Originally Posted by
Zucker2k
@ Dostoyevsky77, where have you been hiding? Nice to see you back.
Alright guys and girls, I have a proposition. It's amazing how quickly we can forget stuff, but I have this pesky thing where I can boot windows normal running my Q9550 @ 495 fsb, but at 500 fsb, I always get a black screen..... unless I switch off the system and kill the switch. It'll seem a strap change may be the issue, since I'm running @ PL8 with CL5, but even if I change to PL9, I get the same treatment at boot. The system is perfectly stable (guess not) in windows,and I've shown you some screenies of it priming at 4.250Ghz (8.5 x 500). This anomally is true for both 308 and 701 bioses. So I decided to go to the very early bioses and re-discovered 0207. This bios' microcode is obviously outdated,and even though it throws up a warning about updating my bios to unleash the full power of the processor, actual performance in windows is on par with 308. 207 has a higher TRFC too, and very low gtls - 57 (which I'm running on right now), 59, 61, and 63. The only problem I foresee is TRFC is maxed at 42. Now if we can convince Ket? to copy the latest microcode and may be update the ram table in 207, maybe even append the gtl configuration for that bios, we should have a very effective hybrid bios which should help many people overclock their quads better. I doubt Asus will ever go to those low gtls again. What do you guys think?
PS: Oh, 0207 did solve my booting issue @ 500 FSB when I use 0.57x gtl and bump fsbt a bit higher.
