yes + 4% 3dmark2001 it's fabulous.
Yes 900pts more
exelent !!!
When Nforce 3 250 are out?
I`ve e-mailed DFI to do a review on the 250 and they said early April . Epox might be end of this month though. The rest will follow soon after.
anybody find core cg core?
Wee, i just got my new Power supply, Antec Trueblue 480w, and now i could make a stable clock of my cpu. 10x230 - 1.65vcore. Is'nt that okay? I have'nt tried higher, but i'm sure that it can go 2400MHZ :P
http://www012.upp.so-net.ne.jp/ohij2/k8v.htm
air cooling
Athlon64 3400+iADA3400AEP5AP:( CAAOC 0401SPMW
vcore 1.55v
http://www012.upp.so-net.ne.jp/ohij2/11x224-3355-xp.gif http://www012.upp.so-net.ne.jp/ohij2/11x224-104-xp.gif:
Plugged it all in today. Much to my dismay gigabyte F'ed up the mounting bracket by using clips instead of screws... yay.
K8N Pro, havent done any testing or anything, just "hay, it works"
http://www.ocfaq.com/files/0310_supa642200.gif
Any one have a link to a thread with K8N pro tweaking info? looking for info on exactly what all of the voltages are, as well as how the hell to gain access to more advanced functions such as memory timings
edit: Note the CG.. anyone else got one of these? seeing pretty much all C0s in the thread
waouhhhhhhh a CG core !!!!! :banana:
you are very lucky !!!!!
what is the stepp ?????????
:toast:
it s the first i seen , i hope i could have one soon in france to chill it. :toast:
stepping is CAAPC date 0401
Got it shipped to me right from AMD... <3 review samples
Anyway... more random settings.. hehe
http://www.ocfaq.com/files/0310_supa642300.jpg
went to DDR votlage +.3 and HT +.1 and vDDQ +.1 core 1.7... probably could get away with less than that.
going to go play something :D
Control/F1 gets you to advanced menu in the K8NPRO....
Thanks, you've saved me from minutes of painful manual reading :DQuote:
ok , pleased to meet you. ;)
have a good overclock :)
i hope the CG core had more potential.
show us how it perform.
I have to sleep i'm dead.
But i'm excited to get up tomorrow
don't touch the vcore ;) just fsb and hit the max stable at default voltage.
to hit max fsb put the LDT to 2,5X max about 290
LDT 2X max 330
+1:slobber:Quote:
LDT 2X max 330
YOUR VCORE IS WAY TO HIGH.
Try to reach max stable with Standard Vcore dude.
Set LDT@2.5x and play :)
damnz, I have a CAATC 0404, newer week than yours but one core revision older :p:
+1 too kakaroto
where do you buy your cg core?
I didn't, I run a tech site and review hardware. AMD sent it to me. :DQuote:
vcore is back down to stock now, trying out 210x10. Passed prime for 4 hours then crapped out... only other thing I changed was memory voltage +.1, might need more. Before I go further I want to work with the memory timing more. The comp refuses to load windows with any of the manual settings i've tried so far ( 6-2-2-2 7-3-3-2 11-2-2-2 ). When I was trying to get 7-3-3-2 working I thought it might be the tREF so I had it on 2x3120, 1x3120 1x1554 4x2??? 128... Once I get that locked down I'll toy with speeds more. Time to go look up the vmem mod and such.... my 1GB BH5 is hungry :)
edit: kakaroto, something else you might want to know is that my CPU is brown, not a green like yours.
edit2: have a look http://www.ocfaq.com/files/0304_IMG_0770.jpg
put the LDT to 2,5X
Desynch the ram AUTO to 150 or 166 , at default timings.
stock vcore.
and pump up the FSB with clockgen , i think 240 fsb is possible with a cg core at stock voltage , and try with LDT 2X.
the gigabyte mobo don't boot with +230 FSB.
Try with clockgen for NF3 !!!!
www.cpuid.com
cpulloverclock>
34s 1m @ 2460mhz very very nice :)
what mobo gigabyte nf3??
it's not a giga but an ASUS K8V standardQuote:
Originally posted by paul007
cpulloverclock>
look at this page
default ram timings arent acceptable... its BH5, i dont want to run 8-4-4-3Quote:
put the LDT to 2,5X
stock vcore.
www.cpuid.com
Ok i understand , but we want to know if the CG core is better than C0 at stock voltage.
Timings are not important for this test.
you can't hit 2400 mhz at 1,5v ? :(
tryingQuote:
