Originally Posted by alexankius
I can tell you right now they won't handle much. Hooked up some Antec Tri-Cools and they were blinkin' like crazy. HAd to hook them up to standard 4-pin from the PSU instead. O.K I've had too many.......:toast:
Reset cmos and tried a stick of 5300 ballistix in slot 1 and BAM! post. Installing windows now. Initial impression: BIOS sucks :p:
I have a .45a panaflo on my CPU fan header and it's fine.
Great find, thanks! :up:Quote:
Originally Posted by Blauhung
wich cpu ? E6600/Xeon 3060 ?Quote:
Originally Posted by afireinside
http://sean.nickfire.com/core2redux/IMG_1350.jpg
:D
Trying to get clockgen to work now... Sitting in an antec 900 under a typhoon with a panaflo.
This is just an observation, first I will say that I am totally lost with this bios coming from my 680i and I have no clue as to what the hell I'm doing:fact:
I keep looking for things to disable in bios to get an overclock as I did with the 680i bios and then I remember a lot of the things were nvidia related.
Now no this is not an overclock like you guys are doing but for me its a learning experience. On my BX2 I was able to take my x6800 to 3.5GHz by simply bumping my multiplier to 13 and setting my ram to auto, I have not raised one volt on any thing:eek:
Now on my 680i this was not possible, I would not get into windows:fact:
I love this board and the only issue and a small one at that is with the intel desktop utilities sometimes it works and sometimes it just locks up:D
One other thing my ram is running auto @ 5.5.5.18 .21 405.5 MHz 2:3 its corsair 6400 C3D what would be recommend to spiffy it up a bit on manual settings:D
ishhhhhhQuote:
clockgen almost messed my board
Glad to see this worked....Quote:
did you go back and reset some memory timings/vdimm and add the 2 second stick?
why do you not like the bios?
Does a quad core work ok on this mobo...just considering future upgrade
Also, is it easy to remove HS on NB to replace it
This boards looks like a winner for me..should be able if my cpu(e6600 L628A266 supposedly will hit 3.6 from the guy I bought it from) is up to it..to hit 400fsb with my 10th anniv. crucial ram
Just trying to decide if the RD600 will be worth the extra money and wait..love the idea of digital PWM
Hi@all as a new member I say hello to all guys^^
So, as a noob in oc I want to ask if these settings are ok?
Board: Bad Axe 2 rev05
CPU: E6600
all @stock voltage:(1,145IDLE-1,235v stress--intel desk util.) FSB 340@3064
EIST:enable
Tower:Thermaltake 5fan + Scythe samurai(cpu fan)
Ram:corsair twinxms2 8500/1066 @ 667mhz4-4-4-2
temp:IDLE:38-40 under full load 65-67°
are these temp. too high or is it ok?
thx pushook:cool:
hi
could any one point out a link on how bootstrap 1333 1066 work
basically i have my system E6600 at 9x412 stable over night running orthos temps around 58 with a swiftech kit
my memory is Corsair Dominator 8500C5D
my question is in regard to the memory frequency i have it showing at 412 1:1 is there any way to increase this closer to the 533 my memory is rated and still maintain the oc stable, i read about the boostrap thing 1333 1066 but i have no clue on how to use or what is it, thank for any suggestions.
At 412 MHz FSB and a x9 multiplier, here's a table of memory speeds...Quote:
Originally Posted by juliotrespatas
Code:FSB CPU Ref Mem Ratio Mem DDR2
Freq Freq Freq Freq . Speed Speed
412 3708 333 800 5/6 495 990
412 3708 333 667 1/1 413 825
412 3708 333 533 5/4 330 659
412 3708 333 400 5/3 247 495
412 3708 266 800 2/3 620 1239
412 3708 266 667 4/5 517 1033
412 3708 266 533 1/1 413 826
412 3708 266 400 4/3 310 620
412 3708 200 800 1/2 824 1648
412 3708 200 667 3/5 687 1374
412 3708 200 533 3/4 549 1098
412 3708 200 400 1/1 412 824
412 3708 133 800 1/3 1239 2478
412 3708 133 667 2/5 1033 2066
412 3708 133 533 1/2 826 1651
412 3708 133 400 2/3 620 1239
I'm not running quad core, but others are and seem to be doing OK.Quote:
Originally Posted by nealh
The NB heatsink pops right off using just your fingers for tools.
I wouldn't think you'd have a problem with an e6600 at 400fsb.
Originally Posted by gtj
thanks
Almost forgot! My BX2 perfectly fine boots and POSTs with G.Skill rated at 2.2v-2.3v! With other boards I didn't have much luck unles I use chepo Kingstone 512MB stick to boot into BIOS and change ram voltage.
:welcome:Quote:
Originally Posted by pushook
When you overclock, you should always disable EIST
Your temps seems a little high, is temp are monitored via core temp?
how do you disable EIST on the BX2 i was browsing thru the bios all i saw was C1E and enhance power slope, thanks
It's on the power menu IIRC.Quote:
What bios are you guys looking at:confused: I do not see IIRC under power or C1E are you talking about the P5B??
IIRC = If I Recall Correctly
EIST is on the Power BIOS menu.
Having problems with Plat Rev. 2 in here. Everything else lights up. Just nothing turns on. Works fine in my other board. I guess i'll need to try some different memory then.
Working great here. Are you OC'd? have you tried 1 stick at a time?Quote:
Originally Posted by Reinvented
I haven't even gotten the board to boot yet. These Plat Rev. 2 sticks were reprogrammed since they didn't work in my Infinity board when I had it. If you look in Cpu-z, and your memory tab, tell me what timings are in the table. Is it 4-4-4-15? If so, it might be because of the reprogramming, which caused this.Quote:
And yes, 1 stick at a time doesn't do :banana::banana::banana::banana:.
Here's what's in the SPD table...Quote:
OCZ2P800R21G, 4F435A32, Week 38 Year 06
400MHz 5-5-5-15-22
333MHz 4-5-5-13-19
270MHz 3-4-4-10-15
Currently running at 412.6 MHz 4-4-4-15-19
Any of you guys on 2395 notice if the hard drive access light has been fixed when the secondary sata controller is disabled?
Another question: What is the difference between rev #'s on this board? My version of board is listed as AAD53350-502 in the IDCC so i assume that this means i am on rev 502? It was bought from newegg about 3 weeks ago so it seems like it was pretty old if this is the case. I see that people seem to be happy with their rev 505 boards so i assume this means that i got newegg'd and was sold an older version?
