Haha :toast:
But I guess i've missed something as to why u want to try it...this is the foxconn bios right? thought helped cf...does it up voltage too?
LOL @ Truckchase!
One guy over at http://www.diskusjon.no/index.php?sh...=836984&st=980
tried one of the bios (880MHz Core, 950MHz Memory, 1.25v 3D Voltage)
- it flashed OK, but 3DMark06 caused a instant freeze.
He got cold feet and flashed back to XT again :D
i used a 6.2mm x 8cm cobber tube from braketube to a car:D
an drill the inside up to 5mm ;)
overclocking in Crossfire mode is easy for me, since I run dual mons. I have a monitor hooked up to each card. All i have to do is disable crossfire in CCC and run rivatuner. overclock both cards and re-enable crossfire. works like a charm in XP. Although vista is a whole other beast.
What games are people playing with crossfire? been alittle dissapointed with the amount of crossfire compatible games.
I'm still waiting for dtek's uni-sink for the 2900xt, before I watercool the cards. Really anxious to get them in the loop.
Yah, to 1.25v, and I suspect it may up the vDDR as well, since they set the default clocks pretty agressive. (for us "old" xt owners with the crappier ram) ATI Tool doesn't work for me so I'd like something that will give me a vGPU bump.
Too bad I quit drinking too early last night... :D
Is there a "best" XT BIOS to flash to? i.e. is the HIS better than the Sapphire or is the Powercolor better?
I did it (flashed the BIOS) because Crysis is coming out next week and based off the beta I need all the FPS I can get. Here are the preliminary results:
2d GPU Voltage from 1.00 to 1.10 and amperage from 25.3 to 33.1. Not sure why they raised 2d volts, that seems dumb. Maybe there's some sort of global multiplier that affects 2d as well. The stock clocks are as advertised (880/950), but fortunately I can use AMD GPU Clock Tool to lower them, as my card was only stable at 864/920 previously. I'm going to start there and work up using UT3 demo as a stability testing platform. (since it's alot more fun than ATI Tool) Here's some info dumps from the BIOS:
OLD:
adapter bn dn dID asic flash romsize test bios p/n
0 01 00 9400 R600 M25P10 20000 pass 113-B00602-103
Adapter 0 (BN=01, DN=00, PCIID=94001002, SSID=31421002)
Asic Family : R600
Flash Type : M25P10 (128 KB)
Product Name : 113-B00602-103 R600 GDDR3_8Mx32 512bit 512MB 507e/514m
Bios Config File : S3B00602.103
Bios P/N : 113-B00602-103
Bios Version : 010.047.000.000.025258
Bios Date : 05/18/07 00:20
NEW:
0 01 00 9400 R600 M25P10 20000 pass 113-B00602-X03
Asic Family : R600
Product Name : 113-B00602-103 R600 GDDR3_8MX32 512BIT 512MB 507E/514M
Bios P/N : 113-B00602-X03
Bios Date : 05/29/07 09:23
All this and I'm not even drinking yet.... :coffee: :explode:
EDIT: For some reason on my card it brought it up to 1.3v in 3d, even though it's advertised as 1.25. My previously stable speeds seem stable, so I'm going to start ramping up the GPU.
Ah, ok :) I have the 1gb GDDR4 pro, and I keep the pro bios, because it benches higher than the XT at the same speeds, and I can already do 820/1035 perfectly stable with the pro bios using atitool artifact scanner for 2+ hours (and still no failure). Of course I am using a thermalright hr-03, as5 and a ghetto mounted 120mm fan :) I may even look into lapping the hr-03, it seems to have a pretty crappy finish on the contact surface. (compared to say, a scythe ninja)
Once ATITool is updated and voltage adjustment works, I assume I will be able to scale even higher as I am on all stock volts with the card currently.
Can you change voltage in ati tool?
