Originally Posted by
Waterlogged
There are active and passive versions of the stainless you are talking about BoxGods. The passive is most likely the variant they are using in the pumps as it's much higher in chromium. Also, here's a little food for thought, Gold is much higher on the nobility chart than the stainless we're discussing, why then did Koolance use it to cover their early copper blocks when used with aluminum rads? It's because it was so high on the nobility chart that it was actually impervious to the effects of corrosion. Once you get to a certain point on the chart, things have a natural immunity to the effects of corrosion, passive stainless isn't in that group but it's pretty close.
One more thing, I can't for the life of me remember where I saw it but, I saw something one time that showed there is some sort of voltage leak into the CPU block from the CPU, the person that found this showed that there was indeed a leak, but only when the CPU was in place. They tried testing without the CPU and the was no leak at all. IIRC, This was with C2D so I don't know if the same holds true for i7's.
