where is it written? I looked around every corner of the mobo but ı couldn't see anything??
With my E6750 max FSB was 550, but all voltages were at the highest value.
kadir_slayer, above the first PCIx16 slot.
It's not recomended leaving voltages on auto when overclocking, they might not be enough for a specific FSB or they could go very high witch might be more than enough for a certain FSB freq.
Oh, now wait a second, why should I find max FSB with
and then try the same FSB freq with lower volts?Quote:
vnb 1,55v
vfsb 1,4v
vpll 1,8v
It doesn't make sense. :confused:
I think I have to be more clear. Why should I try finding max FSB with
and then try the same FSB withCode:vnb 1,55v
vfsb 1,4v
vpll 1,8v
I think this is what I have to test:Code:vnb 1,4v
vfsb 1,3v
vpll 1,6v
Max FSB withand same FSB withCode:vnb 1,55v
vfsb 1,4v
vpll 1,8v
Witch I did. I found max FSB at 527, and then tried the same FSB with vnb 1,25v vfsb 1,2v vpll 1.5v.Code:vnb 1,25v
vfsb 1,2v
vpll 1.5v
BarboneNet said that for:
vnb 1.25v bios - 1.55v real
vsfb 1.2v bios - 1.4v real
vpll 1.5v bios - 1.8v real. This didn't happend to me because I couldn't boot at FSB 527 with the minimal values.
I don't have a multimeter, I would've measured too.
barbonenet, if you can point me to a post that shows where the multimeter measuring points are I'll take some measurements tomorrow or Monday.
He is right about the over-volting. As soon as I changed those voltages from AUTO to the second lowest setting, it was reflected in VIN1 and VIN3 in Hardware Monitor. Thanks for the heads up buddy, I just got the E8400 and this motherboard last week, and I would not want to run such high voltages with a 45nm CPU.
http://img142.imageshack.us/img142/6385/voltcw1.th.jpg
here is the back of the mobo.......i will search the misure point on front for you;)
k thanks barbonenet. ;)
VSB & VPLL
http://www.xtremesystems.org/forums/...6&d=1187557024
VMCH
http://www.xtremesystems.org/forums/...4&d=1179836885
for vfsb on front of the mobo i can't find it!
Does someone have rev.1.00g of the board and know if there is a V bug for this rev. too?
All you guys worried about voltage... Good grief go join grandma's needle pointers and overclockers forums. They are Xtreme Quilters though.
My 8400 has not seen less than 1.488 since day one. The first time it fired up it was at 500 fsb and 1.6 in the bios. Which turned out to be the 1.488.
It can take it just fine!!! I have punished it for days on end at over 1.6 volts.
I have Xtreme Air cooling that keeps me under 50C no matter what I do.
My northbridge receives the same Xtre3me cooling as does my memory
:banana::banana::banana::banana::banana: slap those processors boys, show'em whose boss!!
Check out the volts on this run!
http://img.photobucket.com/albums/v2...lla/2001se.jpg
I have since clobbered that score but none the less the volts are the big thing here!!
WZ