Rivatuner info SAPPHIRE 2900PRO 512MB bios
$ffffffffff ----------------------------------------------------------------
$ffffffffff Display adapter information
$0000000000 Description : ATI Radeon HD 2900 PRO
$0000000001 Vendor ID : 1002 (ATI)
$0000000002 Device ID : 9400
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : PCIE
$000000000f PCIE link width : 16x supported, 16x selected
$0000000009 Base address 0 : d0000000 (memory range)
$000000000a Base address 1 : none
$000000000b Base address 2 : fe8e0000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : 0000c000 (I/O range)
$000000000e Base address 5 : none
$ffffffffff ATI specific display adapter information
$0900000000 Graphics core : R600 (320sp)
$0900000002 Memory bus : 512-bit
$0900000001 Memory type : DDR3 SGRAM
$0900000003 Memory amount : 512MB
$0900000004 Core clock : 506.250MHz
$0900000005 Memory clock : 513.000MHz (1026.000MHz effective)
$0900000006 Reference clock : 27.000MHz
$ffffffffff ATI VGA BIOS information
$0a00000000 Title : 113-B00605-100 R600 GDDR3_8Mx32 512bit 512MB 507e/514m
$0a00000001 Date/time : 08/09/07 19:40
$0a00000002 Core clock : 507.000MHz
$0a00000003 Memory clock : 514.000MHz
$0a00000004 Reference clock : 27.000MHz
$0a00020100 GPU VDDC controller : I2C device 70h, register 18h
$0a00020101 GPU VDDC level 0 : 0.700V, VID 94h
$0a00020102 GPU VDDC level 1 : 0.725V, VID 96h
$0a00020103 GPU VDDC level 2 : 0.750V, VID 98h
$0a00020104 GPU VDDC level 3 : 0.775V, VID 9Ah
$0a00020105 GPU VDDC level 4 : 0.800V, VID 9Ch
$0a00020106 GPU VDDC level 5 : 0.825V, VID 9Eh
$0a00020107 GPU VDDC level 6 : 0.850V, VID A0h
$0a00020108 GPU VDDC level 7 : 0.875V, VID A2h
$0a00020109 GPU VDDC level 8 : 0.900V, VID A4h
$0a0002010a GPU VDDC level 9 : 0.925V, VID A6h
$0a0002010b GPU VDDC level 10 : 0.950V, VID A8h
$0a0002010c GPU VDDC level 11 : 0.975V, VID AAh
$0a0002010d GPU VDDC level 12 : 1.000V, VID ACh
$0a0002010e GPU VDDC level 13 : 1.025V, VID AEh
$0a0002010f GPU VDDC level 14 : 1.050V, VID B0h
$0a00020110 GPU VDDC level 15 : 1.075V, VID B2h
$0a00020111 GPU VDDC level 16 : 1.100V, VID B4h
$0a00020112 GPU VDDC level 17 : 1.125V, VID B6h
$0a00020113 GPU VDDC level 18 : 1.150V, VID B8h
$0a00020114 GPU VDDC level 19 : 1.175V, VID BAh
$0a00020115 GPU VDDC level 20 : 1.200V, VID BCh
$0a00020116 GPU VDDC level 21 : 1.225V, VID BEh
$0a00020117 GPU VDDC level 22 : 1.250V, VID C0h
$0a00020118 GPU VDDC level 23 : 1.275V, VID C2h
$0a00020119 GPU VDDC level 24 : 1.300V, VID C4h
$0a0002011a GPU VDDC level 25 : 1.325V, VID C6h
$0a0002011b GPU VDDC level 26 : 1.350V, VID C8h
$0a00020200 RAM VDDC controller : I2C device 71h, register 18h
$0a00020201 RAM VDDC level 0 : 1.800V, VID BAh
$0a00020202 RAM VDDC level 1 : 1.850V, VID BCh
$0a00020203 RAM VDDC level 2 : 1.900V, VID BFh
$0a00020204 RAM VDDC level 3 : 1.950V, VID C2h
$0a00020205 RAM VDDC level 4 : 2.000V, VID C4h
$0a00020206 RAM VDDC level 5 : 2.050V, VID C7h
$0a00020207 RAM VDDC level 6 : 2.100V, VID CAh
$0a00020208 RAM VDDC level 7 : 2.150V, VID CCh
$0a00020209 RAM VDDC level 8 : 2.200V, VID CFh
