Multiplier issue with q6600 rev. g0
I searched and could not find an answer to this (on other sites too), so I apologize in advance if someone has answered this.
I recently replaced an e6600 with a q6600. My old e6600 was able to do 400x8 with a little extra juice (1.4v). The q6600 shows potential, currently running rock solid at 333x9 at stock (1.28v) with my 4gb dual channel sticks at tight 4,4,4,12 timings at 1:1. Unfortunately, I cannot even get close to 400 fsb because I cannot get the multiplier to change, meaning my DDR2-800 RAM is running at DDR2-667 instead.
I can set it down to 8 and save the changes to the bios, but as soon as it reboots, it resets back to 9. I strongly suspect it as an issue with the bios because I AM able to drop the multiplier to 8 if I leave the fsb at 266 (i.e. I can boot at 266x8 and have it stick), proving my CPU can accept a lower multiplier. As soon as I raise the fsb past 266, I get the multiplier issue where it self-resets to 9.
After doing a lot of research for a week and seeing some sites where members claim that any bios versions past 1707 have issues with dropping the multiplier, I tried flashing to 1707. Unfortunately, since I have a more recent rev. g0 of the q6600, 1707 does not recognize the CPU and gives me a microcode violation. I can go past that, but that issue is annoying itself.
So I tried bios versions past that included 2206, 2704 and 2801, with no luck.
I have all the fix settings suggested throughout this thread otherwise (i.e. look on the very first post, and it is a mirror image of what my bios are set to). So I am not sure what else could be the issue other than bios itself.
Am I out of luck?
