deepsilver what do you use to measure the gpu temp?
deepsilver, is its information true enough? did you try smthg else?
What do you mean with "What do you have in it"? Do you want to know which hardware I have in it or what?
ses his sig :banana::banana::banana::banana:
Looking at its design I would recommend some good 38mm thick fans on it, denkis or panas @ 7v (nice, high pressure fans).
hr-05 sli with screwing assembly: :)
http://img254.imageshack.us/img254/8274/img4158as9.jpg
there are small problems with the xtx, but with the 7800 gtx (that is otherwise in) it would fold, i hope.
http://img511.imageshack.us/img511/4462/img4168xm2.jpg
http://img511.imageshack.us/img511/3766/img4170hz0.jpg
http://img352.imageshack.us/img352/199/img4171qi4.jpg
http://img128.imageshack.us/img128/5497/img4174vi8.jpg
is the rear washer hitting the card?
also, whats wrong with using the plastic push pins?
deepsilver
wow
that`s not good thing if you ask me. I suggest you to get a shorter screws
I don't think that screw should be touching the card....
Side note, how well does that accelero X2 cool? What load temps do you get, what case do you have it in, and how noisy is it? My X1900XT went bad and when I sent it back the sent me a X1950XT instead with a preinstalled accelero X2 so I'm curious how well it performs.
Still building but it will go in this case when done.
is that Ultra-120 fan blowing towards the rear exhaust?
I can see space issues, but is there a large difference between blowing into the heatsink compared to sucking through it
Yes it is blowing towards the exhaust. No there is not much difference between pushing and pulling. There will also be a 120 mounted in the 5.25 drive bays feeding air to both the ram and CPU coolers.
Yes, it will. Running the sys in my sig @ a humming.
GeminII with 2x 120x120x38, mounted with anti vibe rubber fittings and running @ 6V:
http://img140.imageshack.us/img140/3494/dsc00040uv4.jpg
My silent System in a Lian Li PC7 :)
http://www.abload.de/img/pc67zs.jpg
