Repair Disk in Window 7 on SSD
Hi, just ran into an issue I hope you can help me with. I created a repair disk for windows 7. I want to make sure it worked. To test it I went into my bios and set SATA CDROM as my first boot devise. I saved the changes and tried to boot form the disk. It went strait past the disk and booted form my C: drive. After 4 attemps, for the hell of it I tried booting from my floppy, after changing the first boot devise and it worked. It immidately took me to my A: prompt.
I have two DVD drives on my system, both four years old, one is a LG and the other a lite-on. Both work fine during normal operations. The resent upgrade to windows 7 was via one of these DVD drives. All my drives are running in AHCI mode and my bios are 18.zzz.
I normally backup my hard drives with Acronis. If you can boot via a DVD drive the backups do not do me much good. Am I missing something obvious?
Thank you for the help.
ANY BIOS > #14 yields problems/issues
I have an IP35-Pro, Q6550, 8gb (4x2gb) OCZ PC2-6400, 5 sata drives and 2 DVDs, plus the stock stuff. It came with, and I am still running, BIOS #14. I have been running Windows 7 Ultimate 64-bit for some time now with no problems. Now I just ran into a problem! I wanted to install/use Windows XP Mode/Windows Virtual PC. When I went to install it, I got a message that "You cannot install or start Windows XP Mode or other virtual machines in Windows Virtual PC if hardware-assisted virtualization is unsupported or disabled in Windows 7." There appeared to be no place in the BIOS to turn it on.
So I downloaded and installed your latest BIOS compilation; 18ZZZ. It gave me the virtualization parameters, but gave me THIS problem! I cannot use 2 of my 2gb DIMMS in slots 2 & 4. 1 & 3 work fine, and run in dual mode like before. I even went so far as to test several different combinations of sizes and configurations, using either one or both of matched pairs of dimms, in sizes from 256mb to 2gb (all OCZ). Either as single, or dual, only slots 1 & 3 will not give errors. ANY dimm into slot 2 or 4 yeilds startup error (beeps and a tight loop of “83–90–98–99”, turns off, then on after about 3 seconds, and tries the same. Over and over.
I also tried every other BIOS available past #14. ALL yield the memory issue, and only 18ZZZ fixed the virtualization issue.
So I went back to my stock #14 BIOS, and am now running as before, with all memory, but no virtualization.
Any ideas/help you can provide will be GREATLY appreciated!
