My room temp was 23C!! That's not fair at all, LOL!
Kinna late for the party but is this the right Processor??
http://www.monarchcomputer.com/Merch...ory_Code=amdop
That would be the 940 socket version...
So any U.S. Site have the 939?? Thanks for the head up
Let us know if you find some... Mine has been backordered for days now.
Ok, some early results from my 146 CABNE 0530APMW.
I am on a msi neo2, which seems to undervolt and has very inconsistant voltages. They bounce all over the place.
I have done 32m @ 2800 with 1.392v
32m @ 2900 with 1.456v all of these on zalman 7700cu
1m @ 3006 with 1.536v.
My 32m runs At 3006 fail a little more than half way through. Not sure if it is temp related or what.
I don't want to push any more temps/volts through this chip until I can get better cooling, or until my room temp cools off. 72degrees F in my room now.
This is by far the best chip I've ever had. I feel I could be limited also by my psu. It is a generic 450w that came with my case...possibly my next upgrade.
Maybe after some burn in and settling of the as5, my results will improve.
Also, I am really still a noob, and don't know all the tricks yet!!
Finally got around to doing some 3d work with this 148 -
3dmark2k1 - Compare link
3DMark2k3 - Compare link
Good 2k1 score! I'm trying to get to about there with my 7800GTX and on watercooling!
Looks good. I think 2k1 is my favorite bench but anymore it makes me feel bad that I can't even get within 10k of the top.Quote:
Originally Posted by HermS
Anybody wanna sell their opty? :)
Originally Posted by Deus Falsus
check the sale threads we arent allowed to talk about stuff like that in here :fact:
perc,
Now i´m testing at 16,5C Roomtemperature!
2850Mhz at 1,26Vc and Prime Custom FFTs in place 15Minutes 8-4096.
Heres the Screenie. Prime is running since 1h30Min. Load is 38-39°C.
Cooling is on Air with an XP90 Alu and an Thermaltake blower+ an 120mm Blower right before to get low Temps. By an opened Case. :banana:
http://img398.imageshack.us/img398/1...mfftsip.th.jpg
When winter comes, you'll be able to do 1.20v. :DQuote:
Originally Posted by Rufus7
I can't wait either...I'm hoping mine will do 3.3 on water with some 5C ambient....except my keyboard has the cold bug so I won't be typing anything :slapass:
Yeah but thats too cold für me.Up to 15°C its not too cold for me.Quote:
Originally Posted by dogsx2
After 2hours Prime Custom i´m gonna raise the clocks a little bit higher at same Vcore. Wanna reach 2900Mhz at 1,264Vc on Air.
Heres the Screen after 2Hours Priming at 2853Mhz by 1,264Vcore.
http://img282.imageshack.us/img282/2...me2h8al.th.jpg
Now i have 2883Mhz at 1,264vcore an Prime Custom FFTs In place is still runnig. Nice Little Screenie here.Now Rt is by 15,8C.
http://img195.imageshack.us/img195/5...h36m4rf.th.jpg
And i´m pushing it up to 2900Mhz in a few minutes.Maybe more.
the 8c hard drive piques my interest :toast:
those are some sick clocks though... i'm quite envious. i can't wait till i finally dig up the money to buy that 146 from vandi :)
Put back in bad dfi mb and got this on air w/bt, room temp 24c load temp 42c. Another new board coming this week, hope it last longer then last. I'd sure like to have the mb ozzimark has, how bout it??? :D
http://img130.imageshack.us/img130/4...30708ac.th.jpg
You were just plain unlucky when it came to your 144, maybe you should have taken the shorter box. :D My 144 runs almost the same as the 146, may run the same as I haven't done much benching with a bad board. The 144 will do 3000@1.4v and the 146 takes 1.45v. I still think the price/performance is in the 144. I was just blessed to get two good chips.Quote:
Originally Posted by ozzimark
If you want me to try out your mb to see how your new 146 will do, I'll fit it into my schedule. :)
the mobo is out of my hands. it actually died, thus an RMA :stick:
i'll be sure to play with the 144 in the new mobo, just to make sure the old one was wasn't messing with stuff. the large difference between max 1M and max screen, despite the low temps perplex me.. and the troubles with memory over 2.5-3-3 timing :nono:
either way, everyone will know what the deal was once the board gets here
And thats the Result of the Session tonight at Aircooling by Rt15,5°C.It was only for 2Hours and 11Minutes stabele at Prime Custom FFTs in place.
3000Mhz by 1,360Mhz Stockcore.Thats Idle Temp by 15,5°C RT on the Screenie. Load was between 42-43°C.
Heres the Screenie:
http://img384.imageshack.us/img384/7...1min3ld.th.jpg
And Suicides up to 3050Mhz at Stockcore!
http://img289.imageshack.us/img289/3...cide3ly.th.jpg
Raised Vcore up to 1,376Volts Prime Custom must be stable for longer than 2 Hours.
can anyone tell me some 144 good stepings? looking for 3ghz atleast 1,55v :S
btw some of 144 are venus and sandiegos? :s why u all guys geting 146 ? BS i dont have extra money to buy 146 :p:
Opteron 144 CABNE 0530APMW are really good for 3 Gig or 146 Opteron same Stepping.
http://users.skynet.be/pt1t/144/SPI32M_2901.PNG
This CPU likes High Voltage :D under Watercooling , With HIS and Without ICE , Room Temp +- 23°C
whata kind of sh** :( what steping is that?
And here some Pics from my System Config tonight.Only taken by a Webcam.