$0a00020300 RAM VDDQ controller : I2C device 4Ch, register 12h
$0a00020301 RAM VDDQ level 0 : 1.800V, VID 07h
$0a00020302 RAM VDDQ level 1 : 1.850V, VID 14h
$0a00020303 RAM VDDQ level 2 : 1.900V, VID 29h
$0a00020304 RAM VDDQ level 3 : 1.950V, VID 3Dh
$0a00020305 RAM VDDQ level 4 : 2.000V, VID 4Bh
$0a00020306 RAM VDDQ level 5 : 2.050V, VID 61h
$0a00020307 RAM VDDQ level 6 : 2.100V, VID 74h
$0a00020308 RAM VDDQ level 7 : 2.150V, VID 82h
$0a00020309 RAM VDDQ level 8 : 2.200V, VID 97h
$0a00030000 PowerPlay state 0 : 507MHz/514MHz/1.00V/boot
$0a00030001 PowerPlay state 1 : 507MHz/514MHz/1.00V
$0a00030002 PowerPlay state 2 : 601MHz/800MHz/fused VID 1/3D
$0a00030003 PowerPlay state 3 : 601MHz/800MHz/fused VID 1/3D/Overdrive
$0a00030004 PowerPlay state 4 : 588MHz/800MHz/fused VID 2/thermal
$0a00030005 PowerPlay state 5 : 588MHz/800MHz/fused VID 1/UVD
$0a00000008 Memory type : DDR3
$ffffffffff ATI graphics processor registers
$0b00000134 RCU_ASIC_SERIAL_NUM0 : 0054453e
$0b00000138 RCU_ASIC_SERIAL_NUM1 : 0001d726
$0b00000600 CG_SPLL_FUNC_CNTL : 210012ac
$0b00000610 MPLL_FUNC_CNTL : 25001c68
$0b00000618 GENERAL_PWRMGT : 0000060b
$0b00000648 SCLK_FREQ_SETTING_STEP_0_PART1 : 80039500
$0b0000064c SCLK_FREQ_SETTING_STEP_0_PART2 : 80000200
$0b00000650 SCLK_FREQ_SETTING_STEP_1_PART1 : 00014600
$0b00000654 SCLK_FREQ_SETTING_STEP_1_PART2 : 00000000
$0b00000658 SCLK_FREQ_SETTING_STEP_2_PART1 : 00014600
$0b0000065c SCLK_FREQ_SETTING_STEP_2_PART2 : 00000000
$0b00000660 SCLK_FREQ_SETTING_STEP_3_PART1 : 00014600
$0b00000664 SCLK_FREQ_SETTING_STEP_3_PART2 : 00000000
$0b00000668 SCLK_FREQ_SETTING_STEP_4_PART1 : 00014600
$0b0000066c SCLK_FREQ_SETTING_STEP_4_PART2 : 00000000
$0b00000670 SCLK_FREQ_SETTING_STEP_5_PART1 : 00014600
$0b00000674 SCLK_FREQ_SETTING_STEP_5_PART2 : 00000000
$0b00000678 SCLK_FREQ_SETTING_STEP_6_PART1 : 00014600
$0b0000067c SCLK_FREQ_SETTING_STEP_6_PART2 : 00000000
$0b00000680 SCLK_FREQ_SETTING_STEP_7_PART1 : 00014600
$0b00000684 SCLK_FREQ_SETTING_STEP_7_PART2 : 00000000
$0b00000688 SCLK_FREQ_SETTING_STEP_8_PART1 : 00014600
$0b0000068c SCLK_FREQ_SETTING_STEP_8_PART2 : 00000000
$0b00000690 SCLK_FREQ_SETTING_STEP_9_PART1 : 00014600
$0b00000694 SCLK_FREQ_SETTING_STEP_9_PART2 : 00000000
$0b00000698 SCLK_FREQ_SETTING_STEP_10_PART1 : 00014600
$0b0000069c SCLK_FREQ_SETTING_STEP_10_PART2 : 00000000
$0b000006a0 SCLK_FREQ_SETTING_STEP_11_PART1 : 00014600
$0b000006a4 SCLK_FREQ_SETTING_STEP_11_PART2 : 00000000
$0b000006a8 SCLK_FREQ_SETTING_STEP_12_PART1 : 00014600
$0b000006ac SCLK_FREQ_SETTING_STEP_12_PART2 : 00000000
$0b000006b0 SCLK_FREQ_SETTING_STEP_13_PART1 : 00014600
$0b000006b4 SCLK_FREQ_SETTING_STEP_13_PART2 : 00000000
$0b000006b8 SCLK_FREQ_SETTING_STEP_14_PART1 : 00014600
$0b000006bc SCLK_FREQ_SETTING_STEP_14_PART2 : 00000000
$0b000006c0 SCLK_FREQ_SETTING_STEP_15_PART1 : 00014600
$0b000006c4 SCLK_FREQ_SETTING_STEP_15_PART2 : 00000000
$0b000006c8 SCLK_FREQ_SETTING_STEP_16_PART1 : 00014600
$0b000006cc SCLK_FREQ_SETTING_STEP_16_PART2 : 00000000
$0b000006d0 SCLK_FREQ_SETTING_STEP_17_PART1 : 00014600
$0b000006d4 SCLK_FREQ_SETTING_STEP_17_PART2 : 00000000
