Originally Posted by
LUCI5R
i) If I use the two Orange SATA ports, do I still have to install Windows using RAID drivers? I'm prepared to format the two drives & re-install Vista, that's not a problem - as long as I don't have to do something special, or something I haven't done before.
ii) So for example, I'll see a C: drive of about 600GB, on which I can do anything I want, like partitions, etc.
One last Query: I know that on RAID 0 if any disk fails, all is lost - whereas in RAID 1 if one disk fails, you can replace it & nothing is lost. But you do get twice the size using RAID 0 and half the size using RAID 1. Just exclusively performance wise - is there a difference between RAID 0 & RAID 1?
Thanks - I appreciate it!
