Thanks for the input. I'll probably still test it. But I seem to have better OC among other thing with 13.Bxx versions. So I will retest with it soon.
that is a 1333 fsb CPU not a 1333 memory strap!..big difference!...a 1066 fsb CPU working with a 1333 memory strap will give you a higher FSB...that is not the case with the QuadGT which was designed to operate on the 1066 memory strap...maybe a "G0" cpu you could get a higher FSB because of the lower watts it operates at...a "G0" is still a 1066 fsb CPU
Here is a link to all the beta bios for all the new board by Abit.
Quad Prime - in place FFT
3.6GHz
P5K Deluxe
1.5V BIOS set, Damper enabled
D-Tek Fuzion + homemade loop; temperature 23° C
IDLE
http://img.photobucket.com/albums/v3...prime_idle.jpg
LOAD
http://img.photobucket.com/albums/v31/canny/prime.jpg
Here's mine.....8 hour shot :)
Swifty watercooled.
http://i16.photobucket.com/albums/b3..._A8_3.8Ghz.jpg
@bito...nice work man...3.8 is respectable for sure!
dont know...maybe people are cranking the ac to cool the room down to 70 degree's or below, my computer room is the hottest room in the house, older home, and lousy ac, and it stays about 79 degrees. if ya crank up the volts on these chips, the temps get up there!
so the people on air running 3.6~4.0...dont know how they did it, or they just have a fantastic cpu..imho :shrug:
For sure my watercooling setup is not the best and could be improved upon to give lower temps at the expense of noise. I do not have a/c to help.
But i have not seen too many prime stable runs at the high speeds touted as being easily achieved by the G0 Quads on air or otherwise.....mainly just SuperPi shots. I guess it still depends on the quality of the chip itself and the other components in the build.
@icon57.....thank you :)
I've come to question the temps of the air clocking guys who are hitting high OCs. I've got a PA120.3, a lapped IHS, and a DDC-2 with petras top JUST for my quad. I STILL hit the mid 60s range when pushing the volts. So either they have the greatest quads around, or my quad is a reconditioned space heater :)
anyone experiencing any wierdness with coretemp and their quads?
i just noticed that it seems my cores swapped around. I assume this must be a glitch in the software, as i don't see how the hotter cores would change core #'s.
also, do other peoples vcore do the same thing with vdroop? where by upping the voltage a decent amount in the bios yeilds the same vcore under load. @ VID + 125mV, my vcore was aprox 1.36X... @ +137.5mV it goes to 1.376V under load, and @ +150mV it stays the same, at 1.376V.
http://img250.imageshack.us/img250/326/myquadgr1.th.jpg
DL Orthos unpak in a folder, then make a second folder & unpak a sceond copy. Place a Icon on the desk top for each "if you like" open both. Now before starting each open task manager locate ORTHOS right click on it & go to Set Affinity, click, you will see the second pic. below, uncheck CPU1 & CPU3 click ok, then do the same with the other run of ORTHOS but this time uncheck CPU0 & CPU2. Close task mgr & start one run & wait about 5 second for it to start working & then start the second run. That's it.
i hear ya!
i know my exos2 is not the greatest wc setup, but it does the trick.
on load, with a high oc i hit the 60's no prob, and if i start cranking up volts it will go into the 70's on full load. and my GO will do 3.2 on 1.4v, if i want higher Mhz, i need to up the volt to 1.5, and above
so, i have to either keep my ac blowing so cold, and/or add some more fans for more airflow into my case....i dont see either of those things happening...(well maybe some carefully placed fans)
Upto 3.60GHz that is still under max Vcore (1.35 according to Intel) of 1.34V load taken by DMM :D
http://img515.imageshack.us/img515/4...e360ghzfe2.jpg
