rev 1.04G able to set low Vcore in older BIOSes
Can anyone help me. For some reason whenever I have my usb cable plugged into my pc from my printer my pc takes an extra minute or two to boot or sometimes it does't boot it just keeps checking on the usb port, anyone know how to fix this thanks
I was interested on buying the Q9450 but I saw here the vcore setting problem.
So I looked at my board revision which was 1.02g.
Then I went into the bios. Its version 2602. I entered the manual vcore settings and I discovered that I was able to select from 1.225v and above.
Look at the screenshot:
http://img399.imageshack.us/img399/286/07082008gm7.jpg
So Im able to put a 45nm processor on?
Ah, so I m able to see voltages below 1.4 now with a 65nm prossecor but when I put a 45 the problem will appear?
I have an E8400 and am able to set voltages from 1.225 and above.
Ah, well, I guess since I have the 45nm problem I'll have to go ahead and flash to 2801 to see if it continues or not. I'll aim for Saturday.
The next motherboard will NOT make me pull the battery. Don't care what features I miss out on. Putting my foot down now...
I'm not getting anything but AUTO, no matter what I disable. I checked the manual but it's way out of date now: what's supposed to be disabled to get multiple vCore values to pick from?...
Don't you have to set the cpu settings first, and then save and exit BIOS, before any manual settings become available? That's how I remember it always after every BIOS flash...
I thought I'd saved and exited several times, but now I go back and look and the manual range of vCore is available again but is still 1.45V through 1.7something.
Virtualization is also something you have to choose early after a flash: I can't touch it now.
So either the message about voltage problems isn't getting through, or they just think the early revisions have been replaced by now and refuse to support them properly. I'll have to call in to the folks who supplied BIOS chips before and see if they can transfer me to somebody who might help talk to the BIOS group...
Post above yours shows it finally did allow manual...
guys I got a 8800gt a couple of weeks ago and noticed the slow bios problems others pointed out, I did some research over the last day or so and initially thought its because this board has pci-e 1.0a slots which apperently are not very compatible with the 8800gt pci-e 2.0 cards. My 3d performance is fine, 2d performance in windows seems slightly slower than my 7600gt was. But it seems there is some kind of generic problems with all the 8800s on this board in the bios? even the pci-e 1.0 versions. Its not a major problem just bit annoying browsing the bios feels like I am on a 386 but at least I can see the post now, before it was too fast as my tft doesnt adjust fast enough.
hey guys, i have a 45nm processor (E7200) with a p5w dh deluxe rev 1.04g and i'm not able to modify the vcore, it just says AUTO, and nothing can be done :(
i've already tried all the posible solutions, i flashed the bios twice, from 2602 to 2704, and later 2801 :mad:
if someone find the solution please help!!
thanks!
Ok, after a week talking with asus technical support, they answered me this:
The problem was notified to our engineers, please be patient until the fixed bios will be released, you'll be able to download it from the ASUS support website, thanks!
What shows manual voltages is making sure the speedstep stuff is disabled, and setting up the CPU configuration and saving/exiting BIOS at least once. You can never set manual voltages right after a BIOS flash, ever.
