Lennox & Spuggi GJ!
Lennox & Spuggi GJ!
My watercooled TJ07, system specs in signature:
very nice :)
Metric, what NB block is that? looks sexy ;)
I guess I should post all my worklog over here too but heres some pics anyways.
Heres a link to a youtube video I made showing my hidden LCD display: http://www.youtube.com/watch?v=HUupnpLPAS4
This is 3 Loops:
Loop 1:
EK Suprme CPU BLOCK, 120.3 Swiftek Rad, Swiftek Res, MCP665 Pump, Blue UV FluidXP EXP
Loop 2:
Two EK Nickel Plated 3870X2 Blocks, Two 120.2 Swiftek Rads, Swiftek Res, MCP665 Pump, Red/Pink UV FluidXP EXP
Loop 3:
Danger Den Chipset Block, BlackIce GTX120, Swiftek Res, D5 Pump, Green UV PCICE
http://img509.imageshack.us/img509/2671/pict0312ja3.jpg
http://img213.imageshack.us/img213/1659/pict0316yb5.jpg
http://img509.imageshack.us/img509/4295/pict0331mk1.jpg
http://img216.imageshack.us/img216/6555/pict0335hu1.jpg
http://img168.imageshack.us/img168/622/pict0305fo4.jpg
http://img395.imageshack.us/img395/8127/pict0368pd6.jpg
http://img183.imageshack.us/img183/5283/pict0371ph8.jpg
Wow, thats very nice. Did you paint those, or are they stickers?
They are vinyl wraps I custom edited in Photoshop to fit my case. I had a company print them for me. It was about $160 to get all mine done. But its High quality gloss finish. Looks better then paint I think. And its something I was able to more less do myself.
thats one bling tj07 man :up: i like
dude !!!! post your worklog here!!!!
awesome rig man!
http://dl6.techpowerup.com/reviews/C...s/girls181.jpg
any more pic's metric?
Looks Major Kick @ss kasu code!
Thanks guys. Ill repost my log here when I get a chance.
I dont know anyone local skilled with an air-brush that can do the same quality work I can do in photoshop. :( I know you had smooth creations do yours before, if i remember right. Id have to look into it. Overall I am very happy with the vinyl and being able to print your own custom work on your computer is great.
I can't believe everyone spotted my fill line.. I thought for sure someone would ask :shrug: :)
that is a very nice tri-loop kasu :up:
@Kasu Code, I just went through your worklog, and you never mentioned what you put in the front of the case? IS that just glued Acrylic with holes cut out for the maze? And how did you get the Raptor in the window(I couldn't see any screws. . .)?
Yea I kinda forgot to take pictures of installing that because I got carried away.
First off its AC.Ryan two way mirrior glass.
Cut glass then drilled holes for the Scythe Controller knobs.
I used two stock drive covers at the top and bottom. I was going to bolt the glass to the panels but didnt like how it would look. So I used heavy duty clear double sided tape. I also used it to mount the monitor. It works great.
The hard drive is mounted using the screw holes under the harddrive. The other hard drive sits on top of my dvd-rw I might get two more raptors to put under the one in the window. But if I do I might put my chipset water loop to work and cool the drives as they have no airflow.
kasu code i like the kind of industrial tubing type effect with the in and out tubes tied together
Lennox still loving your case dude
Kasu man, that's a respectable rig :up:
Here's the lastest version of my machine...
120.3,2,&1, 2x D5, and some crusty tubing for added bling.
http://i80.photobucket.com/albums/j1...0/IMG_4551.jpg
http://i80.photobucket.com/albums/j1...install081.jpg
http://i80.photobucket.com/albums/j1...install084.jpg
That tubing is just...ew! :D
Is that cooled by milk?
it kinda looks like your using milk as a coolant :D
