Thanks! Gonna try it when I get home from work! Been waiting for this one :banana: :)Quote:
Dosflash:
awdflash xxxx.xxx /CC /CD /CP /F /R /PY /SN
xxxx.xxxx = bios file
Link to awdflash:
http://www.conman.se/awdflash.exe
Does this motherboard read the cpu temp correct,reason i ask is the last ABIT board i got was reading it to high.
I'm using 1.3 beta. Don't see any improvement by now... same OC.
Just ordered this board, a 6600, 2 gigs of Geil 4-4-4-12 PC8000, and a 7900GTO. Any tips or tricks for tweakin with this board you think may be useful to me? Should hopefully be here wednesday :woot: cant effin wait. with any luck i can run at 400fsb for 3.6, and 4:5 Ram so itll be at 1000.
lol lemme guess... IC7?Quote:
Originally Posted by clone38
EDIT: also, im having a brain fart, where on the cpu will i find the week? Id like to know to compare it to others when i start getting results of benchies.
*Looks at XFire sig* jesus ive been playin GW too much lately...
it's okay, I won't stress the RAM because I have already tested it with Memtest sometime ago...so hot.
http://i82.photobucket.com/albums/j2...hen/Orthos.jpg
no improvment on the bios??? anyone test it yet?
in times of coretemp we can now read out the temps more acurate ;)Quote:
http://www.thecoolest.zerobrains.com...opic.php?t=137
I'd like to see someone test an e6400 in one of these or someone with an e6600 with advanced cooling like LN or DI.
Originally Posted by Alonso
refer to my above screenshot, you can see there is a 10C difference between Core Temp and Abit Guru
hmmm seems everyon in the 4ghz club went with X6800's or 6700 with this board & extreme cooling. No 6400, you rhte only 6600, & my board won't do 445:(Quote:
Originally Posted by malficar
I don't know if it's the 1.3 bios or not (i didn't try it before) but my system goes weird if I use 1.500V or higher. It has killed my raid setup ! i'll try to flash 1.2 final again and try it again.
this new bios Sicness posted is not beta...it is the alpha 13 as can be seen by the extention M606C_13.A02
my board is on its way and i gonna pair it wif my e6400 that does 3.45 @ 1.375vcore on biostar 965p deluxe.. stable orthos 14hrs.
I think big problem bios AW9D MAX 12 or higher version NOTHING PCI-E Lock !!
It was the bios. Returned to 1.2 final an now there is no problem with vcore. 1.725V in bios, Vch 1.85v, vddr 2.3v, 4Ghz (446x9) 1:1 Cas 4-3-2, on AIR:
http://img82.imageshack.us/img82/5694/30609aq3.th.jpg
This mobo works good! :)
Now passing OTRHOS at 3.6Ghz 1.4v in bios.
well i hoped that abit had already fixed this 7950gx2 and uguru problem but it's still there -_- I'm talking about this nasty bug what is that when u got uguru on in windows and u got 7950gx2 card it only works in single gpu mode and after u turn off uguru it can work multi-gpu mode...
Cripes!!!! The only way I was gonna stick with this board for my game was to buy a 7950gx2 card so I can free up the pci slot for sound but still game with sli. I'm thinking more & more of selling this darn board:mad:Quote:
Originally Posted by Keiki
i have this board but haven't built my system yet but if i understand what you're saying correctly...Quote:
if you enable uguru in windows then only one gpu works on the 7950gx2 and if you turn if off, then both gpu's work.
can this problem simply be fixed by turning off uguru before you run 3d/game benches? OR does the 1 core of the gpu remain disabled until you reboot and leave uguru off?
yep luckily u can "fix" it by just turning off uguru when u play/bench but still weird and stupid bug.Quote:
Originally Posted by shimmishim
yeah. that is kind of silly. didn't realize a bug like this existed. interesting indeed.Quote:
not so many aw9d +7950gx2 users out there so that's the reason it's not so well known yet ^^Quote:
(and now is time to test this 1.3 bios)
My system:
Abit AW9D-MAX, X6800 L624, corsair 2x1024 8500C5, PoV 7950GX2.
Some picīs:
http://www.conman.se/x6800/PICT2387liten.JPG
http://www.conman.se/x6800/PICT2391liten.JPG
http://www.conman.se/x6800/PICT2392liten.JPG
http://www.conman.se/x6800/PICT2397liten.JPG
http://www.conman.se/x6800/PICT2399liten.JPG
http://www.conman.se/x6800/PICT2402liten.JPG
http://www.conman.se/x6800/PICT2403liten.JPG
Right now runing SuperPi @ 4,4Ghz
hey about that 1.3 bios it seems to be .A02 file do i just change it to .bin or what?
awdflash M606C_13.A02 /CC /CD /CP /F /R /PY /SN
that will do it :toast:
