deleted
deleted
Got my rig finished today! :banana: :banana: :banana: :woot:
http://images.people.overclockers.ru/preview/86151.jpg
http://images.people.overclockers.ru/preview/86150.jpg
http://images.people.overclockers.ru/preview/86149.jpg
http://images.people.overclockers.ru/preview/86148.jpg
http://images.people.overclockers.ru/preview/86147.jpg
http://images.people.overclockers.ru/preview/86146.jpg
http://images.people.overclockers.ru/preview/86145.jpg
http://images.people.overclockers.ru/preview/86144.jpg
http://images.people.overclockers.ru/preview/86143.jpg
http://images.people.overclockers.ru/preview/86142.jpg
http://images.people.overclockers.ru/preview/86141.jpg
http://images.people.overclockers.ru/preview/86140.jpg
http://images.people.overclockers.ru/preview/86139.jpg
http://images.people.overclockers.ru/preview/86138.jpg
Thats a nice looking rig ^^ :)
i concur. well done!
My rig, crowded, but gets the job done:
http://i64.photobucket.com/albums/h1...ffJoens008.jpg
http://i64.photobucket.com/albums/h1...ffJoens007.jpg
http://i64.photobucket.com/albums/h1...ffJoens006.jpg
http://i64.photobucket.com/albums/h1...ffJoens005.jpg
http://i64.photobucket.com/albums/h1...ffJoens009.jpg
http://i64.photobucket.com/albums/h1...ams1/Joens.jpg
http://i64.photobucket.com/albums/h1...s1/Biff001.jpg
Yeah, I love the keyboard. Readings for each core :)
-Satan
Those fans are either strategically positioned or you have just lobbed them in there.
GFX, Ram and maybe pwmic
http://img65.imageshack.us/img65/2313/img0517ic0.jpg
One storage PC in chenbro RM414 chassis.
Spec is
Pentium D940
some 2gb ram
4 300gb HDDs plus one 80gb OS hdd.
The right one is my current main rig in Lian-li PC-626 case.
Its spec is in my signature.
http://img246.imageshack.us/img246/4602/img0519rq3.jpg
My trusty firewall appliance.
http://img246.imageshack.us/img246/7619/img0520tz0.jpg
And my backup internet connection. I plan to completely change its routers later on. But for now, those will work.
I only have a top pic of my case :)
http://corner.thuvienhoahoc.info/topX.JPG
islash that is a nice looking rig , great job . i was wondering if that case can hold dual psu , i ask cause i see yours is kinda sideways . thanks
heydo6
The PSU simply stands vertical. It isn't possible to but 2 PSUs... maybe only if you remake the case.=)
There is a downside.. Dust, hair and other particles normally build up on the floor. They will be sucked up and will eventually clog the Rad. Which means a weekly/montlhy cleaning will be needed.Quote:
Originally Posted by SlackerXL
Anyways.. when I built up my case I opted for something different. What caught my eye was a VERY old Compaq Proliant 1500 server case. It housed a Pentium 100MHz with 128MB of ECC EDO memory and a total of 20GB of HD space in 5 seperate drives.. so yes.. quite old. It was also beige and disgusting looking.
http://www.ci.ru/inform2_97/p30_pic2.jpg
So I opted to try and turn it into a newish rig. Wasn't easy.. damn case was some oddity.. wasn't following any known specifications (not ATX, AT, baby ATX etc).
http://img.photobucket.com/albums/v5...e/DSC01976.jpg
http://img.photobucket.com/albums/v5...e/DSC01982.jpg
http://img.photobucket.com/albums/v5...e/DSC01987.jpg
http://img.photobucket.com/albums/v5...023_resize.jpg
http://img.photobucket.com/albums/v5...022_resize.jpg
ElMoIsEviL
Wow... massive thing. Big work ;)
I think the first 15 or so pages where every single image is broken needs to be deleted or a new case gallery started. ;)
my comp will be up on this in about 30 days.
My baby @ Sask Place quite some time ago, figured I might as well post them, nothing has changed on it since then, it's the comp in my sig. custom phase change and a modified CM stacker.
http://www.seocc.net/Images/pics/show1.JPG
http://www.seocc.net/Images/pics/show2.JPG
http://www.seocc.net/Images/pics/show3.JPG
it's nothing special, but much cuting behind front and from right side :)
all air cooled and not planing to switch on water (maybe air+pelt later).
