um, fugger is a poopy head.
Good job Fugger, but it would look a lot more professional if someone checked at least the front page for spelling errors:p:
wow 4Ghz... What a fugger...
very nice.. love the fsb
nice as hell dude!
when can we se som ln2 and extreme superpi results? :D
AWESOME!!!!!!!!!!! 4ghz unmodded is really good.... i hope also 5ghz is within reach.
5ghz is a golden clock for a conroe.
have you tested 3dmark 06 yet?
Shoit!
Nice work Fugger!!! :toast:
-A.
I believe there was talk of how the Conroe XE will be 2.93Ghz stock with unlocked multi able to do 4ghz on air...
Perkam
i have heard about a 3,33ghz XE. but the most extreme edition user have better cooling then just air,specially the netrbust dualcore users :P .
~400 FSB will be possible with higher multiplyers? ex. 15x ?
wow, that might make an Intel lover out of me.. ;)
Originally Posted by BlackX
6ghz i doubt...
btw forgot to say i might change over to an intel rig this christmas cause of the stuff you post, realy amazing
5ghz conroe xe will do superpi at less than 10s most likely.Quote:
Originally Posted by Super strokey
Perkam
That is crazy :slobber: (hey, wanna send me a Conroe sample over my way?)
Beautiful chip!
Total power!
When a test under DICE or DualCascade?:D
The appropriate term for pre-release or sample processors is ES or "engineering sample", alpha and beta are stages in software development.Quote:
Originally Posted by SepheronX
There's no such thing as beta hardware...except maybe the X360 and the PSU issue :D
Perkam
so 4ghz was single core how badly did this hurt its performance??
5ghz at this point sound difficult to reach with both cores IMO
I think it is more like 4.3GHz....Quote:
Originally Posted by perkam
Iterations plotted the Pi times and clock frequencies on a graph and found an almost linear relation, and he predicted that Conroe will break 10s at somewhere about 4.2-4.3GHz.
I don't know whether it was posted here. Either here or at THG Forums...
Let us be just realistic here.Quote:
Originally Posted by mjp1618
1) his chip is Cherry picked.
2) A Center Spin infact
3) He had to disable one of the Core to get to 4Ghz.
4) So what makes you think everyone else will get anything CLOSE to it?
DFi might get you an Extra 5% tops but that wont give 4.3Ghz.. Maybe 4.2 Tops.. but this is the Best Conroe, given to one of the best Intel Overclockers on Earth, Toss in phase and All the Help he got from Intel.. My guess is the wall is around 3.4-3.6Ghz for conroeQuote:
Originally Posted by Willis
LOL, it's just a slightly-modified Vapo. :rolleyes: Compared to the extreme cooling a lot of guys here use, we ain't seen nothing yet. As if a single-stage -60 phase change unit is something other-worldly here?
I'll go with actual, empirical test benches rather than your "guess." Coolaler was hitting 3.5+ on air with stock volts.
Speachless? :confused:Quote:
Originally Posted by nn_step
Conroe breaks 4Ghz
Posted by: Admin on Friday, May 19, 2006 - 12:51 AM
Im speachless...
My A0 chip is not cherry picked at all, luck of the draw and both chips of the same batch were nearly the exact same for OC on air.
B stepping is far superior to my chip and the shipping retails are even better.
Where did nn_step get the info that this chip is a center spin?? It is impossible to tell what part of the wafer these were from.
Nice work Fugger. Conroe has a bright future regardless of what the amd fanboys think :D
Originally Posted by mdzcpa
lol, modded board, not 100% supported (not officially anyways) es cpu and getting the negative remarks rolling on in.:stick:
Thanks for the previews
