Bad luck m8 though at least you can get to 2.4Quote:
These need volts. What voltage do you have?Quote:
I have a similar one and at stocks volts it doesn't do jack. However, it reacts very well to volts, and heat and power consumption indicate it is reasonable happy at those volts.
new results.
Again, my Opteron 175 CCBWE 0534SPMW, now at higher volts.
I have it at 1.6V, Big Typhoon.
It has been dual-priming all night.
I have been initially disappointed, it doesn't clock well at lower volts. But it seems that this one really likes mid-high volts. Power consumption and heat indicate that the load is not insane, so I might very well settle for this 24/7 and see what happens long-term.
Sorry for the Unix shot. I have not been able to make Windows 2000 boot or switch to the "SMP kernel" or whatever that is called in Windows land. Any hints?Code:last pid: 872; load averages: 2.00, 1.99, 1.92 up 0+11:21:44 07:55:30
46 processes: 3 running, 43 sleeping
CPU states: 0.0% user, 96.8% nice, 0.4% system, 0.0% interrupt, 2.8% idle
Mem: 35M Active, 89M Inact, 65M Wired, 40K Cache, 60M Buf, 303M Free
Swap: 3025M Total, 3025M Free
PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND
574 cracauer 1 139 20 8372K 6992K RUN 0 672:11 98.58% mprime-real
530 cracauer 1 139 20 8372K 6984K CPU1 0 673:26 97.22% mprime-real
730 cracauer 1 96 0 2380K 1480K select 0 0:15 0.00% top
761 cracauer 1 96 0 2376K 1476K select 0 0:15 0.00% top
786 cracauer 1 96 0 2380K 1480K select 0 0:13 0.00% top
710 cracauer 1 96 0 6060K 2672K select 0 0:02 0.00% sshd
766 cracauer 1 96 0 6060K 2668K select 0 0:01 0.00% sshd
573 cracauer 1 -8 0 1188K 544K piperd 0 0:01 0.00% tee
531 cracauer 1 -8 0 1188K 544K piperd 1 0:01 0.00% tee
439 root 1 96 0 9148K 4912K select 0 0:01 0.00% httpd
446 daemon 1 96 0 1268K 872K select 0 0:00 0.00% healthd
Originally Posted by Martin Cracauer
Most I have pumped into is is 1.525, It will prime at 2.5 (250x10 1:1 4x HT) for about 30 min at that vcore.
I didnt think it would be safe to pump any more through it with an XP-90.
Going to try your suggestion, kinda risky since I do not have an accurate tempature monitor. (SLI-DR Expert is way off on Opterons) I believe its reading around 20c low. Assuming this is true Dual Priming at 1.568 is still keeping me at ~55c. PWMIC is 41c and Chipset is 43c.
I have everything running smooth at 2.6ghz with stock voltage on my opteron 170. Much more than that and it will become unstable but does not scale at all with voltage. It seems like I just can't get it to play nice with my memory even though all of the timings are really lose. Once I figure it out Ill post some results.
Nobody can tell you how much volts is safe.Quote:
I made a decision that this CPU wants the volts and rewards it with much better clocks. My single-core Opterons have much smaller gains from high volts. My decision to feed this one what it wants includes that I won't complain if it breaks sometime soon. If it does, at least I'll know what an unsafe voltage is :)
As for temperatures, get a fan controller with thermal probes. If you insert the probe under the heatsink's base plate right next to the IHS on the chip, with contact to the IHS, you come very close to accurate readings. Just mentally add 5 degrees, or "calibrate" by using it on a board with working monitoring first.
Another thing to do is get a power meter and observe how much it is drawing. To produce excessive amounts of heat it would also have to draw a lot of power. This is the main reason why I trust my overclock above, the 1.6 volts dual-core with dual prime does not draw more than my 1.6 volts single-core CABYE.
(disclaimer: yes I know volts kill independently of heat, this is why I say I take my chances)
Well so far,
Raised the Vcore to 1.568
Just passed 2 hours Dual Prime at 10x250 1:1 4x HT
Moving up to 10x255 and trying that.. So Far So Good.
Seems you were correct that this stepping like some voltage.
Judging from my experiance on how warm my HSF gets at a specific temp Im estimating around low to mid 50s for temps..
