What coolers are those on the video cards? They look really good, and aren't too big. Is the CPU overclocked, and what temps do you get on it?
The gpu coolers are Zalman VF1000's, really nice and aren't too loud since I control them via my Kaze master controller. The CPU is clocked to 3.8 right now and I get idles of around 37-38C, on load it never goes past 50-ish, the NB stays around 32C
EDIT: bah smee types faster than me
@saint-francis
You've inspired me! I am going to have to make a wood case now.
hi pvtdonuts..nice rig you have there..hope you don't mine me asking what timings do you have your ram at as i have the same ram and i no its holding me back with my over clocking i have the 680i im a waiting on evga with me upgrade ..grrrrr..for the 780i i have mine linked and sync at 3.2 ghz but no it will go more its just the ram timings i need to get right if you could shed some light on this i would be really pleased.thax
I thought seriously about walnut but it's so heavy that I thought it would be too much for the shelf I have the system on. I ended up using white oak. But remember, if you are going to make a completely enclosed case you will have to deal with the inevitable echoing that will come from using a wooden case. You will need to get some acoustic sound deadening material.
A slight update to my LCed case...
http://img411.imageshack.us/img411/3599/base3005ou6.jpg
http://img441.imageshack.us/img441/2413/base3001zl5.jpg
Those cards are crying out for waterblocks:D
nice bugiz... 15.9mm OD... what's the ID of that tubing?
Any difference in temps from 8/11mm? (guess not...)
@Garrett:
Better temps? No, i dont think so. But is looks better :-) ID? No idea, u can order it here http://www.aquatuning.de/product_inf...12mm-klar.html
@ CYBERDUID... AMAZING!!! i love the red. that must be SOOO amazingly fast. i love it!
knowing the Druid, probably some crazyness like dual 120.3's or something. :p
i'm very envious cyber!!
what cpu's are you running mate?
I rekon a couple of acetal ek fc 3870x2 wb's are calling you name :)
Looks very clean n awefull :)
Awesome maybe? :D
I use a PA160/MCP 655/Silenx to cool the dual Xeons. The rad and fan and pump are outside the house in the winter weather: works very well: 45,45,23,23,32,36,35,33 Load temps ;)
Here are some pics of my systems, i know it is not the most beautiful but one of the most powerful :)
http://img186.imageshack.us/img186/2...neu1mw6.th.jpghttp://img366.imageshack.us/img366/9...neu2zt9.th.jpghttp://img393.imageshack.us/img393/5...neu3ir8.th.jpg
