Gosh I really like that bitfenix case with the graphics card against the window. If only I wasnt addicted to making monster specs :(
I was going to try it out with the stock fans for a while, but they were far too noisy, so I added my silent red led fans to the case, but they are rattling a little because the screws don't fit in them too well. I managed to eliminate a lot of rattle by temporarily sticking cellotape to the screws, but will try installing them again with a better screwdriver, or buy some rubber grommets if that doesn't work:
http://i.imgur.com/vWa8tnJ.jpg
http://i.imgur.com/r1H7PNF.jpg
http://i.imgur.com/faI65DR.jpg
They seem to match very well! How are you orienting the motherboard in the case?
4 Attachment(s)
Hey guys, just got my Phanteks the other day, and damn is it a beast! =D
Temp on my x3470 @ 4ghz 1.35vcore is 70c load =)
A little off-topic, but what is the best thermal paste these days for air/water cooling? I use the Noctua NT-H1, is there a better performing option out there?
http://img132.imageshack.us/img132/5569/n4op.jpg
Some new fans to replace old or crappy ones.
NB E-Loop B12-4 for CPU cooler:
http://i.imgur.com/A2MzlgL.jpg
2x San Ace 120x25mm for intake:
http://i.imgur.com/LPXpYVV.jpg
Lian Li Q06b, Asus p8z77-i deluxe, i7 2700k @ 4.8ghz, gtx670 @ 1250/7600
cpu: Megahalems + 2 gelid slim fans, gpu cooler - gelid icy vision
Full Album: https://picasaweb.google.com/ae1337/LianLiQ06bITX (32 photos)
https://lh3.googleusercontent.com/-j...00/Q06_001.jpg
A major upgrade this year too: AMD FX8350 -> Intel i7-4930K.
Other specs.
Cooler Master HAF 932.
Corsair AX860.
ASRock X79 Extreme11.
CM Hyper 412S.
Corsair Vengeance LP 1866CL9, 4x4GB.
Gigabyte HD7970.
HDD WD 1TB+2TB.
ODD Lite-On BD-RW.
Looking for a replacement SSD since Intel 120GB is to smal.
HP Storagework LTO-3 Ultrium 920.
[EDIT] Added Delock PCI-E 2xSER card & the old Plusdeck2 (tapedeck).
http://i1153.photobucket.com/albums/...ps77c6d4e0.jpg
