my above quote says so...a quad is very hard to get to 500 fully stable at 8x...i could get there into windows and it was functional but like i said benches were the problem.
Anyone can take a guesstimate on the aprox. LOAD of this Q9650 at 1.6vcore/4400mhz?
Anybody has reports of L822B348 batch being unstable @ 450x9 FSB?
Batch # L820B036
Pack date 31st July
Vid 1.250V
Hi,
This is the max I can get stable on air (hits 78C on dual orthos load), but to be honest I only got there last night so I have only run orthos for an hour, the night before I just went to 4.275gig and I ran orthos for 2 hours stable but am having some problems with my board/memory ATM so things are a bit hit and miss!
Anyone know why my realtemps isnt sensing core's 2 and 3?
Little offtopic: I got same issue Tatty one ! http://img359.imageshack.us/my.php?i...psissuehh6.jpg Core #2 n #3 wont go lower than 40c ???
Sorry...wrong Thread
Got some new memory to sort out my motherboard issues, this has helped me to get here, I stress this was a deathrun to push my board to the limits and is not orthos stable whatsoever, thanks to all the contributoirs here, I picked up a number of tips to help me on my way!
my q9650 VID is 1.2375
BATCH :L820A924 -- 07/31/08
same q9650/cooler
http://img516.imageshack.us/img516/5906/cpuln2.jpghttp://img516.imageshack.us/img516/5043/mbzc0.jpghttp://img360.imageshack.us/img360/5413/tempeb7.jpg
im able to system boot @ 4.6 ghz 511x9 but since 1.45vtt is the max it hinders any further oc.. just got this dfi p35 and idk all the ins/outs of it yet..
looking back @ mars the vregulators are incredible on that mobo
later today ill test the cpu on the giga dq6 p45..
So I am seeing a lot of folks above the recommended vcore and VTT settings of 1.41v vcore and 1.45vtt. Does this mean that those recommended limits have been debunked? I have a QX9650, essientially the same as a Q9650 with adjustable multi and diff stepping, but the voltage limits should be the same across all 45nm quads. Any thoughts?
1.4vcore above recommended?? im below that :D
easy breezy.. it doesnt get any easier than this
http://img171.imageshack.us/img171/908/cpukf7.jpghttp://img89.imageshack.us/img89/2175/mbqi9.jpghttp://img228.imageshack.us/img228/4395/tempty6.jpg
EP45 DQ6 :up: :up: awesome mobo! :clap:
same q9650/ifx14
And now some action NapalmV5... SS are nice, I want to see that thing work !!
I dont run my CPU above 1.4V except for the odd 5 minute bench, when I did that 4.45 run I actually didnt know how many Volts it would take so over volted to be on the safe side, I did a 2006 run yesteday at 4.3gig on 1.375V (BIOS) ....1.36 (real) and she got through it OK, seems to be these chips get better as they "loosten" up.
I can boot to windows at 4.5gig, have not tried anymore than that....too scared, as I am on air the temps are getting a bit toasty in Orthos at that speed :down:
i guess everythings just a ss.. :)
so far 4 x memtest instances stable
cpuz vcore @ 1.328-1.344
http://img201.imageshack.us/img201/1121/cpuzyc9.jpghttp://img265.imageshack.us/img265/2450/realch3.jpghttp://img201.imageshack.us/img201/5683/corehn3.jpg
same q9650/ifx14/ep45dq6
http://img223.imageshack.us/img223/8097/4600gp4.jpg
NapalmV5
wow 500 FSB, nice ! Great chip!
That's friggin amazing that you are over the 475Mhz FSB wall and then going past 500Mhz with a quad, simply amazing. I am assuming you are not using any exotic cooling like phase change or LN. Anyway, what is your VTT voltage set at and what GTL references are you using? I may try to push my chip this week since I haven't really done it yet.
Thanks,
Utnorris
WaterFlex - thanks :)
Utnorris - thanks.. oh ive stated several times air/ifx14 cooling.. no water/phase/ln2
what vtt? forget about it.. you guys wanna faint/end up in the er? :) lol
no gtl tweaking whatsoever.. may play around with gtl to os boot @ 4.7ghz
just listen to your cpu.. itll let you know what it needs/craves :)
hmmm seriously though, whats your VTT i would like to know what to do about mine and a little 4.4 ghz benching :D
Q9650 500x9! It is my dream:rolleyes:
andressergio - thanks :)
SNiiPE_DoGG - lol lets just say it is higher than the "recommended vtt" :)
runs 3dmarks without a hitch @ 500x9
http://www.xtremesystems.org/forums/...69&postcount=9
Nice to see 500FSB becoming not so hard like before :D
Napalm......VERY nice, I see I need to do a little more, havent played with Vtt's yet, just left it on auto, maybe I will raise a bit to lower VCore a bit (hopefully).
thanks tatty and good luck.. wish you 4.5ghz steady aswell :up:
system specs:
Q9650
EP45 DQ6
Mushkin 4GB 1066
4870 1GB @ 850/950
Areca ARC1210/Raptors
Silverstone OP1000
even @ 4GB just as stable
http://img502.imageshack.us/img502/6779/4gbct9.jpg
i did os boot @ 4.7ghz/no gtl settings but no ss.. nonetheless will be enjoying this stable 4.5ghz for some time.. or at least until the next mobo.. :)
good luck guys!
