There was? Damn, I missed that....could have used one of them. :mad:
Instead using a Bitspower 5.25" res that has it's top port at the lowest point at the top. Works fine otherwise, but makes bleeding such a PITA :cussing:
Yep, here's a few images I was able to dig up on short notice. The yellow thing in the first one is a spinner.
http://www.xtremesystems.org/forums/...3&postcount=16
http://www.xtremesystems.org/forums/...9&postcount=77
I hope that spinner isn't included. I'm not certain what you would do with all those ports though. :shrug:
I want a water to water heat exchanger!!!
I don't care if its plate-frame or shell tube, but all of these reservoirs with multi port capabilities are just begging for it. While I'm tossing around a wish list, have the ability for the water to water heat exchanger to take TEC's and an intergrated PWM controller. :) We're getting closer and closer to running psuedo condensor and evaporator style loops.
Maybe they should experiment with a 6 port triple loop though? or would that be moving past the efficiency range of the D5 to the point that its struggling like me on my army run tests?
That would only be beneficial with really, really restrictive subloops (unfortunately). I think the 'ideal' point with a D5 is somewhere between 1 and 2 subloops...but of course we can't have non-integer quantities :p:
If done right, something like an RD-30 would be killer for parallel :slobber:
I actually HAVE run a three loop version lol. It works just fine but I think the plumbing gets a bit crazy at some point...it is pretty simple to convert the T3 into a three loop version to tinker with.
On the 8 port, no thank the stars Brian decided to 86 the gay little spinner propeller thingy lol. The 8 ports do come in handy for some projects, but most of the time the extra ports are so people can put the line exactly where they need it, and then populate the rest of the ports with LED plugs to amp up the light.
Here is a nice little accessory for the 8 port T3.
http://www.bods-mods.com/Trident/LED1.jpg
It is a tiny 20 station LED driver board that plugs into a standard molex. It has 2 pins for a switch if you want to add one.
http://www.bods-mods.com/Trident/LED4.jpg
Makes short work of the tool free LED plugs included with both versions of the T3. They sell in a little open topped black and UV case and come with 24" prewired LED's. Should be in retail in the next week or two.
Thanks to Boddaker for the pictures which are from his current project, Neptune's Trident. You can find his work log just about anywhere quality builds are showcased. He is also one of the modders in the ION contest.
ALMOST VEGAS TIME BOD!!!!
moddersmart sucks for RMA returns that is all so now they are on blast
I linked your post to Mel who oversees customer support for ModdersMart and PrimoChill and she said if you can provide her your ticket number she would be happy to see what is up with your RMA. You can PM me the number and I can pass it on, or call their support, or use the contact feature in the ticket system.
Phone is fastest.
Hi just curious, any new products coming in for the T3?
Anyone know where I can purchase the 2x LED that comes with the T3, the ones from first run or jab-tech maybe only came with blue, don't think there were option for UV. I see UV as an option on the primochill website under the drop down menu, but in the accessories section for separate purchase.
PrimoChill's site gave you the option of what color LEDs and Comp fittings you wanted with your T3. It seems most other places didn't.
Here are the LEDs, though I don't see any UV ones there.
Face plates shipped TODAY!!!
As far as I know Brian ordered 100 face plates split to 10 polished/chrome plated 40 brushed anodized silver/clear and 50 brushed anodized black. I do not know if or when he will order more as I can't imagine they are making much off of these or which resellers are getting them...US only or if there will be any going to the EU etc. The point is if you want one I would order it as soon as you see it for sale at your favorite reseller.
I sent a black and a silver bay cover from Lian-Li and the manufacturer assures me they can match the look very closely.
I am already hounding Brian to get me at least 2 of the black and 1 silver to give away to some guys in here that have already asked for a sample but he did not commit one way or the other so we will see. He said modders Primo sponsor get first dibs...
There are also metal compressions for the T3 coming as an option.
Wonder what shipping would be all the way to Singapore? Might be cheaper if I just got on a plane and delivered them...cept my wife would want to go.
I desperately need one of these in black. I hope they will be offered in Europe. Is there any way you can find out for sure which resellers are getting them or at least whether or not they will be US only? I will order from a US shop if I have to.
Is this fine to use with a single CPU loop? Or is it more suited for dual loops only?
It will work just fine in a single loop. It is designed more for a dual, but you can see skinnee's review here, it held its own in single.
I will ask again but I doubt he even knows yet himself...
Yes there are metal barbs designed specifically for PrimoChill parts. There will also be metal compression fittings out soon as well. Something a LITTLE different (what else would you expect from me lol)
http://www.moddersmart.com/en/primoc...ng-2-pack.html
DB just got his Polished aluminum face plate in the mail today. He was kind enough to drop it into his current Trek Away Team Case build and grab a few pics.
http://img140.imageshack.us/img140/1260/dsc01830ajm.jpg
http://img513.imageshack.us/img513/8645/dsc01829k.jpg
He hasn't had a chance to crack the center pod open and adjust the T3 a bit deeper into the case yet so the face plate is a tad high, but you get the idea of how much better a face plate with depth looks compared to the typical flat faced "2D" type.
Not sure where his work log is at XS but it's a cool build worth checking out ;)
It has 2 full systems with 4 fold out displays. Both systems (so 2 CPU's and 2 GPU's) are run off of a single PSU and a single T3.
DB...sorry man but I can't resist.
For those that don't know the build is sort of a portable engineering work station used by SCE away teams (Starfleet Corps of Engineers) which is analogous in the Trek verse to the Navy Sea Bee's or the Army Corps of Engineers.
SCE away team engineering stations...built for engineers by engineers. They can interface with unknown alien ships systems, regulate anti-matter injectors, and replicate virtually any engineering parts needed for emergency repairs--including self sealing stem bolts. If you smell something burning do not panic as it's just the built in three slice toast replicator.
When are the T3 face plates gonna be ready for sale?
They have already shipped from the manufacturer and should be in the US first of next week (say the 7th) and should be off to resellers by the end of the week. So short answer is pretty soon.
