Originally Posted by
Ace-a-Rue
generally that is a memory problem...a couple of things you can try is to raise your Vdimm and/or loosen you memory timings.
if that does not work, also raise your vcore, ICHIO and MCH.
why don't you post your set voltages.
i do see that you have four sticks of memory...overclocking becomes more difficult in that configuration...generally the cure is to at least raise Vdimm, ICHIO and MCH....do it in small increments to see if that solves the problem.
i will be gone for a week so someone else can give you a helping hand to help you solve this little problem-O;)