$0b000006d8 SCLK_FREQ_SETTING_STEP_18_PART1 : 00014600
$0b000006dc SCLK_FREQ_SETTING_STEP_18_PART2 : 00000000
$0b000006e0 SCLK_FREQ_SETTING_STEP_19_PART1 : 00014600
$0b000006e4 SCLK_FREQ_SETTING_STEP_19_PART2 : 00000000
$0b000006e8 MPLL_FREQ_LEVEL_0 : 000ae300
$0b000006ec MPLL_FREQ_LEVEL_1 : 00000000
$0b000006f0 MPLL_FREQ_LEVEL_2 : 00000000
$0b000006f4 MPLL_FREQ_LEVEL_3 : 00000000
$0b000006fc CTXSW_PROFILE_INDEX : 00000000
$0b00000700 HIGH_PROFILE_INDEX : 00000800
$0b00000704 MED_PROFILE_INDEX : 00000c00
$0b00000708 LOW_PROFILE_INDEX : 00000800
$0b0000070c TARGET_AND_CURRENT_PROFILE_INDEX : 00000015
$0b0000078c CG_BUSY_SAMPLING_PARAMETERS : 000241eb
$0b000007d4 CG_SPLL_FUNC_CNTL_2 : 00000000
$0b000007d8 MPLL_FUNC_CNTL_2 : 00000000
$0b000007f4 CG_THERMAL_STATUS : 00000000
$0b000007f8 CG_THERMAL_INT : 00000000
$0b00000804 CG_FDO_CTRL0 : 00000000
$0b00000808 CG_FDO_CTRL1 : 00000000
$0b0000080c CG_FDO_CTRL2 : 00000000
$0b00000810 CG_FDO_LUPT0 : 00000000
$0b00000814 CG_FDO_LUPT1 : 00000000
$0b00000818 CG_FDO_LUPF0 : 00000000
$0b0000081c CG_FDO_LUPF1 : 00000000
$0b00002004 CHMAP : 00003210
$0b00002408 RAMCFG : 000000a8
$0b00005428 CONFIG_MEMSIZE : 20000000
$0b00008950 REG_8950 : 00000000
$0b00008954 REG_8954 : 00000000
Truckchase! nice job man. :toast: Did you flash both cards installed, or pull them out one at a time to flash ea? The readme file shows flash instructions for flashing two cards installed (or just flash mounted in diff slots?) with out having to remove them one at a time to do the flash?
Needs a 12 pack tonight :toast: :D
Thanks! I'm a poor guy, I only have one card. :D I'm just trying this modded BIOS out to increase overclocking capacity due to the increased voltages. I'm still testing, but I'm over 900Mhz now on the core and I've got my memory bumped up by 30Mhz higher than my previous high as well. This BIOS definitely ups the vMEM as well.
If you wanna flash xfire, just make sure to specify the adapter number. I'd do both at a time. Here's the command syntax for atiflash.exe:
--- ATIFLASH v3.39 ---
-h, -?, /h, /? Help (this screen)
Format: ATIFLASH [command] [parameter1] [parameter2] [parameter3] <option/s>
[command]:
-i [Num] Display information of ATI adapters in the system.
Display information of adapter [Num] if specified.
-ai [Num] Display advanced information of ATI adapters on system.
Display advanced information of adapter [Num]
if specified.
-p <Num> <File> Write BIOS image in file <File> to flash ROM in Adapter
<Num>.
-pa <File> Write BIOS image <File> to all appropriate adapters.
-s <Num> <File> [Size] Save BIOS image from adapter <Num> to file <File>.
First [Size] kbytes (except for Theater in bytes) of ROM
content is saved if [Size] is specified.
-cf <File> [Size] [Sum] Calculate 16-bit checksum for file <File>.
Checksum for the first [Size] kbytes of the file is
calculated if [Size] is specified.
-cb <Num> [Size] [Sum] Calculate 16-bit BIOS image checksum for adapter <Num>.
Checksum for the first [Size] kbytes of the ROM content
is calculated if [Size] is specified.
