Instead of searching this huge thread I'll just ask a quick question.. Does anyone have any issues running the 1:1 533 divider?
when memory gets over 500 fsb 1-1 i cant get it to boot :( so 4.5 gig ddr2 1000 :) so yes and no :)
I was trying 1:1 400fsb x8 on a Q6600 it just wont do it.. I am also wondering if this board or cpu doesnt like using the 8x multi.. Still much more testing to be done though:) I think I'll flash to the newer bios as well.
The original 10 BIOS is more or less useless even under the most undemanding situations.
Well...didnt flash yet...but artifacts dissapeared..and mouse lag too.
It was ati driver related.
Im back to Catalyst 6.9 for now...
Going to flash to B08 tonight and see what happens.
Thanx a lot guys.
I was halfway through my bios flash and it froze (at stock speeds) so my board is a brick now:(
Not very nice. :( :( A UPS should be used and I also don't have that... guess I'll stick to B6R awhile. :(
What how ... you didnt flash in dos ?:slapass:
Sorry to hear that bro...there has to be a way to bring that sucka back to life.
Anyway...is there a way to control those leds that are on the other side of the board...i didnt even know that this board had those until they lite up yesterday night.
Like a dumb a$$ I flashed with Winflash (which says it supports) and it froze at 43%.. I'll just get another bios chip I think and it'll be just fine..
@ VIctorj There are controls in the bois for the lights..
when you go into bios go to uguru part and go to the right like high right key and you sould get a hole new page :)
From what I gather you shouldn't notice any difference to b08.Quote:
I'm using the B08 right now and I will flash with 11Final? as soon as i get home. B08 works fine.
I packaged the ISO with both bioses for convenience. B08 works 100% so you can flash away. The 11Final is not tested by me yet. If there is anyone who can't wait 5 hours for me to report my findings please flash away. (Only for the Truly Xtreme)
Quoted from RichH
RLMQuote:
It is not a newer BIOS build than beta 8, in any way. Ergo if you are already running B08 there is no point whatsoever flashing this BIOS
There's no such thing as "B011", and the sooner people stop referring to that file by that name the less confusing it'll be.
That file posted above that people are referring to as "B11" is renamed 11B08, period. The only "cleaning up" that's been done on it is that it doesn't have the beta identifier on the POST screen, and the ID string says 11 instead of 00. Aside from those two cosmetic changes the file is identical to 11B08 in every respect.
This "cleaning up" means that it looks like a release candidate, yes. However, Abit did something very similar with beta 6 a few weeks back, and as we all now know, that BIOS did not get released.
It would be well worthwhile for people to not get into the habit of referring to this file as a beta 11, as it's then gonna get very confusing if beta 9 or 10 subsequently escapes!
I have a big problem, I can't go to the BIOS anymore ....
If I press DEL, the boot freezes during the Jmicron unit detection .
If I don't press DEL, the system boots normally and fail to load XP which is normal since I use RAID0.
To solve the problem I tried many times the Clear CMOS behind the motherboard, I tried to reflash the B08 BIOS, the B07, I tried to unplung the CDROM that was connected to the Jmicron, still in vain ...
I absolutely have no idea left to solve this ...
Go into bios right then go to uguru when you see like clock speed and such
just click to the right there a hole other section of options :)
ahhh man nikid32, did you turn off or reset the system your self and were you running vista at all
i read somewhere that sometimes this is a screen freeze but everything is still working on the inside but everyone resets it thinking it froze up on them (i did the same thing and had to order a new bios chip)
but apparently in most cases if you just leave it for a long enough time before restarting/reseting your system then the flash will be allright and youll have the new bios, has to do with the desktop doing some thing and making it look like its frozen
Im running B08 right now...no problems yet...just cant pass 400fsb...(not that i tried that hard tho)
Are you guys up to a "post your settings on QuadGT" thread?
Didn't get a chance to flash yet... but if thats a B08 relabeled as 11 then its pointless to flash...
every thing max volts Ftw ??? :)
whats the best bios to run a RAID 0?
