what was your Vcore set to? :confused: (the asus probe tool always shows it lower...I had mine at 1.4875 and it shows 1.4)Quote:
Originally Posted by n91htmare
Maybe I should try 1.45 or lower and see if I can still run stable!
post if it works!! :fact: :hrhr:Quote:
Originally Posted by Random
CPU-Z always reads E6* volts wrong.
that's been known for a long time!
Mine reads like 1.2 v no matter the vCore until I hit 1.5v in BIOS, then it reads .05v low.Quote:
Originally Posted by Moonraker™
Mark
Bios 0711 released!! :)
guys, break it down to me....
I've tweaked my OC settings some more, tightened the RAM timings, and lowered the Vcore while remaining stable...all is well so far. I got the e6300 OC'd to near 3.2ghz using a Scythe Infinity +fan.
My problem is that I feel my temperatures are way too high.... 50C/57C idle/load! :confused:
Mobo also shows 40-41C
is just that I live in Florida and my house is usually around 79F ambient, or perhaps I have a bad mount of the Heatsink? :(
Is this normal?
ps- I'm running Vcore at 1.400, and Vdimm at 2.25v.
Ive just ordered one of these ot replace my P5W64 which reported stupidly high cpu temps.
Hope its a good one :)
P5B Deluxe is great. But it shows hight temps too. My idle temp with core temp is 40-41c. And 50-55c @ load! So it seems the 965 chipsets or, c2d with it shows higher temps, or something. Because i thought with C2D being 65nm and so would be much cooler, but at these temps its much higher than amd cpu´s.Quote:
Originally Posted by Devious
Does anyone have changelogs for the new 0711??
Found Here?!
Cool!! I'm interested in this too.Quote:
Originally Posted by HaZe303
idiotic question # 37436:
Is it wize to upgrade the BIOS via the Asus windows bios app? if so, will keep my OC settings, or do I need to restart and put them back again? :confused:
You can choose the program to clear cmos or not. But i recommend you do clear cmos when updating with Asus Updater. So yes then you need to set all settings again. But yes the asus updater works fine, you can use it with no worries. ;)Quote:
Originally Posted by ssabripo
Asus update works fine. You should always load optimized defaults after flash. Dont flash overclocked just in case...
Hello there folk´s.
I´ve got a small problem, my Board (P5B Deluxe Wifi) was pretested @530 FSB an my Cellshocks are pretested @ 1200, but my damn E6400 only reaches 400MHz with 1,45V and over 50 degrees...to much i think ;) The CPU is an E6400 with the Stepping L628xx My Cooler is an Sonictower@5V FGLLE Papst. Is there anything i could tweak or mod?
alright...just to make sure I dont FUBAR' it, I update bios in windows with Asus update, then load optimized settings, reboot, goto BIOS, and re-enter my OC settings, and then start up again?Quote:
Originally Posted by loc.o
Set stock clocks/load optimized def
Update, if done comp wil reboot.
Go to bios and load optimized def
F10 / reboot
Go to bios and set your prefs
Those are the steps i always take and it works fine.
yes :)
but go in steps to that frequency just tu be shure ;)
Doing this in windows I assume, right? Perhaps I didn't look hard enough, but I dont remember the app having a default loadQuote:
reload defaults after bios upgrade???:confused:Quote:
good lord! perhaps I should just use the Asus flash utility in Bios....more straightforward :p:Quote:
Bios 0711 changelog:
P5B Deluxe Release BIOS version 0711
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
running it now seems fine to me...:toast:
My volts set in Bios was 1.28... windows reads it at 1.24.Quote:
Which is still much lower.
A lot of people keep putting more volts into the CPU because when they fail orthos or other stress tests, they think it's the CPU and keep feeding it more power. When it could be that You just have an unstable FSB or Ram.
At the same time, these chips act very weird.
You may only need 1.28 to get to 3150mhz, but to get to 3200 you might need 1.45, that extra 50mhz might not be that easy. I will find out for sure once i get home and try it myself.
I remember when I had my opty165, i could 2.95 at 1.45v all day long... but getting to 3.00 was a different story even at 1.6V, by then i just got scared, never got stable.
hmmm batch L628.... :DQuote:
Yes its L628A (347) and vdimm was 2.35, typo edited.
Bios 0711 fixed the double restart/false start issue it seems. That's good, but otherwise it seems the same as before for me.
Mmm fixes that issue SWEEET.Quote:
Originally Posted by Dredd
I gotta try this during the weekend when I got a little more time.
what setting do you use for the pci-e? mine's locked to 101
