OK race to 25,500 hahaha, I will have to use all my secrets of the jedi ;)
:lsfight:
Score 20045
3.8ghz x3 720BE 2140HT-2400NB
Gigabyte MA790FXT-UD5P
Kingston DDR3-1800 @ 1600mhz
1. 4850 660mhz-1200mhz
2. 4850 800mhz-1200mhz
http://service.futuremark.com/compare?3dm06=10179089
http://3800z24.info/Phenom/x3_720/x3...4850's.JPG
DFI 790X-M2R
PII X3 720 @ 3.7Ghz, NB 2.6Ghz (1.45V)
4Gb ocz @ 1066
3 x 3870 820/1200
Silverstone 1000W
lots of water
http://lh3.ggpht.com/_uo9kciAVieo/Sa...s800/19373.jpg
19613
Shader 2.0: 7634
Shader 3.0: 9280
CPU: 5565
PII 940BE @ 3915mhz
4870 (845/1100) x 4850 (650/1000)
DFI 790FX-M2R
4x1GB D9GMH @ 1160 5-5-5-12
http://service.futuremark.com/compare?3dm06=10170298
ooh i think you got 20k in that rig oese =)
yeh it was lack of time and that 4850 was undervolted actually because it belongs to wifeys comp actually xD
have to try again some time... when new bios for the m2r comes out ill try again..
Should be able to get even higher then 20k
4850 here CF
3DMark Score 20677 3DMarks
SM 2.0 Score 8227
SM 3.0 Score 9757
CPU Score 5688
http://service.futuremark.com/compare?3dm06=9813912
http://img3.imageshack.us/img3/6959/...6phenom940.png
mmh k perhaps i had af enabled in driver or something??
will redo that run..
Just did another run with CPU @ 4.1,,, Same setting on GPU
3DMark Score 20302 3DMarks
SM 2.0 Score 8116
SM 3.0 Score 9297
CPU Score 5879
http://service.futuremark.com/compare?3dm06=10063624
Honda, you should be pulling 22K plus at those speeds bud, something isn't right......I pull 22k+ with only 4.0.....
I agree, I am begining to catch you with my x3 720:p: try a run with only 2200HT
:confused:Edit: double post some how...
vinister please post link
I'll have to look into that.....something just isnt right
The chip will retard itself so to speak if it gets to hot, We found this out under LN2 ask MSI, I spanked him at 4.8g in cpu test when he was at 5.6+.
Also use default performance tab in CCC and do not lower mitmap, it hurts your score. Try dropping that HTT, even the Finland guys only used 2160, it doesn't help. If the card is clocked to high it will give you a bum score also, minor artifacts don't hurt, but there is a point in which they do lower your score.
Hope this helps you out.
Charged::: just wondering if I could get a GPUZ screen shot of your system. trying to figure out my problem here, only thing that I can come up with is that my PCIE isnt running @ 2.0, If you take a look at my post back on this page my GPUZ is telling me that my Bus Interface is running @ PCI-E 2.0 x 16@ 16.
Then looking at Chew's is has @ x8 2.0 :shrug:
Sure, let me get my Vista MCE box up and running for my wife's American Idle recordings :p:. I put 2 HD tuners in for her.
Here you go...
http://3800z24.info/Phenom/HD4850/gpu-z_4850s.JPG
*updated*
Hows this for a quick run:rolleyes:
Attachment 96031
PII 940@3838Mhz
Biostar 790GX128M
2xHD4850s@675/1050