Its from page 29 but there was a disscustion about the orange vs yellow slots on the DFI Ultra-D.
Yellow slots "can" be fore BH-5 looks like the focus on which slots to use are totally dependant on your bios, there are many diffrent revisions for each bios and each one has a diffrent focus on ram.
I have the stock bios on my mobo and use the yellow slots and it works perfect with my setup, had my OCZ Platinum 1:1 DDR600 stable with tight timings on my opteron 146, and I currently run my Mushkin DDR500 at DDR515 totally stable both were in the yellow slots.
I never updated to a newer bios as the saying goes "if it aint broke dont fix it"
I have more pictures on my home PC of my rig, but now that I am at work I can only share some of the ones I had uploaded in the past.
Bear with the bad photo quality, my camera died on me.
http://www.photodump.com/direct/VciousXUSMC/new1p-T.jpg
http://www.photodump.com/direct/VciousXUSMC/new3p-T.jpg
http://www.photodump.com/direct/VciousXUSMC/new2p-T.jpg
http://www.photodump.com/direct/VciousXUSMC/new5p-T.jpg
http://www.photodump.com/direct/Vcio...frontnew-T.jpg
http://www.photodump.com/direct/Vcio.../sidenew-T.jpg
http://www.photodump.com/direct/VciousXUSMC/new4p-T.jpg
http://www.photodump.com/direct/VciousXUSMC/new6p-T.jpg
http://www.photodump.com/direct/VciousXUSMC/new7p-T.jpg
Some of the Mods:
installing a 120mm fan in the front, yes that was cut with a dremel /bow
http://i11.photobucket.com/albums/a1...MC/thehole.jpg
fans in
http://i11.photobucket.com/albums/a1...C/frontfan.jpg
moded that mesh front into this cool dragon
http://i11.photobucket.com/albums/a1...C/frontbez.jpg
final product: this cool turbine looking fan behind a dragon, at a later time I may actualy get a turbine fan off xoxide.com with the led's in it wich will bring it out even more.
http://i11.photobucket.com/albums/a1...nanddragon.jpg
More may be uploaded later inluding the 120mm fan on the top of the case that I moded in. I didnt take any pictures of when I had to mod the case for my psu as I was in a hurry to get it up and running and it was the last thing on my mind.
You can kinda see the many phases the computer went thru when I swiched out the psu and things, I dont even have a photo of the final product when I had got all the wires put away, you dont see any wires now except the fan I have near the pwm ic's and the black lights. All the psu wires are behind the hdd cage and hidden away looks nice and neat.
Just recently added the x-fi in there and its offically a FULL case the pump barly fits at an angle between the sound card and the hdd cage, while the video card is just above it. I love the case to death with its price and options but next time I may get somthing bigger.
I am very happy to say the case is finally done. The only thing left to do is prop it up off the ground, maybe put it on wheels, not sure yet.
but here it is !!
http://img.photobucket.com/albums/v6...e/P8291051.jpg
http://img.photobucket.com/albums/v6...e/P8291049.jpg
http://img.photobucket.com/albums/v6...e/P8271045.jpg
My start up switch.
http://img.photobucket.com/albums/v6...e/P8271046.jpg
http://img.photobucket.com/albums/v6...e/P8291047.jpg
I havent gotten a chance to mount my start up switch yet but, itll be done soon enough.
Also need to do more cable management.. but thats for another day.
what do you guys think?
P.S. This thing is HEAVY!!!
^^ that case must weigh 100 lbs, but it looks awesome.
I agree with you, a lot more cable management needs to be done but it looks like you have put a TON of work into it.
bravo dude
cable managment will do great
Yea nice rig man!
Brought my rad from outside of my case into it, and heres how it looks now.
http://upload.nickfire.com//files/1/...0003_thumb.jpg
http://upload.nickfire.com//files/1/...0004_thumb.jpg
Looks really nice. Loved the color scheme.Quote:
Originally Posted by NickS
Question: Does that fan cover/filter thingy restrict air flow? If not, where can I get those?
thanks
