Huge clocks man, that really is a gem CPU :D
What Vcore?
Oh yeah, here's a new one for you guys :)
http://database.he-computer.de/Bilde...ftownscott.jpg
What Vcore?
re benched the main rig with the non standard BOINC client, made quite a difference in Dhrystone.
And with the screenshot this time.
Nice chip :D ;)
http://i2.photobucket.com/albums/y9/...incbench-1.jpg
E1200 Celeron Dual Core
Asus P5K3 Deluxe
Samsung HCF8@ 1600mhz 8-8-8-30
Vista 64 Ultimate
Boinc Ver. 6.2.28
2872 (Whetstone)
6478 (Drystone)
14.10.2009 12:13:55 Starting BOINC client version 6.10.13 for windows_x86_64
14.10.2009 12:13:55 log flags: file_xfer, sched_ops, task
14.10.2009 12:13:55 Libraries: libcurl/7.19.4 OpenSSL/0.9.8k zlib/1.2.3
14.10.2009 12:13:55 Data directory: C:\ProgramData\BOINC
14.10.2009 12:13:55 Running under account Ike
14.10.2009 12:13:55 Processor: 4 AuthenticAMD AMD Phenom(tm) II X4 B50 Processor [AMD64 Family 16 Model 4 Stepping 2]
14.10.2009 12:13:55 Processor: 512.00 KB cache
14.10.2009 12:13:55 Processor features: fpu tsc pae nx sse sse2 pni
14.10.2009 12:13:55 OS: Microsoft Windows 7: Ultimate x64 Edition, (06.01.7600.00)
14.10.2009 12:13:55 Memory: 3.75 GB physical, 7.49 GB virtual
14.10.2009 12:13:55 Disk: 74.33 GB total, 55.75 GB free
14.10.2009 12:13:55 Local time is UTC +3 hours
14.10.2009 12:13:55 ATI GPU 0: ATI Radeon HD 2300/2400/3200 (RV610) (CAL version 1.4.403, 256MB, 40GFLOPS)
14.10.2009 13:17:30 Running CPU benchmarks
14.10.2009 13:17:30 Suspending computation - running CPU benchmarks
14.10.2009 13:18:01 Benchmark results:
14.10.2009 13:18:01 Number of CPUs: 4
14.10.2009 13:18:01 2811 floating point MIPS (Whetstone) per CPU
14.10.2009 13:18:01 8384 integer MIPS (Dhrystone) per CPU
14.10.2009 13:18:02 Resuming computation
Win7 x64
BOINC 6.10.13 x64
Gigabyte MA785GM-US2H
AMD Phenom II 550BE unlocked to 4 cores@ 3.4ghz
Anyone know why this thread isn't stickied?
Core 2 Quad Q9550@3630MHz
8GB RAM (Corsair 1066MHz)
running latest stable Gentoo Linux (amd64)
2.6.31-gentoo-r6 kernel ;-)
3946 floating point MIPS (Whetstone) per CPU
16577 Integer MIPS (Dhrystone) per CPU
BOINC Manager says it's version 6.10.18 ;)
PS: looks like Gentoo is a bit faster than Ubuntu :D
16,5k integer? Holy crap... looks like Linux does beat Win in this bench. Curious to see the difference in actual crunching times
Hard to say if it's actualy faster or slower than Windows, cause I use this machine as a development box, so my RAC is probably not max of what this machine could do...
And because help conquer cancer is 32 bit app on Linux "wcg_hcc1_img_6.03_i686-pc-linux-gnu"
and not 64bit I guess Windows might be actually faster :mad:
Not much difference between VM (winXP) and win7.
Intel 980x @ 4.4GHz
http://img715.imageshack.us/img715/8638/980x4400.th.jpg
damn..... me want a 980x... 4.4ghz is awesome, on air or water? Nicely done man..
It's on water and runs in the mid 50's C while crunching. Shortly after that screen shot, I replaced the MX2 TIM with some Indigo Extreme and it lowered temps by about 5c across all cores! :D These new B batch chips really seem to fly on low volts.
this is what i'am using Only using 2 Cores since i am gaming also and if i'am afk i use the FAH GPU client since Boinc GPU Client doesn't work with ATI Cards.
http://i41.tinypic.com/malc3n.png
http://img515.imageshack.us/img515/1...kenfeed.th.jpg
Lol at file size... :devil:
http://imgur.com/fzUBO.png
OS X 10.6.3
BOINC 6.10.43
2.4 Ghz Intel i5 520M
4GB DDR3
2725 Whetstone
4505 Dhrystone
This is the only computer I trust to fold at 100% 24/7, it has a warranty for 3 more years. :)
I bet your 9450 benches a lot higher:up:
Indeed it does, but its quite loud and turns my room into a oven.
The i5 is snappy enough for a laptop.
Server 1:
Q6600@2.4Ghz, 8GB, 7.3TB RAID6
15-Apr-2010 00:30:15 [---] OS: Linux: 2.6.31.5-0.1-xen
15-Apr-2010 00:33:13 [---] 2412 floating point MIPS (Whetstone) per CPU
15-Apr-2010 00:33:13 [---] 7043 integer MIPS (Dhrystone) per CPU
Server 2:
AMD Athlon II X4 620@2.6Ghz, 8GB, 250GB RAID1
15-Apr-2010 01:28:34 [---] OS: Linux: 2.6.31.8-0.1-xen
15-Apr-2010 01:30:32 [---] 2258 floating point MIPS (Whetstone) per CPU
15-Apr-2010 01:30:32 [---] 7711 integer MIPS (Dhrystone) per CPU
Both running Opensuse 11.2 x86_64. All stock. I'll add a few more machines for the coming up 1 week challenge. :yepp:
Finally settled on a good speed/heat ratio for WCG! :up:
http://i279.photobucket.com/albums/k...tsettings_.png
BOINC 6.10.18 WinXP-32
Phenom II X2-550 Unlocked to X4
http://img101.imageshack.us/img101/8602/bionc3408.png
