Racuch, I love the shiny black plastic on the cards! Great idea!
Sorry if the picture quality isn't that great, I think facebook degrades them.
http://photos-c.ak.fbcdn.net/hphotos..._8029287_n.jpg
http://photos-h.ak.fbcdn.net/hphotos...3_394751_n.jpg
http://photos-b.ak.fbcdn.net/hphotos..._4599510_n.jpg
http://photos-d.ak.fbcdn.net/hphotos..._8307985_n.jpg
Great like always seba84_2005 But in the last pic you can see your photoshop marks, where the white meets the case :).
Well here is what $6000 and 4-5 months of planning will get you. My friends and coworkers said it was a dumb idea, but oh well. Here you go.
http://img.photobucket.com/albums/v4...0/100_1505.jpg
Side panel is primed grey so I can hand paint it whenever I get bored I have no plans, because if I can get a hold of the CM windowed side panel I will put that in. Yes there is a window actually there it's UV Blue, when I have my UV lights on.
http://img.photobucket.com/albums/v4...0/100_1500.jpg
http://img.photobucket.com/albums/v4...0/100_1501.jpg
http://img.photobucket.com/albums/v4...0/100_1497.jpg
Enjoy, looking to do a P80 project sometime this year.
New to these forums but i will post some pictures.. you folks do awsome work with your cases.....
http://img.photobucket.com/albums/v4...3_01010036.jpg
http://img.photobucket.com/albums/v4...01010034-2.jpg
http://img.photobucket.com/albums/v4...01010033-1.jpg
It's a Mid-Tower Soprano case and really not alot of room to work with there and why the rad is out the back..
I still need to take it back apart and paint the chassic and work on wire management more and maybe switch out the mobo but core hardware is..
e5200 clocked @3.87Ghz
XFX HD4890 clocked @ 1000core/1120ram
Gigabyte 965p DS3 Rev 3.3
Corsair DHX DDR2 PC3200 4 Gigs
WD Black 520G with 32Mb buffer
LG Multi Blu-Ray drive
PC Power & Cooling 610
DD cpu block and XSPC gpu block ..
Black Ice 240GTX rad and Fesser coolant ..
http://img.photobucket.com/albums/v4...g?t=1248625237
Another LC from Polish people :P
http://www.abload.de/img/dscf9315t38k.jpg
http://www.abload.de/img/dscf932246ji.jpg
http://www.abload.de/img/dscf9325x688.jpg
http://www.abload.de/img/dscf9339y5wk.jpg
http://www.abload.de/img/dscf9338k1j5.jpg
http://www.abload.de/img/dscf9357j60e.jpg
http://www.abload.de/img/dscf9366p4zn.jpg
http://www.abload.de/img/dscf937294uj.jpg
fanboy
is that a tsunami case?
also, could you take a pic of how you mounted the rad please?
nice rig right there
wow fanboy... very nice work!
fanboy, nice painting job, I like it! just paint the rad in the same way
This build has been complete for a while now, thought id post some images. No cables were hidden during the making of this machine. Thank you Danger Den for your support!
http://members.cox.net/jeremyhubbard/DSC00201.jpg
http://members.cox.net/jeremyhubbard/DSC00205.jpg
http://members.cox.net/jeremyhubbard/DSC00204.jpg
There are a plethora of beautiful builds from the Polish contingent of late well done lads (.....and ladies if there are any)
Some Norpene goodness, cooling an i7+NB as you can see. Just ignore that spine-like zip-tie collection on that CPU-NB bend, there should have been a steel anti-kink coil, but dummy me ordered the wrong ID and I was too impatient to order the right one. :D
http://img29.imageshack.us/img29/5615/dscf0137z.jpg
http://img21.imageshack.us/img21/1570/dscf0135t.jpg
http://img33.imageshack.us/img33/7517/dscf0132a.jpg
http://img32.imageshack.us/img32/8195/dscf0133i.jpg
@p2501, Massive setup bro, very cool! I assume you have that setup in the event you'd be adding some GPU blocks in the loop.
May I ask what size are your tubes and where did you get/order them from?
Thanks man! :)
No, this setup stays as is, it's to keep that W3520 below 70°C even on the hottest of days (4.2GHzHT@1.32v), fans are only M yates so it's kinda quiet enough.
Tubes are 1/2" ID 3/4" OD Norprene, purchased at Sidewinders. =)
Here's my P180 Mini-build:
http://i109.photobucket.com/albums/n...i/DSC00270.jpg
http://i109.photobucket.com/albums/n...i/DSC00273.jpg
Seems like there's an invasion of the HeatKillers going on. :o Nice builds everyone!
Bought a HAF and a new Rad. Put the 220 in the loop as I thought why not. Will probably end up cooling the GPU's with it in the end.
http://i240.photobucket.com/albums/f...per575/026.jpg
http://i240.photobucket.com/albums/f...per575/022.jpg
update:
http://i240.photobucket.com/albums/f...per575/014.jpg
http://i240.photobucket.com/albums/f...per575/013.jpg
lmao, because I want them to trip on it.
Actually used a slither of it on the bottom of the 220 to stop vibrations, ended up using some scotch double sided tape instead.
very nice build everyone, for some reason I like that HAF with the green coolant a lot :D
Black interior looks so nice
Poland projects rule man
Cheers
The colour is just from the 5% mix of nulon ultra cool that I run in the loop, I don't think it really matches, but then neither does the grey interior, creamy noctua fans, or the blue motherboard, haha.
Only thing I want to do better is the cabling, tidy it up a bit more (behind the HDD rack). I'd also love to redo the tubing with some angled fittings to get rid of some of the bends and excess tubing.
Bloody red project beta version :)
http://www.abload.de/img/bloodyredozvo.jpg
Malik... hard core :)
Colour is incredible!