-cr <Num> [Size] [Sum] Calculate 16-bit ROM checksum for adapter <Num> and
compare it to the [Sum] specified. This command is
the same as -cb if [Size] is specified.
-t <Num> Test ROM access of adapter <Num>
-v <Num> <File> Compare ROM content of adapter <Num> to <File>
-mi <Num> [ID] Modify SSID & SVID in BIOS image of adapter <Num> to
<ID>. SSID & SVID in BIOS image of adapter <Num> is
displayed if [ID] is not specified.
-mb <Num> <File> Modify SSID, SVID, BIOS Pin Number, & Boot Message in
BIOS image of adapter <Num> to values in <filename>.
Input file example:
ssid = 715B
svid = 1002
biospn = "113-xxxxxx-xx"
bootmsg = "ATI graphic board"
-pak <File> Package an executable for BIOS update according to
the commands in <File>.
Config file example:
outfile = update.exe
banner = "Update v1.0"
infile = a123.bin
command = -pa infile
<option/s>:
-f Force flashing regardless of security checkings (e.g. AsicID &
BIOS file info check OR boot-up card).
-fa Force flashing bypassing already-programmed check.
-fm Force flashing bypassing BIOS memory config check.
-fs Force flashing bypassing BIOS SSID check.
-fp Force flashing bypassing BIOS P/N check.
-sst Use SST25VFxxx flashing algorithm regardless of ROMID straps.
-st Use ST M25Pxx flashing algorithm regardless of ROMID straps.
-atmel Use AT25Fxxx flashing algorithm regardless of ROMID straps.
-nopci Do not enumerate PCI adapters, i.e. enumerate only AGP and
PCIe adpaters
-pcionly Enumerate only PCI adapters, i.e. do not enumerate AGP and
PCIe adapters
-agp Enumerate only AGP adapters, i.e. do not enumerate PCI and
PCIe adapters unless used with -pcie or -pci
-noagp Do not enumerate AGP adapters, i.e. enumerate only PCI and
PCIe adpaters
-pcie Enumerate only PCIe adapters, i.e. do not enumerate AGP and
PCI adapters unless used with -agp or -pci
-nopcie Do not enumerate PCIe adapters, i.e. enumerate only AGP and
PCI adpaters
-pci Enumerate only PCI adapters, i.e. do not enumerate AGP and
PCIe adapters unless used with -agp or -pcie
-noremap Skip BARs error detection and remapping in PCI configuration
space
-reboot Force a reboot of the system after successfully completing the
specified operation
-siireset Specifies the GPIO Pin to be used as the Reset when updating
SiI1930 microcontroller firmware
Input example:
-siireset=7 <No Spaces>
-siiuprog Specifies the GPIO Pin to be used as the uprog when updating
Input example:
-siiuprog=14 <No Spaces>
-scansii Overrides normal adapter detection to enable detecting SSI
roms with/without TPI firmware
-log Logs output to atiflash.log, overrides existing file
-logappend Logs and appends output to atiflash.log
-ddc Enable DDC support
-padevid=<ID> Use with -pa command to update adapters of specific device ID.
-passid=<ID> Use with -pa command to update adapters of specific SSID.
-pasvid=<ID> Use with -pa command to update adapters of specific SVID.
*<Num> = adapter number, <File> = filename
*[Size] = data block size in KBytes, except for Theater Pro in Bytes
*Use command -i to see the adapter numbers in the system.
*Theater Pro supports commands -i, p, s, cf, cr, t, v and options -f, -noremap.
Even tho that says 3.39, I used 3.43, which can be found here:
http://www.techpowerup.com/downloads...lash_3.43.html
Flashed the '880c950m' bios only (visible) differences:
Vcore 2D= 1.10 (up from 1.00)
Vcore 3D= 1.30 (up from 1.20)
I'm on water, so not so consernd.
Testing in progress - starting point 870 (max stable on 1.20). should hit 900+ if the heat don't get me :D
Initial findings (using Aquamark because it's fast and gives a general idea of where the limits are);
Could loop AM at 910. Card barely breaks 50 degree C (core temp).
At 918 AM crashes 1 out of 2 times. So between 910 and 920 seems to be max OC at 1.30. Since heat seems to be no issue (yet), i'm tempted to try the 1.35 bios.
Something odd though - why does the bios raises the 2D voltage? Maybe it have something to do with the card itself - only alowing 2D +0.2 as max 3D voltage. Seems strange to me.
