I found it is the Uncore giving me the trouble I ran the classified on a lower Uncore and I can pass Linx without a problem, I was running these settings when I had the problem:
Mother Board ( EVGA X58 Classified E-760 )
Drivers ( )
Bios ( S61B )
CPU ( Core i7 920 D0 )
CPU Cooler ( TRUE Push-Pull )
Memory ( 6GB Kingston HyperX 2000mhz Cas9 )
PSU ( Thermaltake ToughPower 1200W )
GPU ( ATI 5870 )
Drivers ( 9.10Beta )
Operating System ( Windows 7 Pro )
Frequency Control
CPU Clock Ratio ( 21X )
CPU Host Frequency (Mhz) ( 201)
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( x20/4000Mhz)
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 102 )
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 2000/ 2:10 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 8 )
tRCD Setting ( 9 )
tRP Setting ( 8 )
tRAS Setting ( 21 )
tRFC Setting ( 88 )
Command Rate ( 1t )
B2B Setting ( Auto/0 )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.3625 )
CPU VTT Voltage ( +300mV )
CPU PLL VCore ( Auto )
**IOH PLL VCore (Auto )
DIMM Voltage ( 1.66V )
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( Auto )
IOH VCore ( 1.200V )
IOH/ICH I/O Voltage ( Auto )
**VTT PWM Frequency ( 610 KHZ )
**CPU PWM Frequency ( 1210 KHZ )
**CPU Impedance ( Less )
**QPI Signal Compensation ( Less )
ICH VCore ( Auto )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Enabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 4.800 GT/s )
OC Recorvery ( Enabled )
PnP/PCI PCI Express
Maximum Payload Size ( Atuo/128 (I think the lowest) )
Okay those are my settings I was having trouble with, now when I just change the memory multiplier to 2:8 so they run at 1600Mhz, and the Uncore from x20 to x18, so I am running a 2:9 memory-uncore divider, I have NO problem at all being stable, it is just when I want to go for an Uncore of 4000mhz and a memory speed of 2000mhz, I dont know why.
