my board died while at 650mhz:( stuck on c1 nomatter what i do
New bios dated 29/12/2008 D45PDC29 for DFI LP DK P45 T2RS+. Link
Major Reasons of Change:
The BIOS enhanced the 16GB memory compatibility issue.
Haven't tried yet. I noticed it today, I'll test it soon.
it's not dead :rolleyes: turn it off, remove both RAMs and start without them. Turn it off again but no CMOS Reset or something like that.
Then try only one module in another slot (if you use the yellow ones, try the orange) and start the board.
If you have other memory modules with different spd it will be easier, just remove battery and start with one module of the other RAM, load defaults and turn it off. Then you can change modules back again and go on with OC :up:
thanx angoholic but i've done all that. it's c1 always, with ram or no ram, i got 3 pairs of dimms that i've tried in all slots, it always stays in c1:mad:
Hi i have been fighting this problem for weeks does anyone have any info or ideas? I cannot get this to run @ 16x for benches please understand that 24/7 stable is not what i am looking for if i get the save/screen shot before it dies i am happy:) Its a real shame as for 2d benches this board is the nut's but 3d just so hard to get 16x pci-e. Any help would be good as i have little hair/patience left:rofl: All this is with no overclock on pci-e and multiple cards starting to lose my mind:shocked:
^^^let's hope the replacement is as good if not better, i got to beat that monster fsb of yours:D
Don't know if it could help you but once i had this problem with the Graphic Interface which linked in x2. After had dismantling the pieces and rebuilting the rig, It disappeard. fortunately...
I just got a 1M running @ 625MHz with boot-up at 615 :)
I need to find the right GTLs settings for increasing my Vnb
But this Bios is crazy, i've got a head pain :D
http://images0.hiboox.com/images/110...8ef7c45f86.bmp
And what a pity for you, Nikk. Hope we will see you again playing on a DFI board :up:
Last week a FET near the NB died so I have to wait for a week or few more days to get the board back from a friend...
damn-it ! That's a black serial^^
i must be careful with mine :D
It's not as bad, we should have enough Alpha&Omega D452 for that game ;)
I have had same issue but solved. Your mobo is probably alive.
This mobo sucks on 3D tests. I have EVGA 9800GX2 and if i OC my CPU, can't boot. But with VGAs like HD2600XT or olders, it works at Q9650/4.7+ GHz or E8600/5+ GHz... Another possibility: i am a stupid guy.
I can only say: Play with it, mine was stuck some hours at C1 but i could also solve that problem, normally if it would be dead it would hang at 88 that means not counting up but rather displays all digits but maybe TheGanG has an advice for you :)
Boot @ 656MHz FSB
(Did not want to upload it first because of the strange number..660 sounds better :D but as you already know the board still gets repaired so i have to wait :( )
it's already sent for rma, replacement should be here tomorrow:p:
i've had it for a week trying to revive it, how long am i supposed to wait lol
Can anyone help me please? :(
I have just bought an E8400 stepping E0 but it won't overclock: who can post every setting in bios to get it stable at 500x8? Thanks in advance; I hope in your help!! :):)
P.S.: the motherboard model is DFI DK P45-T3RSB PLUS
I got C1s and 88s too. It works 1-2 dayz later, nothing else. :cool: Oh i also changed dimm slots hundret times > so it comes back to life. Clear-CMOS may set extremely low VDimm, so our dimms may not want to boot again, just an idea...
I use my BlackOps + E8600/5.6+GHz for 3D benching. BlackOps hasn't high FSB with regular Quads. It's suitable and tuned for QXs with 10-15 multi, rock solid.
Shame, Q9650 can get 3D benchs on DFi at 4.7+ GHz but GX2 doesn't work.
Hello,
I have just tried:
vtt 1,35V (1,37v effective)
CPU GTL 0,63
NV GTL 0,61
FSB Vref 2A
Vcore 1,35V
NB 1,4V
Clockgen 3,75
CPU Clock 0 skew 200ps
CPU Clock 1 skew 100ps
DRAM Timing: my default (8-8-8-24 @ 1,5V); Enhace data transmitting: Normal ; T2 Dispatch: Disabled ; Flex Memory Mode: Disabled
With these settings the motherboard boots up correctly at 450x6 and a SuperPI 1M is correctly executed.
But if I try 470x6, error at POST and the only chance is to reset. What a trouble!
up :(
My results so far with E8600 and Q9650 on my DFI DK P45 T2R/S Plus:
E8600 + 2GB DDR2
4500MHz (9x500 and 4:5 divider) 1.344 vcore / 1.32 vTT / 1.39 vNB / 2x1024 OCZFlexPC9600 @ 1200MHz 5-5-5-15 / 2.11 vdimm = Prime small ftt stable, Prime blend stable, Linpack stable :)
E8600 + 4GB DDR2
4500MHz (9.5x475 and 4:5 divider) 1.344 vcore / 1.30 vTT / 1.42 vNB / 4x1024 OCZFlexPC9600 @ 1190MHz 5-5-5-15 /2.09 vdimm = Prime small ftt stable, Prime blend stable, Linpack stable :D
Q9650 + 2GB DDR2
4300MHz (9x475 and 4:5 divider) 1.344 vcore / 1.32 vTT / 1.42 vNB / 2x1024 OCZFlexPC9600 @ 1190MHz 5-5-5-15 /2.09 vdimm = Prime small ftt stable, Prime blend stable, Linpack stable :)
Q9650 + 4GB DDR2
4300MHz (9x475 and 4:5 divider) 1.344 vcore / 1.32 vTT / 1.42 vNB / 4x1024 OCZFlexPC9600 @ 1190MHz 5-5-5-15 /2.09 vdimm = No boot
4200MHz (9x466 and 4:5 divider) 1.344 vcore / 1.33 vTT / 1.42 vNB / 4x1024 OCZFlexPC9600 @ 1165MHz 5-5-5-15 /2.09 vdimm = Prime small ftt stable, Prime blend Fail, Linpack Fail
4200MHz (9x466 and 5:6 divider) 1.344 vcore / 1.33 vTT / 1.43 vNB / 4x1024 OCZFlexPC9600 @ 1118MHz 5-5-5-15 /2.09 vdimm = Prime small ftt stable, Prime blend Fail, Linpack Fail
4200MHz (9x465 and 1:1 divider) 1.344 vcore / 1.33 vTT / 1.44 vNB / 4x1024 OCZFlexPC9600 @ 970MHz 5-5-5-15 /2.09 vdimm = Prime small ftt stable, Prime blend Fail, Linpack Fail
4050MHz (9x450 and 1:1 divider) 1.225 vcore / 1.27 vTT / 1.42 vNB / 4x1024 OCZFlexPC9600 @ 970MHz 5-5-5-15 /2.09 vdimm = Prime small ftt stable, Prime blend stable, Linpack stable :confused:
Can I conclude that this board cannot run with a high ram load and with an overclocked Quad Core installed?
