Originally Posted by
Zucker2k
I think both your nb and cpupll volts are too high for that overclock. You'll be surprised, but I'm sure even all auto settings would give you lower volts and still stable.
First off, run on the 333 strap, set both gtls to 67, advance both DRAm clockskews to 300 each
Set PL to 8
Too high vcore can also become a problem but you should generally add .40v for that 400mhz difference between 3.2 and 3.6ghz.
I'll set pll to 1.60v (real), check hardware info section in bios
NB to 1.55v
Run ram 1:1 so 900mhz 5-5-5-15 (you can tighten things later) set full max recommended volts too; test later with memtest if you're still having problems
Hopefully, this is not a cpu wall. remember, not all chips can do 3.6ghz stable. Goodluck.
