Originally Posted by ***Deimos***
I certainly hope thats with LOD and high performance in the driver. After about 380-400, my 6800 becomes very bandwidth limited, and thats with memory running at 900, 950, or even 972 (after voltmod). Go figure. With core only at 375, the GT runs memory at 1000, and Ultra with core at 400/425, memory at 1200.
for everybody who is only getting 800's with 2.2ns Hynix
get NIBITOR 2.8 from mkvtech
you can test timings in windows without flashing!!
for 900+, I found I MUST have tRCDRD=6 and tRP=6.
Intructions:
1. Tools-Read BIOS- Select Device-OK
2. Tools-Read BIOS- Read into NIBITOR- OK
3. Go to Timings tab, and click autoselect to change to proper timingset- ok
4. click detail timings, and you will see your timings.. make changes as desired. When you click ok, you will notice, that the Timing0, Timing1, Timing3 have changed. Write these down!
5. Back at the Timings tab, Click test timings, get timings, and insert the values you wrote down, click set timings, and go run atitool artifact tester (highly recommended) or some other benchmark.
EX:
Timing0: 060C1512
Timing1: 05010307
Timing2: 00240306
correspnd to:
tRC=18
tRFC=21
tRAS=12
tRP= 6
tRCDRD=6
tRCDWR=3
tRRD=4
