I was lucky, they were just getting the stock in today, 20 peices and i was lucky enough to secure one of them, there all sold out now tho.
what is everyones max OC and playable in Crysis.......i got a xfx seems to be a poor overclocker.............720 core 1800 shader and 2000 mem is max.......
that seems like a good clock. but DONT go over 2000 Memory!
I got my EVGA to 740, but I wouldn't keep it that high at all times just to play games. Besides, 2fps won't make that big of a difference while playing Crysis :)
Lets all have a silent prayer to the overclock gods for mascaras. Amen
I found my issues were that I had to remove riva tuner, ati tool, uninstalled the nvidia drivers, removed the card from the slot and reseated the card.
booted into safe mode..ran drivercleaner pro and reinstalled. now I'm getting 13k instead of 7k lol
8800gt at stock was about 11.5k with my system
Interestingly enough the GT score at stock was a few points off from my highest GTS overclock score!
I'm still tweaking and sure I can get some higher core shader clocks since the 7900 bracket came from swiftech today. Now I can mount the mcw60.
this was obtained with the following clocks (gpu/shader/mem) 729/1840/2060
System and CPU Information
Operating System Microsoft Windows Vista
DirectX Version 10.0
Mobo Manufacturer ASUSTeK Computer INC.
Display Information
Graphics Chipset NVIDIA GeForce 8800 GT
Graphics Card Vendor Nvidia Corp
Driver Name NVIDIA GeForce 8800 GT
Driver Version 7.15.11.6904
Driver Status WHQL - Not FM Approved
Linked display adapters No
Video Memory 512 MB
Core Clock N/A
Memory Clock N/A
Benchmark Settings
Default Settings Yes
Program Version 3DMark06 Revision 1 Build 0
Resolution 1280x1024
Anti-Aliasing None
Texture Filtering Optimal
Vertex Shader Profile 3_0
Pixel Shader Profile 3_0
Force Full Precision No
Disable Post-processing No
Force Software Vertex Shaders No
Force Software FP Filtering No
Disable HW Shadow Mapping No
Color Mipmaps No
Repeat Count Off
Fixed Framerate Off
Main Test Results
3DMark Score 13230 3DMarks
SM 2.0 Score 6235 Marks
SM 3.0 Score 5865 Marks
CPU Score 3095 Marks
Detailed Test Results
Graphics Tests
1 - Return to Proxycon 51.027 FPS
2 - Firefly Forest 52.885 FPS
CPU Tests
CPU1 - Red Valley 0.983 FPS
CPU2 - Red Valley 1.559 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 56.231 FPS
2 - Deep Freeze (SM 3.0) 61.072 FPS
trans am, almost identical to mine.
E6850 @ 400x9 = 3.6Ghz
2Gb DDR2 @ 1.25 Ratio = 1000 5-5-5-15-30-2T
8800GT @ 708/1690/2006
169.02 driver set to performance
3DMark Score 13285 3DMarks
SM 2.0 Score 6177 Marks
SM 3.0 Score 5802 Marks
CPU Score 3242 Marks
1 - Return to Proxycon 50.424 FPS
2 - Firefly Forest 52.523 FPS
CPU Tests
CPU1 - Red Valley 1.021 FPS
CPU2 - Red Valley 1.647 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 56.079 FPS
2 - Deep Freeze (SM 3.0) 59.956 FPS
First Boot:
45º Idle @ Fan Auto (29%)
http://aycu05.webshots.com/image/338...5268714_rs.jpg
http://aycu10.webshots.com/image/338...0883700_rs.jpg
regards
wow. is your os vista too?
we are both at 3.6ghz...i tested one at 4-4-4-10 @500mhz then another at 5-5-5-10 @ 600mhz. 600mhz was a tad better.
I'm not sure which ram speed this run had. I can run my shaders really high. 1870mhz. before ati tool artifact checker starts freaking out. I haven't even gamed with this thing yet. just playing am3 and 3dmark2006
Sorry, XP Pro SP2.
3dmark 2006
8800GT Default (625/900)
Forceware 169.04
Q6600@3.6ghz
windows XP
http://aycu29.webshots.com/image/336...5563464_rs.jpg
:up:
mascaras, what's up with your CPU score there?
mascaras, load temps? Stock cooling?
cumps.
I'm running a VF900 on my 8800GT, full loadtemps about 55c. :)
Has anyone been getting better overclocks by slapping heat sinks on the fits?
When my ND1 gets here (maybe today) I am going to sink every chip I can, I cut down some Swiftech MC14's so they should fit anywhere.
mascaras can you have a 2k5 run for me? :toast2:
what are your idle and load temps with fan @ 100%?
mascaras. try 700-1800-1000 and run the artifact checker. kick your fans to 100% in riva and lets see some oc!
Compairing scores on a swedish homepage and its looks like Leadtek overclocks more on the mems...all with Leadtek is over 2100mhz.
anyone with atitool???
my atitool (0.27) dont work correctly ( i want test Scan for artifacts)
regards
Try atitool 0.26 works great
Heres a link http://www.techpowerup.com/atitool/
