not sure but alll i know anything with 0447 is good.....i have that stepping....able to do 2.52Ghz 1.4vcore prime stable
http://sapmig.no.sapo.pt/30.JPG
Stock cooler.
A8N-SLi
PDP 3200XBLK (TCCD)
sapmig Nice overclock! :P
what is the week?
My 3000+ cbbhd 0449 gpgw -> BOX AMD -> Tower outside 0°/-1°Quote:
Originally Posted by K32A
Max superpi (1.7v bios)
http://www.membres.lycos.fr/boblemag...superpi29s.PNG
Max screen (1.7v bios)
http://www.membres.lycos.fr/boblemag...ie@2885mhz.png
max stable 2650/2700mhz a 1.7v i think
boblemagnifique - Thanks alot!
Thats an great oc, looks great! Maybe i'll buy one of those ;)
for me this cbbhd 0449 is average, my 3200+ cbbhd 0447 tpew do better (stable 2600mhz has 1.4v, max benchs has 2981mhz has 1.65v with the box amd ) but good there is worse, now i await one 3000+ cbbhd 0448 spaw (best the step of the 3000+)Quote:
Kueller,Quote:
Originally Posted by Kueller
I have a very similar setup, but can get my voltage anywhere near what you run your cpu at( I'm higher ). What is serial on motherboard. I'm thinking 0440 just need more juice. Also what Fan do you have on you XP-90? I'm running 1.36B Bios. I have tried lower voltages and just am not stable 100%
My memory also has about the same limits 2.5-4-4-10 at 282. Oh what are your A64 settings for 183Mhz.
Gack ZipZoom, sold me old stuff and here I bought in Dec. I firmly believe new steppings and serial on CPU and Mbd are key to getting higher OC with lower voltage.
Kevin
Originally Posted by boblemagnifique
Yeah, we all want the 0448 SPAW :D
yes I have to seek during a few weeks and a friend will take some tomorrow, one will vera what that gives (some are good and different average = 2450mhz stable max has 1.4v and different 2700mhz stable max has 1.4v, it is the lottery these winnies :(Quote:
my its cbbhd 0450spbw
I´ve got one cbbhd 0450spbw also. I´m waiting for MB, if mine overclock so well like Yours, i will be very happy and we ppl can rely on sttepings. If not, i think we must stop thinking about sttepings, at least for these A64.
Replacing my 0437 with a 0450 was the best thing I've ever done. The week 50s seem weaker than say 47-49s but they are still doing 2.6-7. When I got my first winnie(the week 37) I said I would be happy with 2.6 and it wouldn't do anything over 2.5 but my week 50 has made me a very happy camper!
:toast: :banana:
Man,
My Winnie can seem to get that high on that low of voltage. have a 0444 on 0409 Serial Neo2. I end up needing 1.525+15% to get 298Mhz. Wonder If just luck of draw or need to reapply AS5 compound or I just cranked it up too soon after getting. Gack I wish I could use less voltage.
TheMeatFrog, what settings do you have your memory at?
It's running with a 166 divider at 250MHz 2.5-3-3-7 timings w/2.75v.
ahh, ok. That is what I am running now. What bios ver. you using? Trying to find other with Patriot memory is tough. Been looking for A64 Tweaker settings that seem to work well so don't have to reboot alot (lazy :D)
so, today i get a 3200+ winchester 0447spaw:)
had anyone here some oc results with this stepping?
0447 is good step :toast:
some oc results????????
my 444xpew is benchstable up to @2,7ghz with 1,7v
I will get the 0501 FPMW. A good stepping/week? never see this week and stepping on XS, must be a very new one.
This CPU will be first on air and then Mach 1 R507. :)
Just one month old :) wish ya luck. What is written after the week?Quote:
Originally Posted by kakaroto
CBDED, unknow to me :PQuote:
Originally Posted by $0m#0n#
do i become xtreme?
i reached 2810 mhz with "just" watercooling (all own made)
i've got screen from 2799 and 1.6Vcore (just to be sure i can manage 2.8)
http://users.telenet.be/jortcollijn/kaboem.JPG
then i tested the max fsb of my mobo.
could reach 335 and 345 was bluescreen :p:
http://users.telenet.be/jortcollijn/screen1.JPG
My 24/7 settings HERE.
1,77V? What cooling do u use?Quote:
Originally Posted by CP-Geek
