R U Use Stock Cooling For NB?
Greetings!
Guys, I have the T2RS Plus and I have some trouble with the temperatures on the NB.
The ambient temperature is 27.6C and the NB's temperature idles @ about 52-53C going up to a dangerous 61-62C when I'm gaming...nothing fancy.
Should I change the NB cooling? Maybe a Thermalright HR-05 IFX SLI + 2 x HR-09 for the PWM? (i think they will fit)
These are my specs :
E8200 8x400 + Mugen 2 (+25mV)
2x2GB Mushkin 996580 @ 4-4-4-12
Gainward 8800GTS G92 + Musashi
Antec NSK6580 - not a great airflow, but ok.
/sory for my English :D
anybody like me??
i've got new cpu today - Pentium dualcore E6300 - 2,8GHz(10.5*266)
when i overclock with T2RS Plus - it's had something wrong
when i set FSB > 300 in bios - boot good - but in win - cpuz alway get 300 - and setFSB doesn't work anymore
EX: in bios - set FSB: 325 - boot okie
in win - it's alway get 300 - FSB :banana::banana::banana::banana: happen
then i try again
in bios - set FSB 350 - boot okie
in win - get 300 again - FSB still bs
and set it again
in bios - set FSB: 290 - boot okie
in win - get 300:shrug:
so wtf ???
need new bios ???
Hmh, did some testing & all. after i received my Team Xtreem double sided d9's i've so far came up with 595FSB, booting @ 590FSB.
Using 1.29VTT, 1.42NB & 1.32 +- Vcore. But somehow my system wont boot above 1.3VTT , and i have no clue why.
Sure, im on air, but 1.30VTT doesnt seem THAT much, or is it?
Using 200 core#0 and 100 core#1 skew, 3-3-1 @ adv. mem settings tab.
Perhaps anyone has a clue? due to the fact i think i need it in order to get 600FSB+ ^_^
Thanks!
Yoh guys,
tomorrow I will get my Q9650 for the DFI DK P45 T2RS Plus.:D
I am planing to run my system with a fsb of 450 Mhz or higher. Thatīs why I decide to set all three jumpers of the cpu fsb select from the pins 1 and 2 to the pins 3 and 4.
I will do that before I install the Thermalright IFX-14 because otherwise I wonīt have any room left to set the cpu fsb jumpers.
Is it o.k. to set the jumpers on the pins 3 and 4 before I havenīt even started up my system?
I don't think that you have to set these jumpers,
because i left it on 'CPU selection' on my board and there are no problem for clocking
@ Thijs > Did you try strap 400 ?
Mine Board Working In Auto CPU FSB Jumpers
Not Any Problem In 1 & 2 Jumper
Sorry What's Work Of Strap??? Can I Use For My Quad For Hich Max FSB?
400/800 yeah, regular 1:1 fsb/dram.
Just fails to boot with 1.30VTT , oddly enough..
Although i think it might be due to the other ram,
cant recall having that issue with my other ram,
but if i use those, i cant get to 600FSB :P
It's a set of Team Xtreem 2x1GB DDR2 800 TXDD2048M800HC4DC
@ cl 4-4-4-10 @ 2.1-2.2V , builddate jan 08.
I can't really tell you for a quad, you have to try ;)
but I would use 400 strap for hitting 600 MHz FSB with my C2D, It gives me more stability than 333 strap :)
Roughly; higher the strap, more relaxed are the chipset's timings...
But i prefer give you a thread which explains this well > http://www.thetechrepository.com/showthread.php?p=32
@Thijs: Hard to say. Maybe i would try to relax some 'timings' settings like enh. address/transmit. besides a higher tRD , sub's timings ... etc
ps: Sorry for my bad english :p:
VTT 1,3V is too much for 600MHz FSB. It seems that you did not get it :D Every VTT needs separate CPU GTLs and maybe a VRef as well.
This 615@prime were with 1,25V VTT. Of course every CPU and Board (even with same CPU) needs other combinations, but highest should be 1,28V with right GTLs. You could also try higher ones but that makes absolutely nonsense if you want to push FSB harder, e.g. if you use 1,4V for 600, then what would it be for 650? ;) You get me?
you're explaining this really well and it seems that you owned me :rofl:
So i completely agree with the fact that there are relationships between Vtt,Vnb and GTLs, it's not just so easy tuning them well :p:
