Nice ram wow.. I've never seen TCCD run that tight that high...Quote:
Originally Posted by caligula
I bet us that are running 32M are. I think 1M is a joke anyway as it's not representative enough of true perfromnce nor stablilty.
for example.. a dothan at 2.0 vs A64 @ 2.0 dothan wins.. but gets slaughtered at 32M because of crap bandwidth..
Wich one of these would you choose? All are 3500+
CBBID 0450WPAW
CBBHD 0450TPGW
CBBHD 0450UPAW
CBBHD 0450VPBW
CBBHD 0450SPCW
CBBHD 0450SPBW
CBBHD 0450VPAW
CBBHD 0450UPNW
i´ll buy a new 3500+ winchester, and i can choose from this:
450UPAW
451EPMW
450GPMW
which one would you choose?
@Dirrt: I would try the UPxx if I were you. Good stepping imo
If I were you, I would try the 0450 UPAW. I've got a winnie (3200+) UPcW and that's a nice one :cool:Quote:
Originally Posted by FX Freak
My Winny 3000 Stock cooled
Msi Neo2 noMod bios 1.36 beta
2*512 A-Data Vitesta ddr 600 (2.5-3-3-5 @ 305mhz)
Win2003 Server
Maxtor DMP 8 30 Giga (Waiting for Raptor in warranty)
http://img179.exs.cx/img179/9947/275031s8zk.jpg
Waiting for liquid cooling :banana:
PS: But the subzero problem is resolved or not? I want to buy some dryice :D
just tested in bios 3000+ 0451 dpaw 295fsb with 1.55vcore
I got the CBBHD 0450SPBW with last four numbers 0129
thx:)Quote:
Originally Posted by V1nce
other opinions?
what the max clock with your upcw?
Sorry for the small size of the screens, I shrank them a bit too much for the quality.Quote:
Originally Posted by Zebo
http://www.maplehurst.net/images/Mem285-1.jpg
Everest says
8033mb/s read
3143mb/s write
Sandra says
7552mb/s int.
7449mb/s float
Why sandra and everest read scores are so different, I don't know...But the 8k in everest was cool. Those benches were taken at 285, which isn't totally stable, memtest comes up with a couple errors, as will a 32M pi run, which is why I said the ram is really only stable up to 283 with those timings. But it's a moot point, since it won't do 295 1:1 which is what the processor wants so I run it with a 183 divider via A64 tweaker.
0450UPBW on air. :D
Is that 300MHz on GSkill ram, if so LA or LE and 2x512 or 2x256? I have the exact same chip/week/steppings and 2.7 even is as far as I can go. Let me know your results! :banana:Quote:
Originally Posted by vlad
A few new results of my watercooled 0433SPMW. :-)
http://weber-steuerungstechnik.de/overclock/under40.jpg
http://weber-steuerungstechnik.de/overclock/3120mhz.jpg
(pressed print to fast...cpuz don't get the mhz ... )
http://weber-steuerungstechnik.de/ov...3000mhzspi.jpg
http://weber-steuerungstechnik.de/overclock/277mhz.jpg
LA 2x256 :up:Quote:
Originally Posted by TheMeatFrog
Gravedigga good work man :toast:
yeah thats a hell of a oc you managed.
hope its going to be the same here when i install my wc rig
Mine are very stable after 13H of priming.Quote:
http://img186.exs.cx/img186/4021/300...e13h47m2so.jpg
hi :)
here is mine one:
wincester 3000+ @ 285x9 = 2565Mhz 1.56v primestable. i can bench over 2700...
it's not even closer of a 50 week one... but i think it's not bad :p: anyay it's allways runngin a 2280Mhz 1.4 :$
cheers :toast:
http://users.pandora.be/dajefn/pc/ov...ng/2700MHz.JPG
0450WPBW @ boxed cooler
this is not the max at that voltage
What are the temps on this voltage? If I set +0,1V on my cpu, its temperature can easily hit 67C. Maybe because i didn't apply my own thermal paste but left the original which was on the cooler already...
Well I have a 92mm Vantec Tornado on my boxed cooler and I get 45° max 50° at load.
http://www.shadowness.com/users/16200/16116/300pass.JPG
2.7GHz w/ 1.46vcore
i use the speed in my sig for 24/7, 2.7ghz for tests
Nice Overclock! How do you like that Epox?
Hey guys. Hope you can help me a little...
I have just got an mail from my local store, that the next sending of 3000+ Winnys, is with the newest steppings, do you know if thats good or bad?
EDIT: How about this 0449gpgw - is it good or bad?
