win2000 SP2 is best for 3d01 IIRC...
i use XP SP1...
i use XP SP1...
hey SAE, get your NF4 yet?
from where? :D
I did not kill them, they killed themselves :lol:Quote:
Originally Posted by Revv23
I sold most of them... :D
They should be the same, but maybe they differ in component quality ;) (not officially, the newer nf3/4 boards have superb japanese caps, iirc)
No, I am still not sure where to buy and what vid card (have to wait for the money from board/axp and x800 though).
I really wanna get an FX, but it's not available here... :(
@SAE
FX55 750 € at Ebay ;)
Where? :D
:D The only one I see so far at EBAY, pre-used:Quote:
Originally Posted by SAE
FX-55
Viel Spass !!! :toast:
Hmmm... right... nothing at Ebay. It was one or two weeks ago... :rolleyes:Quote:
got my new LPB today...another damn china....how do i keep getting those? 3 out of 3 now are chinas....hmmm should i see if someone has a taiwan or just see what this china can do under water and phase change?
like whats better about the taiwan boards....higher FSB?
Better stability (waaaaayyyy better) at high fsb together with high vcore/CPU speed.Quote:
Originally Posted by stealth17
That's about it. :D
But some of these china boards are good though, LORD (a great clocker on AXP too) had an excellent one once.
how did you get a taiwan? luck?Quote:
i cant find any of them!!!
i have taiwan chipsets...that count?
I thought your current board was a CH board wasnt it SAE? the one with 263x13?
aorry stealth my first and only TW board was the first and only infinity i boughtfrom newegg.
stealth17 - from witch shop you get china one? :rolleyes:
PS. both my LP B mobos was china made. One can do 225x12, and other, with the very same components, just killed it's own bios, when I try the 225x12 settings, so... ;) Even then china boards have some weak pieces and some very good ones.
It's overclock. Your mileage may wary... :stick:
Anyway, one (the better one, of course... :cussing: ) of my DFI LP B is dead as brick now, after the capacitor mod + 6hours of work, and that it is. No power led light anymore... :brick:
Originally Posted by trodas
The china ones are the lesser boards, the TW are the better ones usually.
my friend is gonna do some moding on my dfi nf2 this weekend
http://forums.moops.tk/showthread.php?t=11 <- ALL mods OK here ?
should i be carefull of anything ? 10x
Hmm... first off: what's he planning to do? I mean, which mods... that's important to know for giving any kinda hints.Quote:
Originally Posted by TEDY
Furthermore your link is dead, it seems. :p:
nope link works
well i want:
vdimm 3.6v max
vdd (do i need more then 1.9v?)
vcore and ocp....so 2.00v is stable...
anything else ?
VDD is not helpful in my experience, seems different for everyone though.
it was a big gain for me. i hit 265 compared to 255 w/ out it...you can tell if ya need it just by seeing if your fsb does better at 1.6 or 1.9 (or in between). id say if it better at 1.9, then go for it!Quote:
1.6 to 1.8 did help me sata wise, 1.9 even more so, but not past that, i dont get SATA corruption at 1.9 ever it seems.... something else always craps out first at those high speeds.
vdd, I have at 2.15V. That should suffice.Quote:
For all the smd mods (ocp, vdimm) - be careful not to lift the smds (vdimm) or to break them off (ocp)? For ocp, just unsolder both sides not leaving any rest of ceramic on the solder pads.
yeah i lifted the smd on my vdimm mod, it was a real pain getting it back on right.
i did my vdimm from the underside...works AWESOME!
Great idea, stealth :thumbsup:
I never lifted that smd though ;) But I often heard of people doing it accidentally.
wish i would ahve thought of that stealth, i am always worried that i didnt get great contact on that smd and in turn lost stability...