Mine is the exact stepping and it sucks just as bad, glad someone else is having the same problem, I thought my board or memory was failing. I can run super pi at 10x2.4ghz and that is my best. I think I am going to ebay mine.
well got the cpu stable 23hrs+ primex2 small ftts @2650Mhz 1.48V CPUx10 HTx3 (600 in Bios) HTT650 but due to mobo not liking TCCD mem its only at 176.7MHz 1T 2 2 2 5 relaxing the mem timings doesnt help to get the mem above 200MHz stable (unless u count 2200MHz htt220 1:1) Hoping for a bios update to improve compatability with TCCD mem - untill then I am stuck out off syn with poorish bandwidth :slapass:
Edit typo error
Do you have your other memory timings set to Auto, and just have the divider and 2225 set? Or do you have other manual settings as well?Quote:
Originally Posted by Zeus...
well I have tried many differnet setting 1t 2T CAs ras etc had this mem stable at 265MHz on my MSI Neo2 Plat so I have treid so much it hurts - its like a blurr the last week - this Bios 703 doesnt like TCCD or doesnt like mine the settings ATM are auto except the mem is limited to 133MHz in bios any higher and it fails to boot when overclocking -oh set mem to 2.9Volts could take it higher but the mem doesnt need that much its not like I was going for 1:1 @ 300HTTQuote:
Originally Posted by phadeout
weren't you able to hit 2.95 GHz or so on that chip before you fried your old board?Quote:
Originally Posted by jsriolo
Well just an update on my 0536 Opty 170.
Earlier today I couldnt get 2500 stable until 1.568 vcore. I dual primed it for around 2 hours. Now after that Im running 2500 at 1.52 vcore, and its been stable for over 4 hours. This is the first positive sign I have had out of this processor, maybe this stepping just requires some burn-in to work well. I'm just hoping for 2.6 (Don't think its worth the effort to go any higher with this proc)
[that was 2.70 GHz]Quote:
Unfortunately, one core decided to freak out after 20 hours of prime95.
Back to the drawing board I guess...
20 hours? still a pretty good sign of stability for normal use..
:p:
after 20 hours? Dude, i think its plenty stable for daily use if it goes that long.
I was messing with the new ASUS A8N32 SLI board..
http://img234.imageshack.us/img234/9...00653ft.th.jpg
http://img234.imageshack.us/img234/5...00715nw.th.jpg
I thought my DFI board PWMIC temps were holding me back but i basically capped out at the same speeds with the ASUS board.
I just can't get 2.9 GHz primestable. (dual SuperPi 32mb is fine)
2.8 GHz @ 1.4V seems to be the sweet spot..
You think my 12V rail going down to 11.72 could be effecting my overclock?
Anyway, going to be keeping the DFI board.. the Asus board does have some nice features but it was way too expensive ($270). I prefer the DFI bios and I won't be using SLI so it is kind of a waste.
12V goes to 11.72... what did it start at? 12? 11.9? etc.
Smartguardian reports 11.83V idle.
I've seen it drop to 11.72 underload.
It's a Fortron AX450
I have a 7800GT, 2xSATA HDs, DVDRW, and four 120mm case fans.
Originally Posted by demenion
Still within the ATX specs, however I think you might need a larger PS.
You are pushing it for a 450w imo. But hell Im pushing my PCP&C 510 ATX-SLI :P
2x7800GT
2xWD Raptors
2xWD 400GB
2xHitachi 160GB
2x120MM Fans
DVDRW, DVD, CDRW :P
But PCP&C tend to underrate thier Powersupplies. I go from 12.09 Idle to 12.04 load..
I went with the Enermax liberty and that powersupply has really suprised me.
I just got the 500watt version and i was running 7800gtx SLI's, amd opteron 165 w/ 1.55Vcore and some bh memory running at 3.5Vdimm.
My ATX +12V always stays at 12.22, seems like a very strong 12v rail.
ATX +5.0V sits at 4.97-4.99 according to smart gaurdian under CPU load, and 5.02 at idle.
Not for me :(Quote:
Originally Posted by Budwise
Software developer. If I get a segfault I must know it was mine, not the hardware's.
So more volts or settle for 2650 MHz?
that's a pretty decent drop IMO.Quote:
My Enermax 660 keeps my opty, plus my 2GT's (see sig) going strong, Single Instance of Prime plus running 3dmark05, and I see about .02V drop on the 12V rail... Though I have 4 Rails and it's hard to say how this mobo is interpretting that, it's most likely just reading the rail for the 24Pin ATX. The GT's and devices have their own rails, as does the 4Pin CPU connector...
settle for the 2650, i did lol
2650 @ 1.4 seems to be great for me, runs nice and cool anyway.
According to this DFI board, it runs at 23C lol while the PWMIC is 36 and chipset is 39.
DFI REALLY needs to fix that.
Glad to see someone else with some GEIL. My memory wont do past 255 ARGE! and it wont even take more than 3.52Vdimm! ARRRGE!
