any of you guys been able to get 100bclck and 2933 9-12-12 on samsung to boot?
if so, what did it take?
GOOD sticks + pumping voltage==>WIN :)
Been a bit quite in here :wave:should have some more ln2 by the weekend,will keep pushing :)
Attachment 131380
What's the deal? cannot upload image? :confused:
Sure, have a look
Try 2933 10-12-12 first, if they fail, TRCD limit is low. And decent is relative, if you already need 2,1v for 1400c9 for example, you will most likely run out of voltage to even boot 2933 c9 on air...
Was playing with some cold memorys today and freq,was able to get 18 loops to pass with waza @ these timings and speeds,will get this to pass then push freq to 6.5ghz.I would of screen shot but at loop 18 it shut down:shakes:
http://s10.postimg.org/9u8ylqzuh/6_4.png
Man sux :/
link brokeeeen bull
ahahh,what link ? you mean my shut down i said i had at loop 18,if so that is normal,when running memory so cold -160+ some times after these shut downs code 55 sets in ,this is the time to give up.Even if you can get it back to windows everything becomes unstable,did bench with everything yesterday and everything is still fine :) The OCF is bullet proof :up:
Little bit more guys :up:
bullant - 5:55.312 - 50x100.6 - 1400MHz - 6-10-6-24-64-1 - OCF - GSkill Pis 2x2GB/PSC - 2.19V -CPU-25,Memory Ln2 -160
http://i43.tinypic.com/imjswm.jpg
Great run bullant!
del
Still struggling to break 6:00 barrier..
Tommi_Vercetti - 6:00.297 - 50x100 - 1400.00MHz - 9-12-12-17-107-1 - ASROCK Z87-OCF - G.Skill 2600C10 4GB x2 - 2.2v - CPU H2O/RAM AIR
http://i.imgur.com/rCrctIH.png
Nice Tommi ^
had little play with 5ghz today,trying few things that Ive learn t over the last few days.Was using old OS and think its corrupt,however was pushing bit harder today and seeing what was there,was able to pass 2 loops of 32M with this and with waza,will try it again later with fresh OS to see if there is any improvement
http://s23.postimg.org/k9ro65we3/13222.png
My Samsung 4GHz result
MaJ0r - 7:19:828- 39x102.61 - 1436.6 MHz - 9-12-12-18-108-1T - Asrock Z87 OCF - TeamGroup 2800 C11 2x4GB/Samsung HCH9 - - 2.15v - air/air
http://i.piccy.info/i8/7bd2af892499b...ot0002_800.jpghttp://i.piccy.info/a3/2013-10-12-08...00x500-r/i.gif
I'm away from Hiwa about 0.3sec, may be I have to try catch fast run or reinstall OS. If somebody has a good idea how to improve my result let me know please.
First of all CW major then lucky run.
rerun rerun rerun for 5 hours or so and you will see lucky run
