ok ok ok ok!
so what you are telling me is that the L12 mod along with the "wire" mod will give me more FSB?
& is the L12 mod described in the attached pic is the one for the Mobiles?! & if yes, which to go, thee 166 or the 200 one?!
thanks
ok ok ok ok!
thanks
dude, you sure you're doing it right? i mean... i didn't read what kinda proc. you used, but i usedQuote:
Originally posted by naelq
ok ok ok ok!
thanks
this to do mine with a dlt3c 1700 jiuhb. seems like you short some pins. might be a new variant of that mod, i wouldn't know, but to me it doesn't look right. btw, 2 pages back in this thread is where i posted this, and it might have been posted earlier aswell!
For DFI it resolves cold boot issues with mobile processors, esp. with L12 mod cause the board's setting the cpu to 200MHz with the latest betas and at 1.45V there 're boot probs then.Quote:
Originally posted by fr33ze
thought that'd be what it does but why do it, better stability/higher oc??
Then there's a rumour it stablizes higher vcore voltages with those mobiles... dunno if it's right.
And L12 as you know enables you to use high fsb with higher multipliers on DFI's nf2 boards.
??? :rolleyes:
cheers SAE, thought it'd be somewhere along those lines.
L12 is working now, but i'll have to buy me a new POWERFUL PSU! cause i have a 0.04v - 0.08v undervolting! :(
240MHz FSB without any problems! ;)
Nice :)Quote:
@fr33ze
:toast: :D
hah you think you .08 is bad, my crappy antec 430 cant hald it within .25 of where its supposed to be.
i set it to 1.8 and itll be at 1.68-1.77
Ohhh!
that's why i'm looking into an ANTEC TC 550W or ENERMAX 550W with adjustable pots!
mmm, adjustable railsQuote:
Ohhh!
Im looking into the Fotron 530, for $82 with adjustable pots i dont think i would even need much more of that (well at least for a while.)
that mod works grate for me!
before= 242FSB
now = 265FSB
HI
Is there a pic for the L12 and 1.775 v default for the 2500 Mobil ?
Yeah. Here...Quote:
Originally posted by lght1
HI
if you read the last couple of pages, you were to find:
:banana: :D :banana:Quote:
Originally posted by SAE
It defaults the cpu from 1.45V to 1.775V. It's one strand of wire in the cpu socket as shown here by soundx98:
http://server6.uploadit.org/files/soundx98-Vcoremod.JPG
Only to do the red one.
You're right of course :DQuote:
hi
thats one of them...but what about the L12 wire for the Mobil Barton?
This Barton seems to have the bridges covered with a clear substance...you can look but not touch...and as I recall...there was only one cut.
The L12 is located in the upper right corner of the image... the black strand.Quote:
hi
It's the socket A shown here, upside down.
hi
thanks for the help.
i now have the 230 fsb back that i had when i had my old 2100 tbred in this board.
will the voltage one really help the DFI coldboot issue?
Should help... but for some it did not resolve anything... try it to make sure.Quote:
hi