:p: You need a GTX260 :yepp:.....and that one was just at 4gig.
wow NapalmV5 all that on a Giga?! Amazing results!
Can't wait to get my system hooked up and see the Q9650 limits. But quite frankly I think your most likely at the very top.
Well done!
Actually, what he needs to do is add another 4870 or trade that 4870 for a 4870x2, :D
i got onr of these puppies coming at me from NewEgg . will be here wedsday (I hope) i'll post the batch # when i get it can't wait , my 9450 is a dog , the QX9770 is way cool
Tatty_One - oh i wanted a 280GTX.. waiting on the new 280GTX
Jor3lBR - thanks :)
Utnorris - yeh but the issues associated with multi gpu cards is whats keeping me away..
heres that 4.7GHz.. same everything..
http://img254.imageshack.us/img254/6237/4707yh4.jpg
more than just a ss :)
http://img255.imageshack.us/img255/2694/33es3.jpg
how i got to 4.7? patience..
cpu wants to go even higher but this is the end of the road for the mobo on air.. :(
btw if you guys are wondering what air? not ac cold air or anything like that.. just a 71 F ambient
4.75GHz.. maybe i was wrong on the mobo end of road..
pumping more vcore now..
http://img254.imageshack.us/img254/9043/4750ls5.jpg
going for 4.8GHz
http://img152.imageshack.us/img152/4982/4800es0.jpg
im gonna stop here.. dont want to pump more than 1.5vcore on air or at least until i get a better cooler
thats very impressive dude, what board are you using?
i cant even get mine 3d stable at 3.6, its doing my head in.
Andrew
thanks.. giga ep45 dq6
:eek2:NapalmV5
:sofa: tooooo much fsb for quad! Great job !
funny that is, i was looking at that board last night and trying to convince myself not to spend more money on my pc. how are the bios settings in these? eaiser than a DFI x48. as i think im in over my head, just too many settings for somebody who really dosnt have time to play with them all. i did have my q6600 at 3.6 stable on this board but the q9650 really dosnt like anything i throw at it.
Andrew
WaterFlex - its about time quads do high fsb aswell.. :)
terroristone - x38/x48 are the worst chipsets.. unless you ln2 the chipset to hell youre not gonna get much out of it.. theyre more suitable for unlocked cpus..
youre best bet are the p35/p45 mobos and are the fastest :up:
thanks for convincing me. i know im getting off topic here but it will change my input into this thread if all goes right, What board should i look at, i was thinking the dfi p45 but theya re only 4 phase power....
Andrew
hard to say which are the best p45 mobos.. this is my first p45 not much experience
http://img155.imageshack.us/img155/3237/4850te3.jpg
4.9GHz ??
http://img527.imageshack.us/img527/1844/4900eo3.jpg
i better stop before i kill/destroy smtg
545!!! It IS IMPOSSIBLE !
I have MIIF! I HAVE P45. But i have no money for Q9650 !
Is it under water?
I would stop at 500x8 or 500x9!
you'd probably stop before 2.0v VTT, too. Nice, Napalm!
cadaveca - thanks.. lol 2.0vtt ? yikes.. still got some headroom ~2.0vtt..
WaterFlex - if water i wouldve stated so.. its the very same ifx14/fans cooling.. nothing changed.. just raised vcore and a bit of vtt.. you can see the temps going higher
guys, is there a better cooler available right now than the ifx14? im waiting on the copper true.. but whats the best out there right now
I don't care to pay attention much to air cooling...now, if you can get 545 FSB...you MUST be able to get 525-530 stable...WTF.:shakes:
NapalmV5
Make 500x9 stable! It would be fantastic and great !
Napalm, you have to be the luckiest guy I know, go buy some lottery tickets. Amazing FSB you are getting on a quad, regardless if it is air, water or LN. Just amazing. If I were you I would sell that chip for a couple of grand. I am sure you would get it. Can someone please confirm that they can hit 500FSB with a quad?
Thanks,
Utnorris
4,1GHz will be no problem with his Q9650 und P45-DQ6 ;)
About 2 hours Prime with my Q9650@4,4GHz.
Really want to kick him but i need this CPU longer :)
http://www.abload.de/img/441376-3gbx.jpg
Currently the Foxconn ELA board is available and has 16x16 and 8x8x8 crossfire w/ p45 chipset, in the coming weeks we should see the Foxconn P45 Avenger which will be ddr3, and 16x16 and 8x8x8 CF and will be quantum force :D:D:D (I will get this one for sure ;), anyone wanna buy my ram and DFI x38???)
no clockgen.. all clocks/voltages set @ bios.. and still no gtl tweaking not yet anyways..
http://img153.imageshack.us/img153/4239/4500aw7.jpg
NapalmV5
You have amazing chip! 500x9 clock is great. But i can`t believe it`s on air...
He's got and older version of realtemp there so tjmax may be off 5 degrees but from what I see this is not a real hot running quad. This is cooled by TRUE + ultrakaze...
http://lakesidepc.com/27596.JPG
