I doubt you see any difference at all by switching to the other x16 slot :up:
The E759 can run x16 in the top 3 PCI-E slots, because it has the NF200 chip, which provides extra lanes. The E760 doesnt have the NF200 chip, so you are limited to:
Slot #1 x16, or x8 if slot #2 is occupied
Slot #2 x8
Slot #3 16x, or x8 if slot #4 is occupied
Slot #4 x8
This might have come up already, but with 31 pages of thread I'm not likely to find it.
Is anyone else having issues with dropping RAM in Windows? Seemingly at random, I'll boot into Windows to see "6.00GB (xGB usable)" in System Properties, and games etc. only have access to that reduced amount of memory. CPU-Z and every other utility I've tried shows the full 6GB, but Windows only thinks that lesser amount is "usable". I can get it to see the full amount rebooting a few times or by swapping around the DIMMs from slot to slot, but the problem just reoccurs with the new configuration until I swap my RAM around again. I've tried Memtest, which passes, and boosting vTT and vCore hugely, but it doesn't seem to do anything.
This i noticed, maybe not exactly the same, but there is a setting like the old "aparture" setting, atleast in my DFI there are, should be used when having SLI or so, dedicating more memory for the graphics, I once noticed in win 7, it showed 3GB, 2GB usable, wtf? well then "lowgap" was set so it was dedicating 1gb for graphics......i lowerd this, and its back to normal..... dunno bout the Classy? or perhps its not your problem at all :) seen some strange behaviour about this on all board, RAM not showing, or even working as it should, CPU mem channel problems? think some have fixed this by changing either mobo or cpu.
I had this happen on the Blood Rage & the Classified 759. Once was too much pressure on the the CPU by the WB & the other was to re-seat the processor in the holder. There is a little play and re-seating it dead center did the trick for me. Hope this helps, :D
anyone else get dead link when trying to update bios.
need some help,
im getting BSOD : IRQL_NOT LESS_OR_EQUAL
trying to get it stable @4ghz
CPU Clock Ratio : 20
CPU Host Frequency (Mhz) : 190
DRAM Frequency - DDR3 - 1451MHz
eVGA VDroop Control : Without vDroop
CPU VCore : 1.275V
CPU VTT Voltage : +75mV
CPU PLL VCore : Auto
IOH PLL VCore : Auto
QPI PLL VCore : Auto
DIMM Voltage : 1.60V ---> 1.65 bios reading + e-leet
DIMM DQ Vref : +0mV
IOH VCore : 1.200V
IOH/ICH I/O Voltage : Auto
ICH Vcore : Auto
VTT PWM Frequency : 250 Khz
CPU PWM Frequency : 800 Khz
CPU Impedance : Auto
QPI Signal Compensation : Auto
everything els is on Auto
EDIT:
At first glance, I'd recommend boosting the VCore a couple notches.
If you still have the same issue after trying that, boost the VDIMM a notch. the rest of your settings look pretty good... Although I have found dropping the CPU and QPI PLL to 1.625V helps stability during overclocking.
They released a bios allowing PCI-e packet size to be manipulated last week, i am running tri-sli AND a raid card that is x8....SO what do you guys think has anyone tested different packet sizes on this board yet? if so, results?
ok stable now @4ghz
my settings are :
Frequency Control
CPU Clock Ratio ( 20X )
CPU Host Frequency (Mhz) ( 190 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto ) ---> ok to leave it Auto ??
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 1067Mhz / 2:8 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( auto )
tCL Setting ( 7 )
tRCD Setting ( 7 )
tRP Setting ( 7 )
tRAS Setting ( 26 )
tRFC Setting ( 59 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.3 )
CPU VTT Voltage ( +75 )
CPU PLL VCore ( 1.650 ) ---> is this ok? the default was 1.8
IOH PLL VCore ( Auto )
QPI PLL VCore ( Auto )
DIMM Voltage ( 1.60 )
DIMM DQ Vref ( +0mV )
IOH VCore ( Auto )
IOH/ICH I/O Voltage ( Auto )
ICH VCore ( Auto )
**VTT PWM Frequency ( 250 )
**CPU PWM Frequency ( 800 )
**CPU Impedance ( Auto )
**QPI Signal Compensation ( Auto )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Enabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( Auto )
if im doing anything wrong please let me know :)
do you guys consider IBT 10 runs @ max memory ok for stability testing ?
I wouldnt change anything quattro :) looks great
Now that you have it stable, do a little tinkering and see if it helps you push it a little further, or if it allows you to lower the VCore, or if it affects benchmarking results:
for your OC, you can probably switch to "Without VDroop" and run the VCore at 1.265 to 1.275 (put it under load, and see what your voltage rises to after a few minutes, then adjust your VCore to the closest setting to what you see under load). As to your VTT, at that freq, you can probably leave VTT at "Auto", with the Classifieds I've played with, I didn't have to add VTT until I passed 4.2GHz.....especially with the Uncore at "Auto" (its fine there unless you are trying to squeeze every last benchmarking point out of your system).
BRB to "3" (This is found under Memory Settings and improves memory scores)
VTT PWM Frequency to "610"
CPU PWM Frequency to "1210"
CPU Impedance to "Less"
QPI Signal Compensation to "Less"
My classified died today.... FF code.... Tried everything (New Ram, CPU, PSU, GPU) Nothing works... This really sucks.....
Edit:
I powered it down before I went to bed last night and tried to restart it again this morning… For some reason it powers up with the FF code and restarts after a few seconds with the same code…
:up: thanks
thanks again, its actual "Without VDroop" i overlooked the template .
ill try reducing the vtt and test again, im going to OC further after i get the nb/sb block from BitsPower + other components :) .
also the RAM im using is my friend's im ordering DOMINATOR GT, 6GB (3x2GB), 2000MHz, 7-8-7-20 , will it play well with classified ?
