:slobber: nice!
with a epox 8kda3j 32M finally at 2,5Ghz...
http://manner83.bei.t-online.de/bild...i_16_07_04.jpg
:slobber: nice!
My new "lower frequency" 28sec........I did it once at 4408MHz and I'm trying to do it again......P4 3.4 EE :D
http://www.thelab.gr/images/Hipro5/P...417MHz_png.png
Nice Hipro5,
Thats fast for an EE:toast:
But you manage 4580 here:
Originally posted by hipro5
[mbot] hipro5 - 27 - P4 3.4GHz EE @ 4580MHz 269.4MHz FSB 1:1 Cas 2-5-2-2 [/mbot]
http://www.thelab.gr/images/Hipro5/P..._27sec_png.png
Thanks my friend......I'll HAVE to find an EE with x18 multi though for higher frequncies +4700...... :D :toast:Quote:
Originally posted by Tom Holck
Nice Hipro5,
EDIT : Yes I know but I'm trying to get the 28 sec as low as I can...... :D
P4 3.0C (NW) @ 3.75GHz
RAM 5:4 (Infineon 6A @ 200MHz CL2-2-2-5)
Asus P4C800 Rev.2
http://mitglied.lycos.de/d3r8is/superpi.jpg
S.pi 1mb result of my team (Pisa-oc-Team ->Italy):
http://leghorn1.altervista.org/immagini/AMD/31_s.JPG
S.pi 32mb
http://leghorn1.altervista.org/immagini/AMD/32_m.JPG
SAE, can you tell me how you can banch at that frequency with a FSB so high?:eek: :toast: ... many compliments:)
Have you done a Sandra memory?:slobber:
Regards
Hmm. Good mem, enough stable voltages, good board, good cpu :DQuote:
Regards
Thx :)
I don't do Sandra usually, but the last one I did got me around 4.13k ALU/4k FLOAT...
I have been trying win2003 server, but it dosent seem to help.
Win2k sp2
2700Mhz (270*10 1:1 2.5-2-2-6-12-15) - 32sek
Win2003server
2760Mhz (276*10 1:1 2.5-2-2-6-12-15) - 32sek
2740Mhz (274*10 1:1 2.5-2-2-6-9-12) - 32sek
Im using the 2003 Server Standard. Its on the 3in1 2003 Server CD. Im I using the wrong version?
I want 31sek... grrrr
Is that a clawhammer? if so you might want to tweak it up a little.. (http://www.blackviper.com/WIN2K/servicecfg.htm) eventually try running without any drivers loaded.. oh and perhaps around 40mhz more :)
Yes, its a clawhammer.Quote:
The 2003server is a fresh install (20hours). Do i need to tweak the hell out of it to make it faster than than win2k?
I will try the tweaks, tho.
This sucks.. i allways seem to be missing that last bit of performance :mad:
I'm very impressive SAE, your system is very power; i know that you're writing with Intakeem, and that you're giving him advice to improve our result, and increase our FSB, so thanks!;)Quote:
Thx :)
(Can you send me, maybe in pvt or mail (mhrgala@tiscali.it), some link that it shows OCP mod?thx!:toast: )
Have a look here... :DQuote:
http://www.xtremesystems.org/forums/...646#post393646
http://www.truextreme.com/forums/showthread.php?t=31166
I dunno if the OCP mod is what you want though. :shrug:
I cannot explain what makes my fsb this high... ram is really good, maybe, and I do cool all important areas IMO. Play with your additional (alpha) timings. Try different voltages. Different ram slots, change the slots for each stick to test what the stick likes best... and so on.
Pulled 31s earlier today. :)
http://home.no.net/comerade/pc/superpi31s2xs.png
Edit: made 31s on 10MHz lower CPU-clock...
Edit2: made 31s on 25MHz lower CPU-clock using another OS...
Ahh.
My best result so far
The mem can't go higher with only 3.0v. I need an OCZ booster to give it more.
http://img48.exs.cx/img48/592/SuperPi12.jpg
Also finally cracked 31 secs :D
2.9ghz and 37s :(Quote:
Originally posted by thesaucier
Ahh.
http://membres.lycos.fr/boblemagnifi.../superpi37.png
welcome to xtremesystems bob :toast: :D :banana:
Thank :D while waiting for the dod to be really in the ixtremmmmmQuote:
http://forum.hardware.fr/images/perso/markdavis.gif
http://www.myfavoritehacker.com/some...uperPi-51s.png
51s doesn't seem too shabby for a 1.5GHz Dothan notebook. ;)
why is CPU Z reporting 600 mhz?
As soon as there is no load on the processor... it drops down to the 6x multiplier to save battery life.
my best time at 3803MHz in air with my 3.0E
http://membres.lycos.fr/cpulloverclock79/33.jpg
Id like to see how the 2ghz would doQuote:
hum... still optimising (damn vcore is unstable... set in bios 1,7v but under load it adds 0,1v and sometimes after switching on, only 1,6v)
http://manner83.bei.t-online.de/bild...i_28.07.04.gif
