Fully EK kitted out P6T Deluxe V2 :)
@jedihobbit
Hope i didn't a fend you inn any way. Hehe. So here are the insides of the Mips ram cooler 4 as promised..
http://img.photobucket.com/albums/v2...g/DSC_0054.jpg
:mad: Actually thought it was a great play on words!! :rofl:
Okay looks to have had the channels milled and then the holes drilled......are the edges of the channels at the holes as rough as the pic shows or is that just shadows? Wonder why the channels in the first place as the entry / exit holes kinda sorta look to disrupt flow........ :shrug:
Sorry i didn't check if they where rough. I'll reopen the block later and have a look
Don't worry about that......if it is aluminum the potential of messing up the threads doesn't warrent it. Thanks anyway! :up:
My homemade block, now with laser cutted lga1366 bracket:
http://img.photobucket.com/albums/v2...DSC00850-1.jpg
http://img.photobucket.com/albums/v2...u/DSC00851.jpg
http://img.photobucket.com/albums/v2...u/DSC00853.jpg
On my P6X58D:
http://img.photobucket.com/albums/v2...u/DSC00863.jpg
http://www.abload.de/img/img_7328v2t6.jpg
Filter Unit from Aquacomputer, Stand from Dimastech :)
http://www.abload.de/img/img_3885ysro.jpg
http://www.abload.de/img/img_4634uvk2.jpg
http://www.abload.de/img/img_4754ypo6.jpg
http://www.abload.de/img/img_7980oci2.jpg
http://www.abload.de/img/img_7984wc1j.jpg
http://www.abload.de/img/img_7987qexp.jpg
http://www.abload.de/img/img_7989tkeo.jpg
http://www.abload.de/img/img_7996ye0l.jpg
http://www.abload.de/img/img_8012q983.jpg
http://www.abload.de/img/img_8015wlx5.jpg
http://www.abload.de/img/img_8022lysu.jpg
http://www.abload.de/img/img_8038t260.jpg
PowerColor HD 5870 LCS+
http://www.abload.de/img/dscf5676n6f9.png
Rules added to First post in this thread:
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) Use discretion on the number of images you post for a given part - usually 2-3 images are more than enough to show it off
3) Do not quote images,
4) Post only photos you have taken yourself.
My ek supreme hf full nickel
http://a.imageshack.us/img443/6195/eksup1.jpg
EK Supreme HF Full Nickel
EK FC5850 Nickel + Acetal
http://img137.imageshack.us/img137/295/31030125.jpg
http://img441.imageshack.us/img441/3987/dsc06553g.jpg
http://img811.imageshack.us/img811/7925/blocko.jpg
http://img541.imageshack.us/img541/4261/block2.jpg
