I set my ram to like 5-6-6-16 at like 2.4V and raised all the voltages as high as you could go...Quote:
Wil the cpu do over 445 fsb using lower multi ?
for my P5B new beta bios(0706) was a relief. Now I can reach fsb500 with no problem. Actually now my memory cant go any further. :)
Originally Posted by loc.o
oh yeah....no probs with 8,7,6
http://s2.supload.com/thumbs/default/500fsb.JPG
http://valid.x86-secret.com/show_oc?id=126547
Well my e6400 is ordered and for the time being i am using my 805d in the Asus P5b-d wifi. One thing i have noticed is that i cant hard set my memory to ddr2-700 but if i leave it to auto then it works fine at 1:1 350mhz which is the same thing. can anyone explain this? happens in either slots 1 or 2 sticks. Timmings set at 3-4-4-10. Passed memx86 for about an hour with no probs on auto.
Originally Posted by eyes.only
Can anybody tell me what the p5b deluxe does when nothing is inserted and turned on? I'm mean only both powerconnectors connected without cpu, vidcard, mem. I;m thinking you will get at least beeping errors.
I need this info to no for sure my board is broken.
Thanks:toast:
have you tried to pull the battery and clear CMOS for about 5-10 minutes...to make sure the bios code is reset and all capacitors are cleansed of any static electricity...pull your ATX power plug from the board when you do this.
sounds like you got the same deal I got...check a page back or so...probably a burnt FET, which means RMA time! :o
sorry to hear...I was in your same exact shoes bud; should get the new board today
Yep!Quote:
Originally Posted by ssabripo
The first thing the board was doing after the fatal crash is continuesly rebooted like on,off,on,off, etc. After turning down the power for sometime it didn't go on,off anymorel it stayed on, but that's about it, no post, no beeps, no nothing:confused: Oyeah, during/just after the board crashed it smelled like something was burning. Any pictures of the burnt " fet"?
What's that by the way:confused:
Any word from asus?
Bad batch??
no word from Asus...i've called and never heard back. there is an FET close to the wifi board. I looked at them and they visually seem ok, but you never know by just looking.Quote:
I would just RMA it and start fresh.
Oh come on, wtf are Asus thinking.Quote:
Originally Posted by deathman20
This double restart is a load of ****, its stressing the PSU, harddisks etc needlessly.
I wonder when either my 74Gb Raptor or 600W S-12 gives up ill send the bill to asus :rolleyes:
Only problem is, if you RMA a motherboard you will not normally receive a new board as replacement. You are going to get a refurb back from ASUS, which may be fine, or may have an issue that went undiagnosed. This is true of just about every computer-electronics component RMA.
So, you may or may not be "starting fresh".
Andrew
if within 30 days, I would return it for a refund (which is what I did with mine), and just order another one...that way, you are assured a new one, and also save some time when returning, etc.Quote:
Originally Posted by aamsel
My comp restarts halfway in a game or the game just exit to windows
currently running pci express frequency at = 100
363FSB X 9
Vcore 1.55
It passed the 32M SUperPi tests though
Any ideas ?
Are u having an unmodded board? With what chipset voltage?Quote:
Originally Posted by Smartguy
I am running at 500 X 7 with an unmodded P5B Deluxe no probs here at all..
http://valid.x86-secret.com/show_oc?id=126632
1.4375V CPU
2.25V Ram
1.3V FSB
1.25V NB
Auto SB
Auto ICH
Now I am just trying to hit 4ghz
510 fsb on air with unmodded board. Sloooow :D times had a few open while running spi.
Btw cannot use clockgen while cpuz 1.37 is open, gives "device driver already running" error...
12
http://img.photobucket.com/albums/v6...M510loop12.jpg
Done
http://img.photobucket.com/albums/v6...10dualdone.jpg
Guys....I DID IT!!!:eek: :banana: :woot: :D
after 2 bad/burned boards, PSU issues, yada yada yada, I finally was able to achieve this!! e6300 conroe over air:
http://pichostwizard.com/img/285262.jpg
I'm at 50C under no load, so I'm not liking that, so I think for everyday 24/7 use, I will drop down to just 3.0ghz, and drop the Vcore from 1.4875 to 1.475.
thanks to everyone for all their guidance and help!!! you guys rock! :toast:
32m superpi is not much of a stress test. Try some 3dmark and orthos.Quote:
Originally Posted by hotchoc
While all chips are different, 1.55 vcore should be more than enough to run at 3.27ghz; seems a little high actually.
Check your temps during orthos. Coretemp has a log file you can look at as well to see what it was when you fail in the game.
what are all of your voltages..etc?
so I ran 3d marks to see how it is...dunno what the numbers should be...is this ok?
all x1900xt and other settings at default...just my first run for sanity testing.
how are my temps? seems a little high...mid 50's to upper 50's under load, 50 with no load... :confused:
http://pichostwizard.com/img/285286.jpg
my e6400 @ 3200MHz and x1900xt 256mb @ stock and I scored 11,5k in mark05. i dunno if your score is cpu limited or not.Quote:
Why such High voltage?Quote:
Here is mine.....
http://members.cox.net/picchost/e6300oc3150.JPG
Vcore: 1.4625Quote:
Originally Posted by Grinch
Vdimm: 2.35
FSB: max
NB: 1.55
SB: 1.8
ICH: auto
WoW such low voltage... im going to try this NOW. :DQuote:
Originally Posted by n91htmare
