Amen! :clap:
Drivers:
- Intel Chipset 9.4.0.1026 NEW!
EXE & ZIP formats
These drivers are unnecessary if you're running Windows Vista or newer as they contain all necessary chipset drivers for our board. If you would still like to run Intel's drivers, you can update Intel system devices through Device Manager by pointing them to an extracted installation directory of these drivers, but I don't think there is any benefit to doing so. You can also run infinst_autol.exe /overall to do this automatically.- Intel Rapid Storage Technology 10.8.0.1003
Setup download | Floppy (driver only) download
32-bit and 64-bit floppy files for use during Windows XP or Server 2003 installation, or for manual installation through Device Manager on all versions of Windows: here
These drivers are only necessary if you're running the onboard Intel storage controller in AHCI/RAID mode (see here to enable AHCI if running Windows 7 or Vista). This version of Intel RST is the final supported version for the abit IP35 Pro due to its use of the ICH9R chipset, which Intel has deemed obsolete.- Realtek 8110SC PCI Gigabit Ethernet Controller NEW!
While this points to the PCI-E-based NIC driver, this driver is newer than the one found on the 8110SC page and works without issue.- Realtek High Audio Definition R2.73 for Windows Vista / 7 / 8 / 8.1 32-bit NEW!
- Realtek High Audio Definition R2.73 for Windows Vista / 7 / 8 / 8.1 64-bit NEW!
- Realtek High Audio Definition R2.73 for 2000 / XP / 2003 NEW!
- JMicron JMB363 Storage Controller R1.17.65 WHQL
Utilities:
abit IP35 Pro motherboard & uGuru manual
Click here for my latest BIOS compilation, which improves compatibility with SSDs.
The latest BIOS compilation is still current. Neither Realtek nor JMicron have released new option ROMs, and Intel dropped support for the ICH9R chipset in their Rapid Storage Technology ROMs ages ago so the ROM 8.5.0.1030 and the driver 10.8.0.1003 WHQL are the final versions which will work with the abit IP35 Pro.
